    i hate upgrades
    Duet Web Control
    1.1k
      A Former User @kostasbmw
      @kostasbmw there should be a zip file for each major release, you can upload this as a whole and DuetWebControl will decompress and place the files where needed and prompt you to start the upgrade after.
      • kostasbmwundefined
        kostasbmw
        ok i got it but then i lost connection i cant see the printer...should i get the sd out and check?
        WIFI is on and i cant find the ip address with angry ip scanner..the printer is a ufo
        YAT connected but here is the result when trying to input the data
        m552
        WiFi module is being started
        ok
        m552 s0
        ok
        m587 s"KOSTASBMWX3" P"91171917"
        Error: M587: Failed to add SSID to remembered list
        ok
        M552 S1
        Turn off the current WiFi mode before selecting a new one
        ok
          kostasbmw
          can i reset the duet to factory and start again from the begining....
            jay_s_uk
            Easiest is wipe the SD card as no information is stored on the duet (apart from wifi information on the ESP module).
            Or if you're not happy with that, BOSSA the duet and reflash the wifi firmware
            https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Fallback_procedure_Num_3
            • jens55undefined
              jens55
              I ran into connectivity issues like you are having.
              The things I needed to do are as follows:
              m552 s-1 ; disable wifi module
              g4 s1 ;pause
              m552 s0 ; disable network
              G4 S1 ;pause
              m588 s"*" ; forget all networks
              G4 S1 ; pause
              m587 s"---------" P"===========" ; set new network
              The pauses are probably not needed if you are typing the stuff in on the console but you do need to disable the wifi module before you can ask it to remember a new network.
              kostasbmwundefined 1 Reply Last reply Reply Quote 1
                A Former User
                Duets are not shipped "factory reset"; that would mean its blank, with no firmware due to the nature of the microcontroller used. So Duets have the firmware flashed and SD card populated with a default config on top of a reset state.
                IF you send M999 P"ERASE" or place a jumper over the erase pins on the board it will be the cloest you get to resetting it - but that also renders it useless until you perform Fallback procedure #3 you probably have to update DuetWebControl on the SD card as well.
                To reset the WiFi module send M552 S-1 M552 S0 M588 S"*"
                The only thing you achieve by resetting the board is solving any problems related to not following the instructions given here Section_Special_considerations_for_upgrading_between_particular_firmware_versions so I would perhaps suggesting an alternative approach as there is no going back after you erase the board, except the fallback procedure linked above.
                kostasbmwundefined 1 Reply Last reply Reply Quote 0
                  kostasbmw @jens55
                  @jens55 said in i hate upgrades:
                  g4 s1 ;pause
                  G4 S1 ;pause
                  G4 S1 ; pause
                  I GET A FAILED TO RESET THE WIFI MODULE
                    kostasbmw @A Former User
                    @bearer
                    i followed instructions ..i missed one to uncomment the m552 s1
                    the thing is to reset the wifi because without it nothing to do......
                    i dont know if i can do something through the sd card
                      @kostasbmw said in i hate upgrades:
                      WiFi Server Version: 1.21
                      did you upgrade this along the way?
                      download and place DuetWiFiServer.bin (v1.23) on the sd-card in the /sys folder and run
                      M552 S0
                      M997 S1
                      M588 S"*"
                      confirm the updated version and a blank wifi module with
                      M122
                      M587
                        @bearer said in i hate upgrades:
                        M552 S0
                        M997 S1
                        M588 S"*"
                        M122
                        M587
                        m552 s0
                        ok
                        m997 s1
                        Trying to connect at 230400 baud: success
                        Erasing 4096 bytes...
                        Erasing 212992 bytes...
                        Uploading file...
                        5% complete
                        10% complete
                        15% complete
                        20% complete
                        25% complete
                        30% complete
                        35% complete
                        40% complete
                        45% complete
                        50% complete
                        55% complete
                        60% complete
                        65% complete
                        70% complete
                        75% complete
                        80% complete
                        85% complete
                        90% complete
                        95% complete
                        Upload successful
                        ok
                        m588 s"*"
                        Error: M588: Failed to reset the WiFi module to factory settings
                        ok
                        m122
                        RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later + DueX2
                        Board ID: 08DGM-917NK-F2MS4-7JKFD-3S46R-1HSDD
                        Used output buffers: 1 of 24 (1 max)
                        Static ram: 27980
                        Dynamic ram: 93324 of which 680 recycled
                        Exception stack ram used: 320
                        Never used ram: 8768
                        Tasks: NETWORK(ready,396) HEAT(blocked,1456) DUEX(suspended,160) MAIN(running,1816) IDLE(ready,80)
                        Owned mutexes:
                        Last reset 00:02:20 ago, cause: power up
                        Last software reset at 2020-07-08 18:20, reason: User, spinning module GCodes, available RAM 11452 bytes (slot 2)
                        Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
                        Error status: 0
                        MCU temperature: min 25.7, current 30.4, max 30.5
                        Supply voltage: min 23.9, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
                        Driver 5: standstill, SG min/max not available
                        Driver 6: standstill, SG min/max not available
                        Cache data hit count 263916142
                        Slowest loop: 9.65ms; fastest: 0.14ms
                        === Storage ===
                        Free file entries: 10
                        SD card longest read time 3.1ms, write time 0.0ms, max retries 0
                        Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
                        === MainDDARing ===
                        Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                        === AuxDDARing ===
                        Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
                        Segments left: 0
                        Movement lock held by null
                        HTTP is idle in state(s) 0
                        Telnet is idle in state(s) 0
                        File is idle in state(s) 0
                        USB is ready with "m122" in state(s) 0
                        Aux is idle in state(s) 0
                        Trigger is idle in state(s) 0
                        Queue is idle in state(s) 0
                        Daemon is idle in state(s) 0
                        Code queue is empty.
