Homing advice
3.0k
    agent0810 @Phaedrux
    @Phaedrux
    alright so it helps if i actually make the changes you want. after i re-did the changes you want the homing works fine now AND THE BED STAYS UP when i send a print. The extruder is still crashing into the stops right away when i send a print job and i dont have any fillament coming out yet.
    PROGRESS 🙂
    Should i swap the fan to an always on port?
    undefined 1 Reply Last reply 8 Jul 2020, 17:23 Reply Quote 0
      agent0810
      So when i home it, x and y go to 225 and z goes to 0. but if i want -z to go down shouldnt 0 be at the bottom? how would i swap that around, change the motor direction like you suggested in your last post?
        Phaedrux Moderator @agent0810
        @agent0810 said in Homing advice:
        No, swap the hotend fan and the part cooling fan plugs.
        No, 0 is when the nozzle is touching the bed and +Z means the bed is going down as the print gets taller. It's a bit different with a bed that moves in Z as opposed to a bed that stays put and the nozzle raises. But think of it as the print gets bigger as the nozzle and bed get further apart. The print starts at 0 and grows.
        So the print head isn't moving around the center area of the bed? But you can jog the print head around the entire bed area without problem?
        Double check your extruder wiring. Which driver are you connected to?
        If you remove your filament and then send M302 P1 to allow cold extrusion you should then be able to use the extrusion dialogue to move the extruder motor back and forth. Does that work?
        undefined 2 Replies Last reply 8 Jul 2020, 17:51 Reply Quote 0
          agent0810 @Phaedrux
          @Phaedrux
          swapped the fan plugs and now the front one is on.
          so when i do home all, everything goes to where it is supposed to but the z is at 0 at the top, so it cant go lower right? shouldnt it home at 300 something? im having issues moveing the bed.
          when i send a print the print head crashes for a bit, then it goes around like its printing but no fillament comes out.
          Ran the M302 P1 and nothing happened.
            agent0810 @Phaedrux
            @Phaedrux
            when i hit z+ it tries to go up right now, and its already at the top from homing.
              +Z should move the bed down. If that's not the case, we need to change the direction of rotation of the z motor like we did with the X Y.
              ;drives
              Change that to S0 and test again that +z moves the bed down.
              That could just be it homing again because there is a G28 in the start gcode. If it's already at the endstops it will back off slightly and then home again. Then it will try and do the prime line part, and then start the print. So as long as it ends up moving around the center area of the bed I think that's ok.
              Ok we need to see if the extruder motor is actually working. After you send M302 P1 that allows the extruder motor to move without being heated up. So if you have removed the filament you should be able to test the motor by sending extrude commands from the web interface.
              undefined 1 Reply Last reply 8 Jul 2020, 18:18 Reply Quote 0
                agent0810 @Phaedrux
                @Phaedrux
                the extrude and retract buttons are greyed out on the web interface even after the M302 P1 command 😞
                  How bout if you heat up the hotend to 180?
                  undefined 3 Replies Last reply 8 Jul 2020, 18:29 Reply Quote 0
                    agent0810 @Phaedrux
                    @Phaedrux got it up to 160 and now i can retract and extrude
                      agent0810 @Phaedrux
                      @Phaedrux
                      M120 M83 G1 E10 F300 M121
                      Warning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater fault
                        agent0810 @Phaedrux
                        @Phaedrux
                        at 180 seems to be working. i can see it moving
                          Alright, so at least we know the extruder is moving and extruding now.
                          Next you should go through the extruder calibration to set the correct steps per mm.
                          https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40#s165
                          undefined 1 Reply Last reply 8 Jul 2020, 18:56 Reply Quote 0
                            agent0810 @Phaedrux
                            @Phaedrux said in Homing advice:
                            so retract is pushing out filament and extrude is pulling it back......
                              In that case we must change the motor direction once again
                              Change S1 to S0
                              undefined 2 Replies Last reply 9 Jul 2020, 13:20 Reply Quote 0
                                agent0810 @Phaedrux
                                @Phaedrux
                                I was able to print! My temp tower didn’t come out so hot though. What sorta things do I need to look into to fix?
                                  agent0810 @Phaedrux
                                    Now that you have things working somewhat, you should go through the following guides to confirm correct operation and then do some calibration steps.
                                    https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+3:+Commissioning/39
                                    And
                                      agent0810
                                      Went through them both and it helped a bunch but I feel like there is still some room for improvement. Thoughts?
                                        https://forum.duet3d.com/topic/14250/tuning-jerk-accel-speed-settings/2?_=1594350237285
                                        55 out of 64
