    BLtouch issue
    Firmware installation
    364
      Phaedrux Moderator @janusofdoors
      @vishiano said in BLtouch issue:
      "Error: Failed to enable endstops".
      Post your homing files please.
      Use M115 to verify that you are actually running 3.1.1
      Then send M98 P"config.g" and report any errors.
      janusofdoorsundefined 1 Reply Last reply Reply Quote 0
      • JoergS5undefined
        JoergS5 @janusofdoors
        M584 X0.0 Y0.1 Z0.2 E0.4:05
        not related to bltouch, but you have a missing dot here
        E0.4:05 => E0.4:0.5
        (probably makes no difference, just visually disturbed me)
        • janusofdoorsundefined
          janusofdoors @Phaedrux
          @Phaedrux
          Here is M115
          7/2/2020, 6:45:58 PM M115
          FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.1.1 ELECTRONICS: Duet 3 MB6HC v0.6 or 1.0 FIRMWARE_DATE: 2020-05-19b2
          ; homez.g
          ; called to home the Z axis
          ; generated by RepRapFirmware Configuration Tool v3.1.3 on Mon Jun 29 2020 01:54:12 GMT-0400 (Eastern Daylight Time)
          ;homez.g
          G91 ; relative positioning
          G1 H1 Z505 F1800 ; move Z up until the endstop is triggered
          G92 Z500 ; set Z position to axis maximum (you may want to adjust this)
          ;G91 ; relative positioning
          ;G90 ; absolute positioning
          ; homeall.g
          ; called to home all axes
          G1 H1 X-505 Y-505 F1800 ; move quickly to X or Y endstop and stop there (first pass)
          G1 H1 X-505 ; home X axis
          G1 H1 Y-505 ; home Y axis
          G1 H1 X-505 F360 ; move slowly to X axis endstop once more (second pass)
          G1 H1 Y-505 ; then move slowly to Y axis endstop
          G1 H1 Z505 F360 ; move Z up stopping at the endstop
            janusofdoors @janusofdoors
            @vishiano Only error from M98 is
            M98 P"config.g"
            Warning: M307: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 356C
            I have a separate issue with my heated bed which I believe to be unrelated to the BLtouch issue
              janusofdoors @JoergS5
              @JoergS5 It bothered me enough that I fixed it 😁
                Your homing files are set to use endstops for X Y and Z, but you have only defined endstops for X and Y.
                If you are using a probe for the Z axis, you need to change your homing files to use a G1 X Y move to position the probe, and then a G30 to probe the bed in place of this part:
                Or, if you are using an endstop for the Z axis, you need to define it along with the X Y and Z here:
                M574 X1 S1 P"io0.in" ; configure active-high endstop for low end on X via pin io0.in
                M574 Y1 S1 P"io1.in" ; configure active-high endstop for low end on Y via pin io1.in
                  @Phaedrux
                  So something like the following for homez.g?
                  G90 ; relative positioning
                  G1 X250 Y250 ;move probe to center of bed
                  G30 ;probe bed
                  Only thing is this lowers the bed down instead of up.
                    @vishiano I raised the bed and changed a line in my config.g
                    G31 P0 X0 Y10 Z2.5 ; set Z probe trigger value, offset and trigger height
                    Now when I run homez.g the BLtouch deploys and I get
                    G28 Z
                    Error: Z probe already triggered at start of probing move
                    Error: Homing failed
                      Try G31 p25 instead of p0.
                      If the bed is going the wrong way change the direction of the z axis rotation in m569.
                        @Phaedrux That did it, thanks for the help.
