Duet 2 WiFi not working
Newish. From December.
Was it ever working?
What firmware version was on before?
Does the wifi firmware version install?
Can you provide the results of a M122?
- No it was never working. Just got it installed last night.
- Not certain. Jumped to 3.1.1. Then, reverted back to 2.05.1
- Again, not certain.
- As soon as I get home, I will post the results of an M122
M122 results
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
Board ID: 08DGM-9T6BU-FG3SD-6JKD4-3SD6J-KUMHF
Used output buffers: 1 of 24 (10 max)
Static ram: 25712
Dynamic ram: 92704 of which 0 recycled
Exception stack ram used: 256
Never used ram: 12400
Tasks: NETWORK(ready,1876) HEAT(blocked,1232) MAIN(running,3864) IDLE(ready,160)
Owned mutexes:
Last reset 00:01:28 ago, cause: power up
Last software reset time unknown, reason: User, spinning module GCodes, available RAM 11548 bytes (slot 0)
Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x04433000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
Error status: 0
Free file entries: 10
SD card 0 not detected, interface speed: 30.0MBytes/sec
MCU temperature: min 29.4, current 29.7, max 29.8
Supply voltage: min 0.9, current 0.9, max 1.0, under voltage events: 0, over voltage events: 0, power good: no
Driver 0: ok, SG min/max not available
Driver 1: ok, SG min/max not available
Driver 2: ok, SG min/max not available
Driver 3: ok, SG min/max not available
Driver 4: ok, SG min/max not available
Cache data hit count 132384348
Slowest loop: 99.43ms; fastest: 0.06ms
Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
=== DDARing ===
Segments left: 0
Stack records: 0 allocated, 0 in use
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is ready with "M122" in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 0.15ms; fastest: 0.00ms
HTTP sessions: 0 of 8- WiFi -
Network state is starting
WiFi module is disabled
ok
- WiFi -
That was after running a M552 S0 command
@Jesterize said in Duet 2 WiFi not working:
WiFi module is disabledput a new
DuetWiFiServer.bin
in /sys on the sd card and try runningM997 S1
(or say yes to let DWC upgrade, if uploaded through DWC)connect a usb* cable and connect to the serial console if you cannot see the update status in the DWC console.
*) please note https://duet3d.dozuki.com/Wiki/USB_ground_loops
Thanks bearer. Did that, went through the upload process, restarted it, ran M552 S0 and still getting "WiFi module is being started". Running a M122 still says WiFi module is disabled.
just to confirm; it went through 5%, 10% ... 100% and said it was done?
@bearer Yup
Funny thing is that if I run a M587 command, I get this: M587: Failed to retrieve network list.
Why would it have trouble retrieving a list?
either the (wifi) firmware is corrupted, or something has failed.
you might be able to get some answers by enabling wifi debug and issuing the firmware update again (will only work with serial console)
M111 P14 S1
andM997 S1
should look something like
Debugging enabled for modules: WiFi(14) Debugging disabled for modules: Platform(0) Network(1) Webserver(2) GCodes(3) Move(4) Heat(5) DDA(6) Roland(7) Scanner(8) PrintMonitor(9) Storage(10) PortControl(11) DuetExpansion(12) FilamentSensors(13) Display(15) LinuxInterface(16) Trying to connect at 230400 baud:success Erasing 4096 bytes... Erasing 212992 bytes... Uploading file... 5% complete 10% complete 15% complete 20% complete 25% complete 30% complete 35% complete 40% complete 45% complete 50% complete 55% complete 60% complete 65% complete 70% complete 75% complete 80% complete 85% complete 90% complete 95% complete Upload successful WiFi: WiFi:ets Jan8 2013,rst cause:2, boot mode:(3,6) WiFi: WiFi: load 0x4010f000, len 1384, room 16 WiFi: tail 8 WiFi: chksum 0x2d ok WiFi: csum 0x2d WiFi: v3fff168c WiFi: ~ld WiFi module started WiFi: mode : sta(84:f3:eb:42:b0:83) WiFi: add if0 WiFi: wifi evt: 8 WiFi: scandone WiFi: ../src/SocketServer.cpp(353): found network xxxxxxxxxxx WiFi: ../src/SocketServer.cpp(353): found network xxxxxxxxxxx WiFi: ../src/SocketServer.cpp(353): found network xxxxxxxxxxx WiFi: ../src/SocketServer.cpp(353): found network xxxxxxxxxxx WiFi: sleep enable,type: 2 WiFi: wifi evt: 2 WiFi: scandone WiFi: state: 0 -> 2 (b0) WiFi: state: 2 -> 3 (0) WiFi: state: 3 -> 5 (10) WiFi: add 0 WiFi: aid 10 WiFi: cnt WiFi: WiFi: connected with xxxxxxxxxxx, channel 13 WiFi: dhcp client start... WiFi: wifi evt: 0 WiFi: ip:10.10.0.196,mask:255.255.255.0,gw:10.10.0.3 WiFi module is connected to access point xxxxxxxxxxx, IP address 10.10.0.196 WiFi: wifi evt: 3 WiFi: pm open,type:2 0
edit:
ifWiFi:ets Jan8 2013,rst cause:2, boot mode:(3,6)
is different then most likely wifi or processor has failedif
WiFi: csum 0x2d
and/orWiFi: v3fff168c
is different, then most likely wrong firmware version (i.e. not v1.23) or corrupt binaryif it hangs after
WiFi: ~ld
then i'd wager something is broke, probably the wifi module, but could also be the processor. -
Did that and this is what I got:
M111 P14 S1
M997 S1
Trying to connect at 230400 baud: success
Uploading file...
5% complete
10% complete
15% complete
20% complete
25% complete
30% complete
35% complete
40% complete
45% complete
50% complete
55% complete
60% complete
65% complete
70% complete
75% complete
80% complete
85% complete
90% complete
95% complete
Upload successful
ok -
Missed the M552 S0. Got this:
M552 S0
WiFi:
WiFi: ets Jan 8 2013,rst cause:2, boot mode:(3,7)
WiFi:
WiFi: tail 8
WiFi: chksum 0x2d
WiFi: csum 0x2d
WiFi: v3fff168c
WiFi: ~ld
ok -
Nothing after
ok
?try
M552 S-1
followed byM552 S0
it should give you the output from the ESP8266 bootloader at least -
It looks like it is hanging on the ~ld.
something is broken
Ah, I might have done M552 S0 before M997 come to think of it.
Anyways, it shows the ESP is trying to boot into mode 3,7 instead of 3,6 - I don't recall the specifics around that issue but smarter people than me should have all the necessary information now at least.
@bearer said in Duet 2 WiFi not working:
I don't see anybody like that around at the moment. Will have to wait for DC to have a say.
Only things I can think of to try in the meantime:
redownload the wifi server bin file, check that the downloaded size matches, rename it and try flashing again
Use these commands to try and clear the saved list of SSIDs and then try starting it again.
M552 S0 ; Disable network module G4 S5 ; wait 5 seconds M588 S"*" ; Clear all saved wifi networks
After doing all that, I get this "Error: M588: Failed to reset the WiFi module to factory settings"
Thanks for trying guys! Hopefully, DC has some good news. Fingers crossed.
while we wait for dc42 to take a look
yeah, that was kinda expected as it seems the wifi module isn't starting its firmware properly.
descember puts you just shy of the 6 months warranty doesn't it? if you've got some hot air soldering tools, or people with tools nearby its quite doable to replace the wifi module, or depending on your location https://forum.duet3d.com/topic/13875/community-repairs?_=1593191305483
Lets see what DC says before you take the torch to it.
