    FT-5 wiring question
    1.3k
    • Texzinundefined
      Texzin
      The FT-5 has 2 y motors. What is best use the one y driver on the board or add a expansion board for second motor?
      • elmoretundefined
        elmoret
        There's a stepper driver that has two connections, you could use that driver for Y.
        You could also connect the steppers in series, and connect them to a single port. Or you could assign them to two different stepper drivers, since there's a total of 5 on the board. Z, Y1, Y2, X, E.
        • iDeveloundefined
          iDevelo
          Heres what I use
          M584 X0 Y1:4 Z2 E3                             ; Map to specific drives
          M569 P0 S0                                     ; Drive 0 - X
          M569 P1 S0                                     ; Drive 1 - Y
          M569 P2 S1                                     ; Drive 2 - Z
          M569 P3 S0                                     ; Drive 3 - E0
          M569 P4 S1                                     ; Drive 4 - Y
          • Texzinundefined
            Texzin
            The Folger Tech FT-5 has 2z , 2y, 1x. So if I just use the Duetwifi with out the Duex2/5 I will have to connect the Y steppers in series. Can I series the Y steppers without causing problems or should I add the Duex2/5?
            Can the E1 be mapped to run second y steppers?
            • elmoretundefined
              elmoret
              Yes, you can series the Y motors. That's what's happening on the stepper driver that has two connectors.
              Yes, you can also run the second Y from E1, as commented above.
              • Texzinundefined
                Texzin
                @elmoret:
                Thanks
                • iDeveloundefined
                  iDevelo
                  @Texzin:
                  My config above is for a FT5 Z is on the Z port (both connectors).
                  • Texzinundefined
                    Texzin
                    @iDevelo:
                    @Texzin:
                    Thanks
