    Bltouch setup need help
    Firmware installation
    3.9k
    • Elvis0zundefined
      Elvis0z
      Hey guys need help to set this up its a v1.0 bltouch. It does deploy and retract when I power on the printer which is a Tevo Black Widow. I have x and y homing just need help to set up the bltouch. Here is my config.g. This was partially set up by some one else with a black widow. They have an ir sensor for bed leveling. I'm on firmware v3.11
      ; generated by RepRapFirmware Configuration Tool v3.1.3 on Tue Jun 09 2020 17:58:51 GMT-0700 (Mountain Standard Time)
      M550 P"Elvis Oz Tevo Black Widow" ; set printer name
      ;M551 P"" ; set password
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S1 ; enable FTP
      M586 P2 S0 ; disable Telnet
      M569 P1 S0 ; physical drive 1 goes forwards
      M569 P3 S0 ; physical drive 3 goes forwards
      M92 X80.00 Y80.00 Z1600.00 E400.00 ; set steps per mm
      M566 X500.00 Y500.00 Z18.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E6000.00 ; set maximum speeds (mm/min)
      M201 X1000.00 Y1000.00 Z100.00 E1000.00 ; set accelerations (mm/s^2)
      M906 X1300 Y1300 Z1200 E1300 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X360 Y230 Z280 S0 ; set axis maxima
      M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin xstop
      M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin ystop
      ; Elvis, The following Z-Probe below is where you will have to configure your BLTouch
      M558 P5 H5 F500 T4000 X0 Y0 Z1 ; Set Z probe type/mode 5. H=Dive Height. F=Speed the bed moves
      G31 P9 X+41 Y+10 Z0.0 ; set Z probe trigger value, offset and trigger height
      M557 X25:360 Y15:220 S20 ; define mesh bed level
      M307 H0 A346.2 C140 D5.3 B0 S2.0 V23.8 ; enable bang-bang mode for the bed heater and set PWM limit
      ;M307 H0 B1 S1.00 ; Previous Command
      M308 S1 P"spi.cs1" Y"rtd-max31865" ; configure sensor 1 as thermistor on pin e0temp
      M307 H3 A-1 C-1 D-1 ; Disable the 3rd Heater to free up PWM channel
      M106 P0 S0.5 H1 T45 ; Elvis, The S0.5 is setup for a 12V Fan, set fan 0 value. Thermostatic control is turned off
      M106 P1 S0.20 H-1 ; Elvis, The 0.20 is setup for a 5V Fan, set fan 1 value. Thermostatic control is turned on
      G10 P0 X0 Y0 Z0.0 ; set tool 0 axis offsets
      M575 P1 S1 B115200 ; Elvis, Go into the setup of your PanalDue and set the baud rate to 115200, enable support for PanelDue
      JoergS5undefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
      • JoergS5undefined
        JoergS5 @Elvis0z
        @Elvis0z you need to set M558 to P9 and add a M950 after it. Please see https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Software_setup_RepRapFirmware_Num_3 as first info. The bltouch is the first version, you may need to change voltage level from 5 to 3.3 volt. There is information on antclabs and this forum about how to adapt.
        • Elvis0zundefined
          Elvis0z
          Thanks JoergS5
          I get this error when I try to home all x and y home z does not
            Please send M115 and verify that you have 3.1.1 installed.
            Post your homeall as well.
            What pins are you connecting the BLtouch to? The servo pin must be defined in M950.
            The deploy and retract probe macros will need to be created as well.
