    filament sensor def. not very usable with PA
    368
    • fcwiltundefined
      fcwilt
      Well according to that dump the device is disabled. Is that true?
      • arhiundefined
        arhi @fcwilt
        @fcwilt said in filament sensor def. not very usable with PA:
        yes, hence it did not pause the print when the read data went over 110% or below 90%, otherwise it behaves just like it's enabled
        • arhiundefined
          arhi
          @fcwilt this is not new, we already discussed it in different thread as the mechanism does not take filament direction into account. During retractions it just ignores input. PA speed/slow down the extruder (and reverse it in some cases) and while I never notice any reverse movement on my setup looks like the slowdown is also not followed up with the filament tracking module 😞
          • arhiundefined
            arhi
            @dc42 sorry I know you are now overloaded with new hw but if you can help out a bit maybe we can solve this 🙂
            I'm looking at the MagneticFilamentMonitor and it's sending a data word with 10bit "filament position". If I convert output of the encoder to a compatible output and send "filament position" that I track locally so increase in one direction, decrease in other (overflow?!) will this work with PA and DAA ? Is the only problem direction or there are other issues with PA/DAA not handling pulse inputs?
            I see that LaserFilamentMonitor is sending 11bit position with 100count/mm configured. Same question as magnetic one?
            It would be super simple to create a small board that takes AB from encoder and generates these signals for the RRF. I can go with ATtiny44A to be compatible with existing boards, should be quick and simple project, but makes no sense in doing it if it will not work. @omni has duet's laser sensor and he's getting similar span of min/max as I am with it with PA+DAA on so that's why I'm bugging you with questions
            • arhiundefined
              arhi
              looks like DDA is not a problem, filament monitor code fetches DDARing::GetAccumulatedExtrusion so it's just PA that's not in this chain 😞
                dc42 administrators @arhi
                @arhi said in filament sensor def. not very usable with PA:
                GetAccumulatedExtrusion looks at the actual number of microsteps taken, so it does take PA into account.
                arhiundefined 1 Reply Last reply Reply Quote 1
                • arhiundefined
                  arhi @dc42
                  @dc42 said in filament sensor def. not very usable with PA:
                  direction too? it reduce the number if PA reverses the direction of the extruder?
                    Yes. However, there is a short delay between the filament monitor starting to take a reading and then sending it to the Duet, so PA does reduce the accuracy of the correlation a little.
                    • arhiundefined
                      arhi
                      I found a bug in my design that allowed filament to slip, that's why I had those "zero" readings... now with fixed design it's much better:
                      Pulse-type filament monitor on pin e0stop, disabled, sensitivity 0.119mm/pulse, allowed movement 90% to 110%, check every 3.0mm, measured sensitivity 0.124mm/pulse, measured minimum 79%, maximum 131% over 9440.3mm
                      this looks usable. If a get a clog/block the min will quickly drop below 50% and the print will pause.. so I just need to add a bigger span than original 90-110 and it should work.
                      Looking at the two "smart" sensors too, I think I'll make one attiny adapter for the encoder type to behave like laser or magnetic one or you think it is better to add a new type of sensor (smart encoder for e.g.) ?
                      • arhiundefined
                        arhi
                        def. works.. finished few prints with enabled sensor with PA working ..
                        Pulse-type filament monitor on pin e0stop, enabled, sensitivity 0.124mm/pulse, allowed movement 50% to 200%, check every 3.0mm, measured sensitivity 0.124mm/pulse, measured minimum 74%, maximum 117% over 3091.4mm
                        so if PA is not reversing everything is ok. the 0% minimum was a hardware failure (fixed :D)
                        so def makes sense to add a converter to convert quadrature output to the position data to send like those smart sensors
