    Duet 2 WiFi not working
    Firmware installation
    664
    • Jesterizeundefined
      Jesterize @Jesterize
      That was after running a M552 S0 command
        A Former User
        @Jesterize said in Duet 2 WiFi not working:
        Network state is starting
        WiFi module is disabled
        put a new DuetWiFiServer.bin in /sys on the sd card and try running M997 S1 (or say yes to let DWC upgrade, if uploaded through DWC)
        connect a usb* cable and connect to the serial console if you cannot see the update status in the DWC console.
        *) please note https://duet3d.dozuki.com/Wiki/USB_ground_loops
          Jesterize
          Thanks bearer. Did that, went through the upload process, restarted it, ran M552 S0 and still getting "WiFi module is being started". Running a M122 still says WiFi module is disabled.
            A Former User
            just to confirm; it went through 5%, 10% ... 100% and said it was done?
            Jesterizeundefined 1 Reply Last reply Reply Quote 0
              Jesterize @A Former User
              @bearer Yup
                Jesterize
                Funny thing is that if I run a M587 command, I get this: M587: Failed to retrieve network list.
                Why would it have trouble retrieving a list?
                  A Former User
                  either the (wifi) firmware is corrupted, or something has failed.
                  you might be able to get some answers by enabling wifi debug and issuing the firmware update again (will only work with serial console)
                  M111 P14 S1 and M997 S1
                  should look something like
                  Debugging enabled for modules: WiFi(14)
                  Debugging disabled for modules: Platform(0) Network(1) Webserver(2) GCodes(3) Move(4) Heat(5) DDA(6) Roland(7) Scanner(8) PrintMonitor(9) Storage(10) PortControl(11) DuetExpansion(12) FilamentSensors(13) Display(15) LinuxInterface(16)
                  Trying to connect at 230400 baud:success
                  Erasing 4096 bytes...
                  Erasing 212992 bytes...
                  Uploading file...
                  5% complete
                  10% complete
                  15% complete
                  20% complete
                  25% complete
                  30% complete
                  35% complete
                  40% complete
                  45% complete
                  50% complete
                  55% complete
                  60% complete
                  65% complete
                  70% complete
                  75% complete
                  80% complete
                  85% complete
                  90% complete
                  95% complete
                  Upload successful
                  WiFi:
                  WiFi:ets Jan8 2013,rst cause:2, boot mode:(3,6)
                  WiFi:
                  WiFi: load 0x4010f000, len 1384, room 16
                  WiFi: tail 8
                  WiFi: chksum 0x2d
                  ok
                  WiFi: csum 0x2d
                  WiFi: v3fff168c
                  WiFi: ~ld
                  WiFi module started
                  WiFi: mode : sta(84:f3:eb:42:b0:83)
                  WiFi: add if0
                  WiFi: wifi evt: 8
                  WiFi: scandone
                  WiFi: ../src/SocketServer.cpp(353): found network xxxxxxxxxxx
                  WiFi: sleep enable,type: 2
                  WiFi: wifi evt: 2
                  WiFi: scandone
                  WiFi: state: 0 -> 2 (b0)
                  WiFi: state: 2 -> 3 (0)
                  WiFi: state: 3 -> 5 (10)
                  WiFi: add 0
                  WiFi: aid 10
                  WiFi: cnt
                  WiFi:
                  WiFi: connected with xxxxxxxxxxx, channel 13
                  WiFi: dhcp client start...
                  WiFi: wifi evt: 0
                  WiFi: ip:10.10.0.196,mask:255.255.255.0,gw:10.10.0.3
                  WiFi module is connected to access point xxxxxxxxxxx, IP address 10.10.0.196
                  WiFi: wifi evt: 3
                  WiFi: pm open,type:2 0
                  edit:
                  if WiFi:ets Jan8 2013,rst cause:2, boot mode:(3,6) is different then most likely wifi or processor has failed
                  if WiFi: csum 0x2d and/or WiFi: v3fff168c is different, then most likely wrong firmware version (i.e. not v1.23) or corrupt binary
                  if it hangs after WiFi: ~ld then i'd wager something is broke, probably the wifi module, but could also be the processor.
                    Jesterize
                    Did that and this is what I got:
                    M111 P14 S1
                    M997 S1
                    Trying to connect at 230400 baud: success
                    Uploading file...
                    5% complete
                    10% complete
                    15% complete
                    20% complete
                    25% complete
                    30% complete
                    35% complete
                    40% complete
                    45% complete
                    50% complete
                    55% complete
                    60% complete
                    65% complete
                    70% complete
                    75% complete
                    80% complete
                    85% complete
                    90% complete
                    95% complete
                    Upload successful
                    ok
                      Jesterize
                      Missed the M552 S0. Got this:
                      M552 S0
                      WiFi:
                      WiFi: ets Jan 8 2013,rst cause:2, boot mode:(3,7)
                      WiFi:
                      WiFi: tail 8
                      WiFi: chksum 0x2d
                      WiFi: csum 0x2d
                      WiFi: v3fff168c
                      WiFi: ~ld
                      ok
                        A Former User
                        Nothing after ok?
                        try M552 S-1 followed byM552 S0 it should give you the output from the ESP8266 bootloader at least
                          Jesterize
                          It looks like it is hanging on the ~ld. 😞 something is broken
                            A Former User
                            Ah, I might have done M552 S0 before M997 come to think of it.
                            Anyways, it shows the ESP is trying to boot into mode 3,7 instead of 3,6 - I don't recall the specifics around that issue but smarter people than me should have all the necessary information now at least.
                              Phaedrux Moderator @A Former User
                              @bearer said in Duet 2 WiFi not working:
                              I don't see anybody like that around at the moment. Will have to wait for DC to have a say.
                              Only things I can think of to try in the meantime:
                              1. redownload the wifi server bin file, check that the downloaded size matches, rename it and try flashing again
                              2. Use these commands to try and clear the saved list of SSIDs and then try starting it again.
                              M552 S0			; Disable network module
                              G4 S5			; wait 5 seconds
                              M588 S"*"			; Clear all saved wifi networks
                                Jesterize
                                After doing all that, I get this "Error: M588: Failed to reset the WiFi module to factory settings"
                                Thanks for trying guys! Hopefully, DC has some good news. Fingers crossed.
                                  A Former User @Jesterize
                                  while we wait for dc42 to take a look
                                  yeah, that was kinda expected as it seems the wifi module isn't starting its firmware properly.
                                  descember puts you just shy of the 6 months warranty doesn't it? if you've got some hot air soldering tools, or people with tools nearby its quite doable to replace the wifi module, or depending on your location https://forum.duet3d.com/topic/13875/community-repairs?_=1593191305483
                                    Lets see what DC says before you take the torch to it. 😜
                                      Jesterize
                                      Alright <sadly putting torch away>.
                                        I'm sorry, we see this type of problem reported occasionally, and we don't know the cause. The only solution we know of is to replace the WiFi module. Please ask your supplier to replace your Duet under warranty.
