    Turning on fan on temperature reached
    • knokerundefined
      knoker
      I am configuring a duet3 and I have a 2 wire hotend fan on OUT7.
      I am trying to get it to turn on only when the hotend reaches 45degrees, but that is not happening.
      Here's my config.g
      G90                                          ; send absolute coordinates...
      M83                                          ; ...but relative extruder moves
      M550 P"Duet 3"                               ; set printer name
      M669 K1                                      ; select CoreXY mode
      M569 P0.0 S0                                 ; physical drive 0.0 goes backwards
      M569 P0.1 S0                                 ; physical drive 0.1 goes backwards
      M569 P0.4 S0                                 ; physical drive 0.4 goes forwards
      M569 P0.5 S0                                 ; physical drive 0.5 goes forwards
      M569 P0.3 S1                                 ; physical drive 0.3 goes forwards
      M584 X0.0 Y0.1 Z0.4:0.5 E0.3                     ; set drive mapping
      M350 X16 Y16 Z16 E16 I1                      ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z400.00 E420.00            ; set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00          ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00      ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E250.00          ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800                     ; set motor currents (mA)
      M84 S0                                       ; Disable motor idle current reduction
      M208 X0 Y0 Z0 S1                             ; set axis minima
      M208 X230 Y210 Z200 S0                       ; set axis maxima
      M574 X1 S1 P"!^io1.in"                       ; configure active-high endstop for low end on X via pin !^io1.in
      M574 Y1 S1 P"!^io0.in"                       ; configure active-high endstop for low end on Y via pin !^io0.in
      M574 Z1 S2                                   ; configure Z-probe endstop for low end on Z
      M950 S0 C"io7.out"                           ; create servo pin 0 for BLTouch
      M558 P9 C"^io7.in" H5 F120 T6000             ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X37 Y-25 Z3                         ; set Z probe trigger value, offset and trigger height
      M557 X15:215 Y15:195 S20                     ; define mesh grid
      M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
      M950 H0 C"out0" T0                           ; create bed heater output on out0 and map it to sensor 0
      M307 H0 A81 C106.8 D0.9 S1.0 V24.0 B0		 ; enable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                      ; map heated bed to heater 0
      M143 H0 S120                                 ; set temperature limit for heater 0 to 120C
      M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
      M950 H1 C"out1" T1                           ; create nozzle heater output on out1 and map it to sensor 1
      M307 H1 B0 S1.00                             ; disable bang-bang mode for heater  and set PWM limit
      M950 F0 C"out7" Q100                     	; create fan 0 on pin out7 and set its frequency
      M106 P0 S0 H1 T45                            ; set fan 0 value. Thermostatic control is turned on
      M950 F1 C"out8" Q500                         ; create fan 1 on pin out8 and set its frequency
      M106 P1 S1 H-1                               ; set fan 1 value. Thermostatic control is turned off
      M563 P0 S"e0" D0 H1 F1                       ; define tool 0
      G10 P0 X0 Y0 Z0                              ; set tool 0 axis offsets
      G10 P0 R0 S0                                 ; set initial tool 0 active and standby temperatures to 0C
      A big part of the code was generated in the configuration wizard.
      Any Ideas?
      Thank you
      aidarundefined 1 Reply Last reply Reply Quote 0
      • aidarundefined
        aidar @knoker
        @knoker Try M106 P0 S1 H1 T45
        knokerundefined 1 Reply Last reply Reply Quote 1
        • knokerundefined
          knoker @aidar
          @aidar I realize the mistake now... I was setting the speed to 0 when it reached 45º....
          I'm not sure if I changed that or I pasted it directly from the config ui....
          Well, solved thanks a lot 🙂
