Duet 2 WiFi not working
Did that and this is what I got:
M111 P14 S1
Debugging enabled for modules: WiFi(14)
Debugging disabled for modules: Platform(0) Network(1) Webserver(2) GCodes(3) Move(4) Heat(5) DDA(6) Roland(7) Scanner(8) PrintMonitor(9) Storage(10) PortControl(11) DuetExpansion(12) FilamentSensors(13) Display(15) LinuxInterface(16)
M997 S1
Trying to connect at 230400 baud: success
Erasing 4096 bytes...
Erasing 212992 bytes...
Uploading file...
5% complete
10% complete
15% complete
20% complete
25% complete
30% complete
35% complete
40% complete
45% complete
50% complete
55% complete
60% complete
65% complete
70% complete
75% complete
80% complete
85% complete
90% complete
95% complete
Upload successful
ok -
Missed the M552 S0. Got this:
M552 S0
WiFi:
WiFi: ets Jan 8 2013,rst cause:2, boot mode:(3,7)
WiFi:
WiFi: load 0x4010f000, len 1384, room 16
WiFi: tail 8
WiFi: chksum 0x2d
WiFi: csum 0x2d
WiFi: v3fff168c
WiFi: ~ld
ok -
Nothing after
ok
?try
M552 S-1
followed byM552 S0
it should give you the output from the ESP8266 bootloader at least -
It looks like it is hanging on the ~ld.
something is broken
Ah, I might have done M552 S0 before M997 come to think of it.
Anyways, it shows the ESP is trying to boot into mode 3,7 instead of 3,6 - I don't recall the specifics around that issue but smarter people than me should have all the necessary information now at least.
@bearer said in Duet 2 WiFi not working:
I don't see anybody like that around at the moment. Will have to wait for DC to have a say.
Only things I can think of to try in the meantime:
redownload the wifi server bin file, check that the downloaded size matches, rename it and try flashing again
Use these commands to try and clear the saved list of SSIDs and then try starting it again.
M552 S0 ; Disable network module G4 S5 ; wait 5 seconds M588 S"*" ; Clear all saved wifi networks
After doing all that, I get this "Error: M588: Failed to reset the WiFi module to factory settings"
Thanks for trying guys! Hopefully, DC has some good news. Fingers crossed.
while we wait for dc42 to take a look
@Jesterize said in Duet 2 WiFi not working:
yeah, that was kinda expected as it seems the wifi module isn't starting its firmware properly.
descember puts you just shy of the 6 months warranty doesn't it? if you've got some hot air soldering tools, or people with tools nearby its quite doable to replace the wifi module, or depending on your location https://forum.duet3d.com/topic/13875/community-repairs?_=1593191305483
Lets see what DC says before you take the torch to it.
Alright <sadly putting torch away>.
I'm sorry, we see this type of problem reported occasionally, and we don't know the cause. The only solution we know of is to replace the WiFi module. Please ask your supplier to replace your Duet under warranty.