                        === Network ===
                        Slowest loop: 1193.73ms; fastest: 0.00ms
                        HTTP sessions: 0 of 8
                        • WiFi -
                          Network state is disabled
                          WiFi module is disabled
                          === DueX ===
                          Read count 1, 0.43 reads/min
                          ok
                          m587
                          Error: M587: Failed to retrieve network list
                          ok
                          m552
                          ok
                          m552 s0
                          ok
                          WiFi module started
                          this is what i get with m587
                          If you send M552 S0, and then M552 by itself a few seconds later, what does it report?
                            kostasbmw
                            ok i left it and now when i turned the printer on it connected but i got an error telling me to reload the web interface again
                            JavaScript Error
                            A JavaScript error has occurred so the web interface has closed the connection to your board. It is recommended to reload the web interface now. If this happens again, please contact the author and share this error message:
                            Version: 1.22.6
                            Message: Uncaught TypeError: Cannot read property 'toFixed' of undefined
                            URL: http://192.168.1.5/js/dwc.js
                            Line: 4468:75
                            Error object: {}
                            A Former User? dc42undefined 2 Replies Last reply Reply Quote 0
                              Version: 1.22.6
                              you should probably update this as well
                              https://github.com/Duet3D/DuetWebControl/releases/tag/3.1.1
                              https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Updating_DuetWebControl_files
                                dc42 administrators @kostasbmw
                                JavaScript Error
                                Version: 1.22.6
                                Line: 4468:75
                                Error object: {}
                                If you are running RRF 3.1.1 on the main board (which you are according to the M122 report), then you need to run a later version of Duet web Control than 1.22.6.
                                Edit : @bearer beat me to it.
                                  kostasbmw @dc42
                                  i m trying to locate my version on the dwc
                                  i reloaded the the files in the www folder and no error
                                  should i reflash with the firmware????
                                  my m122
                                  m122
                                  SENDING:M122
                                  Used output buffers: 1 of 24 (10 max)
                                  Static ram: 27980
                                  Exception stack ram used: 308
                                  Never used ram: 8780
                                  Tasks: NETWORK(ready,468) HEAT(blocked,1456) DUEX(suspended,160) MAIN(running,1824) IDLE(ready,80)
                                  Owned mutexes: WiFi(NETWORK)
                                  Last reset 00:03:40 ago, cause: power up
                                  Error status: 0
                                  [ERROR] Error status: 0
                                  MCU temperature: min 25.0, current 31.2, max 31.4
                                  Supply voltage: min 23.9, current 24.0, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
                                  Date/time: 2020-07-09 17:52:14
                                  Cache data hit count 372512281
                                  Slowest loop: 9.67ms; fastest: 0.13ms
                                  === Storage ===
                                  === MainDDARing ===
                                  === AuxDDARing ===
                                  Segments left: 0
                                  USB is ready with "M122" in state(s) 0
                                  === Network ===
                                  Slowest loop: 39.96ms; fastest: 0.00ms
                                  HTTP sessions: 1 of 8
                                  • WiFi -
                                    Network state is active
                                    WiFi firmware version 1.23
                                    WiFi MAC address 84:f3:eb:83:44:a8
                                    WiFi Vcc 3.38, reset reason Unknown
                                    WiFi flash size 4194304, free heap 24632
                                    WiFi IP address 192.168.1.5
                                    WiFi signal strength -48dBm, reconnections 0, sleep mode modem
                                    === DueX ===
                                    Read count 1, 0.27 reads/min
                                  and this is what the dwc says
                                  Board: Duet 2 WiFi (2WiFi)
                                  Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.1.1 (2020-05-19b2)
                                  Duet WiFi Server Version: 1.23
                                    A Former User
                                    M122 will not show DWC version, but you have DWC 1.22.6 and RRF 3.1.1.
                                    So you need to also have DWC 3.1.1 which I linked to above. The second link has the instructions on how to extract it to the sd card as DWC is not currently working you need to put the sd card in your computer temporarily.
                                    edit: oh, i took the error to mean dwc didn't work, pardon the detour.
                                      @bearer
                                      it works i putted the folder files mannually in the sd
                                        As you have established communication using DWC, you can just upload the version 3.1.1 DuetWebControl.zip file through the DWC Upload System Files button.
                                          kostasbmw @dc42
                                          just finished and i get
                                          i hope its ok now
                                            The DWC version can also be found in the settings page of DWC.
