    Smart effector flashes 7 times repeatedly.
    Smart effector for delta printers
    545
    • Tinywookieundefined
      Tinywookie
      I've tried researching this but cant find anything online other then what the 7 flashes means.
      I have a rostock max v2 and just added a duet 2 board and smart effector to it. The duet board seems to work fine, all the towers move and the heaters and fans all seem to work, but the smart effector just flashes at me. I tried the initial test of tapping the end and seeing if it flashes and that's when I noticed that its just flashing 7 times, pausing, then flashing 7 times again. This goes on for at least ten minutes which is how long I left it seeing if it would reset. I tried powering off and back on a few times as well as checking all the wires are providing current. I also disconnected the heater and fans to see if it was something wrong there and I still just get the 7 flashes. What are some trouble shooting steps I can preform?
      Not sure what other pieces of info would help.
      Parts:
      Rostock max v2 printer
      12v 29a meanwell powersupply
      panel 5i
      Duet 2 wifi
      smart effector
      12v 40w heater cartridge
      generic thermistor
      0.9 degree m3d stepper motors
      bondtech extruder
      onyx v7 heated bed
      ninja sticker
      • aidarundefined
        aidar
        From wiki : Codes 6 and 7 should normally indicate damage to the strain gauge traces.
        So you may need new effector.
          Tinywookie
          I saw that but I didn't see any trouble shooting steps. My assumption is I have something wrong since it hasn't worked out of the box.
            Can you post a close up photo of both sides of the effector?
              Tinywookie
              Here is the front and back.
                Thanks. How old is the Smart Effector and where was is purchased?
                  Tinywookie
                  I ordered it on June 2nd from Filastruder.
                    Please contact Filastruder and initiate a warranty replacement. Refer them to this thread as authorization.
                    The traces of the strain gauge are quite delicate so be sure to be careful during installation.
                      Tinywookie
                      kk, thanks.
                      • CoolioXundefined
                        CoolioX
                        @Phaedrux -- I have recently purchased a few smart effectors and without fail I have 3 of these that are flashing 7 times. I do have one that does work, so I'm pretty sure it's not anything having to do with the external set ups, but it seems strange to me that a bunch of them would have the same issue?
                        For reference, where are the strain gauge traces?
                        CoolioXundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                        • CoolioXundefined
                          CoolioX @CoolioX
                          Adding photos for reference here:IMG_7779.jpeg ![IMG_7443.jpeg]
                          IMG_4005.jpeg IMG_6008.jpeg IMG_3235.jpeg (/assets/uploads/files/1594694592247-img_4005-resized.jpeg) IMG_0131.jpeg IMG_7443.jpeg IMG_0635.jpeg IMG_3161.jpeg
                            Phaedrux Moderator @CoolioX
                            @CoolioX said in Smart effector flashes 7 times repeatedly.:
                            Hi, please create a new thread with your issue for the sake of clarity.
