    Z-Probe Problems after Update from 3.0 to 3.1.1
    Firmware installation
    484
    • Twisterundefined
      Twister
      i have done an Update from 3.0 to 3.1.1 on my Duet Maestro. So now i have Problems with my Z-Probe with an inductive Sensor.
      Message in Console:
      29.6.2020, 10:01:16	Error: Z probe already triggered before probing move started
      29.6.2020, 10:01:15	Error: Z probe already triggered at start of probing move
      29.6.2020, 10:01:14	Error: Z probe already triggered at start of probing move
      29.6.2020, 10:01:13	Error: Z probe already triggered at start of probing move
      29.6.2020, 10:01:12	G32
      I thing the Problem is to invert the Z-Probe. This was changed in 3.1?
      So i tryed to change it.
      My 3.0 Config:
      M558 P5 C"zprobe.in" H8 F60 B0 I1 T12000               ; set Z probe type to switch and the dive height + speeds
      G31 P500 X5 Y35 Z3.15                                     ; set Z probe trigger value, offset and trigger height
      M557 X12.5:230 Y40:225 P3:3                            ; define mesh grid
      So i changed it now to:
      M558 P5 C"^zprobe.in" H8 F60 B0 T12000               ; set Z probe type to switch and the dive height + speeds
      But it doesnt work 😞 Can anyone help me?
        To invert the probe signal you need to use !. The ^ is used to enable the pullup resistor.
        You should also verify that 3.1.1 is actually installed be sending M115.
        Also, send M98 P"config.g" and report any error messages.
        • Twisterundefined
          Twister
          @Phaedrux said in Z-Probe Problems after Update from 3.0 to 3.1.1:
          Thank You that was it 🙂
          M115 reports Firmware 3.1.1
          M98 P"config.g" reports:
          M98 P"config.g"
          HTTP is enabled on port 80
          FTP is disabled
          TELNET is disabled
          Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
          Error: Can't change sensor number of existing heater
          Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 208C
          It looks like i must change the Heater Configs!?
          Regards Manuel
            Phaedrux Moderator @Twister
            @Twister said in Z-Probe Problems after Update from 3.0 to 3.1.1:
            Please post your entire config.g
            • Twisterundefined
              Twister
              Here my config.g:
              ; Configuration file for Duet Maestro (firmware version 3)
              ; generated by RepRapFirmware Configuration Tool v2.1.3 on Tue Nov 26 2019 11:04:32 GMT+0100 (Mitteleuropäische Normalzeit)
              G90                                                     ; send absolute coordinates...
              M83                                                     ; ...but relative extruder moves
              M550 P"CorEssentials"                                   ; set printer name
              M667 S1                                                 ; select CoreXY mode
              M552 P0.0.0.0 S1                                       ; enable network and acquire dynamic address via DHCP
              M586 P0 S1                                             ; enable HTTP
              M586 P1 S0                                             ; disable FTP
              M586 P2 S0                                             ; disable Telnet
              M569 P0 S1                                              ; physical drive 0 goes backwards in stealthchop mode
              M569 P1 S0                                              ; physical drive 1 goes backwards in stealthchop mode
              M569 P2 S1                                              ; physical drive 2 goes forwards in stealthchop mode
              M569 P3 S0                                              ; physical drive 3 goes forwards in stealthchop mode
              M569 P4 S1                                              ; physical drive 4 goes forwards in stealthchop mode
              M569 P5 S0 D2                                           ; physical drive 5 goes backwards in spreadcycle mode
              M569 P6 S0 D2                                           ; physical drive 6 goes backwards in spreadcycle mode
              M584 X5 Y6 Z0:1:2:3 E4                                  ; set drive mapping
              M671 X-35:-35:275:275 Y40:203:203:40 S10		        ; position of z belts
              M350 X16 Y16 Z16 E16 I0                                 ; configure microstepping with interpolation for X Y Z E
              M92 X80 Y80 Z400 E415                                   ; set steps per mm
              M566 X300 Y300 Z60 E120                                 ; set maximum instantaneous speed changes (mm/min)
              ;M566 X900 Y900 Z60 E120                                ; set maximum instantaneous speed changes (mm/min)
              M203 X24000 Y24000 Z6000 E6000                          ; set maximum speeds (mm/min)
              M201 X3000 Y3000 Z1000 E1500                            ; set accelerations (mm/s^2)
              ;M201 X9000 Y9000 Z1000 E1500				            ; set accelerations (mm/s^2)
              M906 X1000 Y1000 Z800 E900 I30                          ; set motor currents (mA) and motor idle factor in per cent
              M84 S30                                                 ; Set idle timeout
              M208 X0 Y0 Z0 S1                                        ; set axis minima
              M208 X240 Y256 Z270 S0                                  ; set axis maxima
              M574 X1 S1 P"xstop"                                     ; configure active-high endstop for low end on X via pin xstop
              M574 Y1 S1 P"ystop"                                     ; configure active-high endstop for low end on Y via pin ystop
              M574 Z1 S1 P"zstop"                                     ; configure active-high endstop for low end on Z via pin zstop
              M558 P5 C"!zprobe.in" H8 F60 B0 T12000                  ; set Z probe type to switch and the dive height + speeds
              M308 S0 P"bedtemp" Y"thermistor" T100000 B3950          ; configure sensor 0 as thermistor on pin bedtemp
              M950 H0 C"bedheat" T0                                   ; create bed heater output on bedheat and map it to sensor 0
              M140 H0   											    ; map heated bed to heater 0
              M143 H0 S120                                            ; set temperature limit for heater 0 to 120C
