    Issue with pwm fan output
    4.2k
      Sounds like you may have shorted Fan0 out and blown the fan0 mosfet. Fortunately we added an extra resistor in the Duet WiFi design so that when this happens, it doesn't take the processor out with it.
        T3P3Tony administrators
        Tom, mosfet is a PMV40UN2
        • MrBlomundefined
          MrBlom
          My fan0 just "broke" i hade a wire come lose on the fan most likely shorted it
          fan1 works but fan0 is dead
          can i use fan2 remap fan0 to fan2 ?
          or do i need to change "PMV40UN2"
          soldering on a new "PMV40UN2" will it fix my problem ?
          Thank you
          Regards
          Jens
            Hi if you have a fan channel spare its easiest to remap fan2 to function as fan 0.
            If you are using it as a thermostatic fan then you use M106 to map it to your heater (normally heagter 1 as the bed is heater 0)
            see here:
            https://duet3d.com/wiki/G-code#M106:_Fan_On
            If you are using it as a print cooling fan then setup your tool with it mapped to the correct tool (normally tool 0 for a single extruder printer):
            https://duet3d.com/wiki/G-code#M563:_Define_or_remove_a_tool
            • MrBlomundefined
              MrBlom
              found some more info on the web
              seam changing the "PMV40UN2" do fixe the problem 🙂
              but one more question
              can i take the "PMV40UN2" from fan02 and place it on fan0 for now while waiting for delivery on a new PMV40UN2
              if so do i need to solder back the broken one on fan02 or can i just leave it empty for now (im not using fan02)
              thank you
              Regards
              Jens
                Hi Jens
                Yes you can replace the PMV40UN2 mosfet but since you are not using fan 2 then 1 line of gcode will allow you to use fan2 in place of fan 0, this is probably a lot easier than replacing the mosfet.
                If you de solder fan 2 mosfet and use that to replace fan 0 it is fine to leave the fan2 location empty.
                Cheers
                Tony
                • MrBlomundefined
                  MrBlom
                  Thanks for a fast answer Tony (dident see it at first)
                  add F2 to the tool 0 and im back in business
                  Im so impressed with the duet board
                  i killed my MSK Sbase last week i got this a few days ago and i just love it
                  will never go back 🙂
                  • MrBlomundefined
                    MrBlom
                    Thanks again Tony 🙂
                    • MrBlomundefined
                      MrBlom
                      Hello again
                      i have received the PMV40UN2 (i think. my have nr 72 on top the original have 64)
                      i have only a normal solder set so it was a pain to get it in place and i may have damage it
                      i only get 14v on a 24v system and its 14v always
                      did i damage the PMV40UN2 or is it wrong version
                      or something else i need to know
                      This is the one i got
                      http://www.ebay.com/itm/172590108195?_trksid=p2060353.m2749.l2648&ssPageName=STRK%3AMEBIDX%3AIT
                      Thank you
                      Regards
                      Jens
                        That's the right mosfet. Small MOSFETs are quite easily damaged by static charge until they have been connected in place.
                        • MrBlomundefined
                          MrBlom
                          ok i have one more i will test that one 🙂
                          Thanks for the help
                          • MrBlomundefined
                            MrBlom
                            haha they are relay small 🙂
                            i got 3 of them and two of them jumped away in the installing process
                            i also think i damaged the solder pads when removing the first one
                            so its extra hard to get it in place
                            i need to order 3 more and make a last try
                              I don't advise trying to remove those mosfets without hot air desoldering equipment, because you need to heat all 3 pads at once.
                              • MrBlomundefined
                                MrBlom
                                well im learning by doing 🙂
                                i did damage the 2 lower pads they are gone
                                so i guess i have to live with it ?
                                or can i connect them to something else ?
                                this makes my magnet project a bit harder
                                no i only have 2 fan ports and them are needed to the fans
                                also the heater ports is all out
                                can i use a external board/mosfet to control the magnet on/off(24v)
                                or do i need to get a Duet2/5 board ?
                                a hot air gun is on top of my shopping list now
                                Thanks for the help
                                Regards
                                Jens
                                  If you are looking for an SMD hot air reworking station, the 852D+ isn't bad for a budget unit.
                                  If you look at the Duet WiFi schematic (see https://duet3d.com/wiki/Source_Files for links) then you can see which components the fan mosfet is connected to. You could glue the new mosfet dead bug style to the board and then use wires to connect it.
                                  • MrBlomundefined
                                    MrBlom
                                    thank dc42
                                    been looking at the drawings and this looks correct to me
                                    see pic
                                    https://www.dropbox.com/s/5hx8kb6vppcssvw/likethis2.jpg?dl=0
                                    Please let me know what you think
                                    Thank you
                                    regards
                                    Jens
                                      That looks correct to me too.
                                      • MrBlomundefined
                                        MrBlom
                                        Thank you !
                                        • MrBlomundefined
                                          MrBlom
                                          It works yeah!
                                          thanks for the help
                                          it's not pretty but it works
                                          https://www.dropbox.com/s/zljrxege31854qq/2017-04-26%2018.55.36.jpg?dl=0
                                          Thanks again for the help
