    attempting reconnect though it connected
    Duet Web Control
    • jrohundefined
      jroh
      DWC shows below alert blinking every around 0.1seconds and then becomes uncontrollable status though it's connected(buttons are working but refreshing every 0.1seconds due to reconnection). It happened after I restarted the system after changing config.g file. Tried to use various method to fix but still not working.
      alert : connection lost. attempting reconnect.
      Console : Connection interrupted, attempting to reconnect... Unexpected token a in JSON at posion 560
      Could anyone help to solve this problem?
      I'm using DUET2WIFI with DUEX5 for 4 extruders for 4color mixed nozzle and I just found there is some error on M567 according to M588(diagnose) but I don't know what's error.
      Configuration is as follows.
      M83
      M552 S1
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      ; ...but relative extruder moves
      M569 P1 S0 ; physical drive 1 goes forwards
      M569 P3 S0 ; physical drive 3 goes forwards
      M569 P4 S0 ; physical drive 4 goes forwards
      M569 P5 S1 ; physical drive 5 goes forwards
      M569 P6 S1 ; physical drive 6 goes forwards
      M569 P7 S1 ; physical drive 7 goes forwards
      M569 P8 S1 ; physical drive 8 goes forwards
      M569 P9 S0 ; physical drive 9 goes forwards
      M584 X9 Y2 Z0:1:3:4 E5:6:7:8 ; set drive mapping
      M350 X16 Y16 Z16 E8:8:8:8 I1 ; configure microstepping with interpolation
      M92 X106.67 Y106.67 Z800.00 E984.00:984.00:984.00:984.00 ; set steps per mm
      M566 X1200.00 Y1200.00 Z100.00 E3600.00:3600.00:E3600.00:3600.00 ; set maximum instantaneous speed changes (mm/min) jerk
      M203 X36000.00 Y36000.00 Z2400.00 E3600.00:3600.00:3600.00:3600.00 ; set maximum speeds (mm/min)
      M201 X3000.00 Y3000.00 Z200.00 E3600.00:3600.00:3600.00:3600.00 ; set accelerations (mm/s^2)
      M906 X1500 Y1500 Z1500 E450:450:450:450 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X450 Y450 Z650 S0 ; set axis maxima
      M307 H7 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
      ;M558 P9 F100 H5 R0.2 T6000 A2 B1 ; set Z probe type to bltouch and the dive height + speeds
      M558 P9 X0 Y0 Z1 F300 T6000 H5
      G31 P25 X16 Y10 Z3.95 ; set Z probe trigger value, offset and trigger height
      M557 X50:400 Y50:400 S50 ; define mesh grid
      M280 P7 S160
      M669 K0 ; CARTESIAN
      M671 X-70:545:545:-70 Y-80:-80:615:615 S10
      M305 P0 T100000 B3950 R4700 ; set thermistor + ADC parameters for heater 0
      M305 P1 T100000 B3950 R4700 ; Set thermistor + ADC parameters for heater 1
      ;Sensor
      ;M591 D0 P2 C3 S1
      ;M591 D1 P2 C4 S1
      ;M591 D2 P2 C5 S1
      ;M591 D3 P2 C6 S1
      M568 P0 S1
      M567 P0 E0.94:0.02:0.02:0.02
      M563 P1 D1 H1 F0 ; define tool 1
      M568 P1 S1
      M567 P1 E0.02:0.94:0.02:0.02
      M563 P2 D2 H1 F0 ; define tool 0
      G10 P2 X0 Y0 Z0 ; set tool 0 axis offsets
      G10 P2 R0 S0
      M568 P2 S1
      M567 P2 E0.02:0.02:0.94:0.02 ; set initial tool 0 active and standby temperatures to 0C
      M563 P3 D3 H1 F0 ; define tool 1
      G10 P3 X0 Y0 Z0 ; set tool 1 axis offsets
      G10 P3 R0 S0
      M568 P3 S1
      M567 P3 E0.02:0.02:0.02:0.94
        See the note on M568 being deprecated.
        https://duet3d.dozuki.com/Wiki/Gcode#Section_M568_Turn_off_on_tool_mix_ratios
        @jroh said in attempting reconnect though it connected:
        What did you change?
        What firmware version are you using? What version of DWC are you using?
        jrohundefined 1 Reply Last reply Reply Quote 0
        • jrohundefined
          jroh @Phaedrux
          @Phaedrux
          Thanks for reply. I'm using below.
          ; generated by RepRapFirmware Configuration Tool v2.1.8 on Mon Mar 30 2020
          I tried testing two DWC version such as DuetWebControl-SD-3.1.1 and also old version but same alert happens. I changed below.
          I largely expanded maximum speed and acceleration and jerk and then removed decimal numbers(ex : M203 X36000 removed .00 now returned as 36000.00 as above but still same).
          Tried remove M552 S1 then it was not connected network so revived.
          Machine is working if I press "Home All" button but cannot edit system file as it refreshes continuously.
            I'm not really sure what could be going on. But I think maybe there is a version mis match. You haven't actually said what version of firmware and DWC you are using, but I suggest that you try upgrading to version 3.0 and then 3.1.1. Use the web config tool to get a fresh config set for v3.