            If this is a recent Duet wifi you shouldn't have to do anything special for 5v versus 3.3v
            • Elvis0zundefined
              Elvis0z
              M115=FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.1.1 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-05-19b2
              homeall=
              ; homeall.g
              ; called to home all axes
              ; generated by RepRapFirmware Configuration Tool v3.1.3 on Tue Jun 09 2020 17:58:52 GMT-0700 (Mountain Standard Time)
              G91 ; relative positioning
              G1 H1 X-235 Y-215 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
              G1 H2 X5 Y5 F6000 ; go back a few mm
              G1 H1 X-235 Y-215 F360 ; move slowly to X and Y axis endstops once more (second pass)
              G90 ; absolute positioning
              G1 X15 Y15 F6000 ; go to first bed probe point and home Z
              ;G91 ; relative positioning
              ;G90 ; absolute positioning
              Wiring is set up like this
                @Elvis0z said in Bltouch setup need help:
                Should be:
                M950 S0 C"exp.heater3"
                M558 P9 C"^zprobe.in" H5 F60 T6000 A10 R0.5
                G31 P25 X+41 Y+10 Z0.0 ; set Z probe trigger value, offset and trigger height
                Then in your deploy and retract macros you need
                ; retractprobe.g
                ; Probe retraction routine for BLTouch-Smart on DBot
                M280 P0 S90
                ; deployprobe.g
                ; Probe deployment routine for BLTouch-Smart on DBot
                M280 P0 S10		; Set servo position to deploy
                And for your homeall you should place the probe in the center of the bed with something like this. You'll have to measure,
                G1 X150 Y150 F6000 ; go to first bed probe point and home Z
                  And take a look at this if you haven't.
                  https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
                  • Elvis0zundefined
                    Elvis0z
                    G28
                    Error: G0/G1: insufficient axes homed
                    Got this error when trying to home z
                    Hotend moved a bit then bltouch pin deployed and it stopped. Red light went off and some noise maybe motor, not sure
                    • JoergS5undefined
                      JoergS5 @Elvis0z
                      @Elvis0z when you try to homez, the homez.g is called and executed, please publish it for check. For homing all axes, run homeall.g
                      • Elvis0zundefined
                        Elvis0z
                        Here is homez
                        ; homez.g
                        ; called to home the Z axis
                        ; generated by RepRapFirmware Configuration Tool v3.1.3 on Tue Jun 09 2020 17:58:53 GMT-0700 (Mountain Standard Time)
                        G1 X15 Y15 F6000 ; go to first probe point
                        • JoergS5undefined
                          JoergS5 @Elvis0z
                          @Elvis0z this is ok. And sorry, I misread, G28 calls homeall.g, my mistake, does not call homez
                          I'll recheck your config, whether I see something. You could try exchanging M558 and M950, M558 first for the zprobe definition.
                          You should check
                          whether the Z is correct. Please check https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Calibrate_the_Z_probe_trigger_height
                          • Elvis0zundefined
                            Elvis0z
                            Swapped
                            M558 and M950
                            hotend goes to middle of the bed and deploys probe then probe swiches off I think
                            cheers for the help guys
                            • JoergS5undefined
                              JoergS5 @Elvis0z
                              @Elvis0z you should check G31 Z value also, please see my last post above.
                              In homeall I would move the hotend to the middle of the bed before probing Z, instead G1 X15 Y15 F6000 I would call
                              G1 X100 Y100 F6000
                              to be sure you don't probe outside of the bed one day and not triggering (when bed or endstop moved a bit eg).
                              • Elvis0zundefined
                                Elvis0z
                                This was the last error
                                G28
                                Error: Z probe was not triggered during probing move
                                Error: Homing failed
                                • JoergS5undefined
                                  JoergS5 @Elvis0z
                                  @Elvis0z was your bltouch over the bed and was it deployed?
                                  Elvis0zundefined 1 Reply Last reply Reply Quote 0
                                  • Elvis0zundefined
                                    Elvis0z @JoergS5
                                    @JoergS5 Yes
                                    • Elvis0zundefined
                                      Elvis0z
                                      M401
                                      M402
                                      Both these commands work
                                      • JoergS5undefined
                                        JoergS5 @Elvis0z
                                        @Elvis0z did it have a bit of distance to the bed? There are some documentation to the installation. The Z height in reference to the nozzle is important.
                                        The image right lower on page 1 in the https://locxess.de/3d/BLTouch_Anleitung_englisch.pdf
                                        document, the 8mm.
                                        • Elvis0zundefined
                                          Elvis0z
                                          Yep it probes way above the bed.
                                          • JoergS5undefined
                                            JoergS5 @Elvis0z
                                            @Elvis0z can you please republish config and homeall like it is now, so I can recheck?