              M307 H0 B0 S1.00                                        ; disable bang-bang mode for the nozzle heater and set PWM limit
              M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8  ; configure sensor 1 as thermistor on pin e0temp
              M950 H1 C"e0heat" T1                                    ; create nozzle heater output on e0heat and map it to sensor 1
              M143 H1 S280                                            ; set temperature limit for heater 1 to 280C
              M307 H1 B0 S1.00                                        ; disable bang-bang mode for the nozzle heater and set PWM limit
              M308 S2 P"ctemp" Y"thermistor" A"Chamber" T100000 B3950 ; configure sensor 2 as thermistor on pin ctemp
              M950 H2 T2
              M950 F0 C"fan0" Q1000                                   ; create fan 0 on pin fan0 and set its frequency
              M106 P0 C"Coldend" S1 H1 T45                   	        ; set fan 0 value. Thermostatic control is turned on
              M950 F1 C"fan1" Q1000                                   ; create fan 1 on pin fan1 and set its frequency
              M106 P1 C"Part" S0 H-1                                  ; set fan 1 value. Thermostatic control is turned off
              M950 F2 C"fan2" Q1000                                   ; create fan 2 on pin fan2 and set its frequency
              M106 P2 C"Chamber" S0 I0 F1000 H2 T45                   ; set fan 2 value. Thermostatic control is turned on
              ; LED
              M950 P0 C"e1heat" Q1000
              M563 P0 D0 H1 F1                                        ; define tool 0
              G10 P0 X0 Y0 Z0                                         ; set tool 0 axis offsets
              G10 P0 R0 S0                                            ; set initial tool 0 active and standby temperatures to 0C
              M572 D0 S0.15 					                        ; set extruder 0 pressure advance to 0.15 seconds
              M575 P1 S1 B57600                                       ; enable support for PanelDue
              M501                                                    ; load saved parameters from non-volatile memory
              T0                                                      ; select first tool
                How about config-override.g as well.
                  Compare your heater block to the one I just generated in the configurator.
                  Yours:
                  M950 H2 T2
                  Generated:
                  M307 H0 B0 S1.00                               ; disable bang-bang mode for the bed heater and set PWM limit
                  M308 S1 P"e0temp" Y"thermistor" T100000 B4138  ; configure sensor 1 as thermistor on pin e0temp
                  M307 H1 B0 S1.00                               ; disable bang-bang mode for heater  and set PWM limit
                  M308 S2 P"ctemp" Y"thermistor" T100000 B4138   ; configure sensor 2 as thermistor on pin ctemp
                  M950 H2 C"e1heat" T2                           ; create chamber heater output on e1heat and map it to sensor 2
                  M307 H2 B0 S1.00                               ; disable bang-bang mode for the chamber heater and set PWM limit
                  M141 H2                                        ; map chamber to heater 2
                  Note the extra values for the chamber heater. Do you have an active heater for the chamber or is it just to monitor.
                  • baird1faundefined
                    baird1fa
                    I think to invert the probe you need an ! rather than the ^. I think that ^ just enables a pull up resistor.
                    Edit: I see I'm late to the game.
                    • Twisterundefined
                      Twister
                      @Phaedrux here is my config-override.g :
                      ; config-override.g file generated in response to M500 at 2019-12-06 17:11
                      ; Heater model parameters
                      M307 H0 A183.1 C296.0 D2.1 S1.00 V24.2 B0
                      M307 H1 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                      ; Workplace coordinates
                      G10 L2 P1 X0.00 Y0.00 Z0.00
                      G10 L2 P2 X0.00 Y0.00 Z0.00
                      G10 L2 P3 X0.00 Y0.00 Z0.00
                      G10 L2 P4 X0.00 Y0.00 Z0.00
                      G10 L2 P5 X0.00 Y0.00 Z0.00
                      G10 L2 P6 X0.00 Y0.00 Z0.00
                      G10 L2 P7 X0.00 Y0.00 Z0.00
                      G10 L2 P8 X0.00 Y0.00 Z0.00
                      G10 L2 P9 X0.00 Y0.00 Z0.00
                      With your generated Heater config the M98 output this:
                      M98 P"config.g"
                      FTP is disabled
                      TELNET is disabled
                      Warning: Heater 2 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
                      Error: Pin 'e1heat' is not free
                      I have no Chamber Heater (Heat up with Heatbed), only a Temperature Sensor and 2 Macros to power on the Chamber Fans:
                      Macro Chamber ABS:
                      Macro Chamber PLA:
                      M106 P2 C"Chamber" S0 I0 F1000 H2 T20
                        In that case you could remove this part
                        • Twisterundefined
                          Twister
                          Thx 🙂 so i see the Chamber Temp. in the Extra Tab in the WebIF. Is it possible to show up the Chamber Temp. in the Display?
                            Where do you mean? A screen shot says a thousand words.
                            • Twisterundefined
                              Twister
                              Hello again,
                              here in the Webinterface i see under Extras the Chamber Temperature Sensor (Sensor 2):
                              Can i rename it, so that appears "Champer Temperature" in the WebInterface?
                              And is it possible to show up the Temperature in the PanelDue Display?
                                Are you using the code snip I posted? I did not include a name like yours did. So add an A"Chamber Temperature" to the M308.
                                Unfortunately not at this time.
                                https://duet3d.dozuki.com/Wiki/Connecting_an_LCD_control_panel#Section_Limitations
                                • Twisterundefined
                                  Twister
                                  Thank You! It works now fine 🙂
