    Need help to config file for ender 3 pro
    1.7k
    • Roei3dundefined
      Roei3d @Phaedrux
      @Phaedrux https://youtu.be/nBy0lpH--Uk
      In cylinder I hardly see anything.
        Try lowering the acceleration and jerk for the Y axis. Perhaps the big heavy mirror is making it shake on direction changes.
        Roei3dundefined 1 Reply Last reply Reply Quote 0
        • Roei3dundefined
          Roei3d @Phaedrux
          @Phaedrux yaaaaaaaa I fix it thnks for your help. My hotend and cooling part fan was Vibrates slightly
          It's due to their frequency settings.
          I couldn't find a frequency that would make them stop vibrating.
          So I returned to ender 3 stock fun and changed frequency now Hard to see ringing Thank you so much for your time and for your help.
          And everyone who helped
          You think I should change my config like before?
          Phaedruxundefined bettodiazundefined 2 Replies Last reply Reply Quote 0
            Phaedrux Moderator @Roei3d
            @Roei3d said in Need help to config file for ender 3 pro:
            Well you can try increasing your speed values as part of your tuning.
            Maybe see here: https://forum.duet3d.com/topic/14250/tuning-jerk-accel-speed-settings/3
            • Roei3dundefined
              Roei3d @Phaedrux
              @Phaedrux thnks my last print look very good thnks for your help
              ihave problem whit my duet web when irun macro iget blank status i seeblank.jpeg only "ok"
              if change to dwc1 isee all' how to fix it ?
                @Roei3d Are you running Firmware 3.1.1 and DWC 3.1.1 now? If you're still running firmware 2.x you either need to upgrade to 3.1.1 or change your DWC version to something like 2.0.7 that came with firmware 2.05.1
                • Roei3dundefined
                  Roei3d @Phaedrux
                  @Phaedrux yes iam ruining
                  RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
                  so ineed to upgrade my firmware to 3 ?
                  or downgrade swc to 2.0.7?
                    Yes. First I would try just uploading the 2.0.7 DWC zip file and see if you still have the problem. Updating to RRF3 is a bit more involved and would require updated config.g. By contract, changing the DWC version is as easy as uploading the version you want to try.
                    https://github.com/Duet3D/RepRapFirmware/releases/download/2.05.1/DuetWebControl-SD-2.0.7.zip
                    Roei3dundefined 2 Replies Last reply Reply Quote 0
                    • Roei3dundefined
                      Roei3d @Phaedrux
                      @Phaedrux great thanks i try now
                      • bettodiazundefined
                        bettodiaz @Roei3d
                        @Roei3d Hello! Are you using the stock fans? What are the frequency values that you are using now? Could you please share your current config.g? Thanks!
                        • Roei3dundefined
                          Roei3d @bettodiaz
                          @bettodiaz hii yes now ihave tock fun only the board fun i change
                          this my config
                          M569 P0 S0 ; physical drive 0 goes backwards
                          M92 X79 Y79 Z396 E408 ; set steps per mm
                          M566 X1000 Y1000 Z24 E2500 P1 ; set maximum instantaneous speed changes (mm/min)
                          M203 X6000 Y6000 Z900 E6000 ; set maximum speeds (mm/min)
                          M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
                          M906 X688 Y688 Z688 E810 I30 ; set motor currents (mA) and motor idle factor in per cent
                          M84 S30 ; Set idle timeout
                          M208 X235 Y235 Z240 S0 ; set axis maxima
                          ; Filament runout sensor ;Filament run-out sensor triggers a pause
                          M591 D0 P2 C3 S1
                          M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
                          M558 P9 H2.5 F350 T6000 ; set Z probe type to bltouch and the dive height + speeds
                          G31 P500 X-40 Y-12 Z9.562 ; set Z probe trigger value, offset and trigger height
                          M557 X30:220 Y30:220 S40 ; define mesh grid
                          M305 P0 T98801 B4185 R4700 ; Set thermistor + ADC parameters for heater 0
                          M143 H0 S100 ; Set temperature limit for heater 0 to 120C
                          M305 P1 T98801 B4185 R4700 ; Set thermistor + ADC parameters for heater 1
                          M143 H1 S250 ; Set temperature limit for heater 1 to 280C
                          M106 P0 S0 I0 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                          M106 P1 S0 I0 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                          M106 P2 S0.8 I0 F20 H1:0 T45 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
                          M563 P0 S"hotend" D0 H1 F0 ; define tool 0
                          ; Pressure Advance
                          M572 D0 S0.35
                          M501 ; Load saved parameters from non-volatile memory
                          T0 ; Select first tool
                          ; BLTouch startup
                          G4 S2 ; Pause a couple seconds
                          M280 P64 S160 ; Clear any alarms
                          M402 ; retract pin just in case
                          • Roei3dundefined
                            Roei3d @Phaedrux
                            @Phaedrux you are the king of duet work great thnks 👍👑
