    Single Macro for filament handling?
    Gcode meta commands
    3.5k
      A Former User
      i think you could solve the parsing my just executing the file and use the object model to store variables.
      to deal with missing files i suppose you could set a flag before calling M98 and make sure to clear said flag in each file to be executed.
      I'm sure clever people will come up lots of ways to handle such things when the full support for using variables are implemented sometime in the near future.
      Kolbiundefined 1 Reply Last reply Reply Quote 0
      • Kolbiundefined
        Kolbi @A Former User
        @bearer It all looks like it should be very doable with everything mentioned above, I just need some time off work to start trying it out - I was also making sure that I'm not missing something, like some sort of built in feature that already does this.
        I'm completely new to duet so it is all an adventure at the moment 🙂
        • Kolbiundefined
          Kolbi
          ?!? Can state.status be used within a macro to determine if the machine is currently printing? Or will it simply return 'busy' because a macro is currently being run?
          if state.status == "idle"
          EDIT: It appears this should work, ref: https://forum.duet3d.com/topic/14013/triggers-within-homing-files/12
            A Former User @Kolbi
            @Kolbi https://duet3d.dozuki.com/Wiki/GCode_Meta_Commands
            • Kolbiundefined
              @bearer 👍
              • Kolbiundefined
                Kolbi
                I tried the following example but it will not work. When looking at the state.status from within a macro, it will always report 'busy'. Is there any other way, something I'm missing, that will let me know that a printer is not currently in printing something/ when it is idle (besides current macro)?
                ; If the printer hasn't been homed, home it - But first check if printer is idle
                if state.status = "idle"; Will never be idle when runnig within a macro?!?!?
                   M117 Printer is idle, checking if homed.
                   if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed
                      G28
                • Kolbiundefined
                  Kolbi
                  For the filament 'sub'macro, the following works. It is its own sub-macro that writes/overwrites a file called filatemp based on when the user exits the macro:
                  while 0=0; endless loop until canceled by user
                    ; Set PLA temp
                    M28 "0:/macros/filatemp"
                    M117 "Heating extruder for PLA"
                    T0 ; Activate Hotend
                    M104 S200                           ; set nozzle temp to 200c
                    M109 S200                           ; wait for extruder temp
                    M29
                    M291 S3 R"Filament Handling" P"Filament type currently set to PLA. Press cancel to save this selection or OK to proceed to next filament type."
                    ; Set PETg temp
                    M117 "Heating extruder for PETg"
                    M104 S230                           ; set nozzle temp to 230c
                    M109 S230                           ; wait for extruder temp
                    M29
                    M291 S3 R"Filament Handling" P"Filament type currently set to PETg. Press cancel to save this selection or OK to proceed to next filament type."
                    ; Set ABS temp
                    M117 "Heating extruder for ABS"
                    M104 S250                           ; set nozzle temp to 250c
                    M109 S250                           ; wait for extruder temp
                    M29
                    M291 S3 R"Filament Handling" P"Filament type currently set to ABS. Press cancel to save this selection or OK to proceed to next filament type."
                    ; Set PC temp
                    M104 S270                           ; set nozzle temp to 270c
                    M109 S270                           ; wait for extruder temp
                    M29
                    M291 S3 R"Filament Handling" P"Filament type currently set to PC. Press cancel to save this selection or OK to proceed to next filament type."
                  Anyone have a nicer way to do this?
                  • Kolbiundefined
                    Kolbi
                    I have it working for the most part, had to make two files with third one auto-generated. These are the only files in my macro directory so that the user interface is streamlined on the paneldue 5.
                    The macro 'Set Filament Type' generates the 'Heat Nozzle' macro based on user input - kinda awkward but it works.
                    The macro 'Filament Handling' detects if filament is loaded or not, then heats up nozzle using auto-generated 'Heat Nozzle', and performs load or unload base on filament detected status.
                    I want to add a third auto-option to 'Filament handling', based on if it is currently printing or not. If it is currently printing then it would automatically proceed to a changing of filament routine and not give load or unload as an option.
                    If anyone knows how to reliably do this, determine if a print is in progress at the time of macro execution, please let me know. 😉
                    Any and all feedback is appreciated. Thanks!
                    Macro (Directory):
                    Set Filament Type(File):
                    ;Set Filament Type
                    M291 P"Press OK to change filament type, else press CANCEL to exit." R"Filament Handling" S3
                    	; Set PLA temp
                    	M28 "0:/macros/Heat Nozzle"
                    	M29
                    	; Set PETg temp
                    	M29
                    	; Set ABS temp
                    	M29
                    	; Set PC temp
                    	M29
                    Filament Handling(File):
                    ;Filament Handling
                    if sensors.filamentMonitors[0].filamentPresent = true
                       M291 P"Press OK to begin filament UNLOADING, else press CANCEL to exit." R"Filament Handling" S3
                       M291 P"Please wait while the nozzle is being heated." T5 ; Display message
                       M98 P"0:/macros/Heat Nozzle"; heat nozzle to predetermined temp
                       M291 P"Ready for filament unloading. Gently pull filament and press OK." R"Filament Handling" S2
                       M291 P"Retracting filament..." T5 ; Display another message
                       G1 E-150 F5000 ; Retract filament
                       M400 ; Wait for the moves to finish
                       M292 ; Hide the message
                       M84 E0 ; Turn off extruder
                       G10 S0 ; Turn off the heater
                    else
                       M291 P"Press OK to begin filament LOADING, else press CANCEL to exit." R"Filament Handling" S3
                       M291 P"Ready for filament loading. Insert filament and press OK." R"Filament Handling" S2
                       M291 P"Feeding filament..." T5 ; Display new message
                       G1 E150 F600 ; Feed 150mm of filament at 600mm/min
                       G1 E20 F100 ; Feed 20mm of filament at 100mm/min
                       G4 P1000 ; Wait one second
                       G1 E-1 F1800 ; Retract 10mm of filament at 1800mm/min
                       M400 ; Wait for moves to complete
                    Heat Nozzle(File generated by 'Set Filament Type'):
                    ;Heat Nozzle
                    T0
                    M104 S230
                    M109 S230
                      dc42 administrators @Kolbi
                      @Kolbi said in Single Macro for filament handling?:
                      I suggest you look for state.status != "printing" instead. Here's how RRF determines state.status:
                      // Get the status index
                      size_t RepRap::GetStatusIndex() const noexcept
                      	return    (processingConfig)										? 0		// Reading the configuration file
                      #if HAS_LINUX_INTERFACE && SUPPORT_CAN_EXPANSION
                      			: (gCodes->IsFlashing() || expansion->IsFlashing())			? 1		// Flashing a new firmware binary
                      #else
                      			: (gCodes->IsFlashing())									? 1		// Flashing a new firmware binary
                      #endif
                      			: (IsStopped()) 											? 2		// Halted
                      #if HAS_VOLTAGE_MONITOR
                      			: (!platform->HasVinPower() && !gCodes->IsSimulating())		? 3		// Off i.e. powered down
                      #endif
                      			: (gCodes->IsPausing()) 									? 4		// Pausing / Decelerating
                      			: (gCodes->IsResuming()) 									? 5		// Resuming
                      			: (gCodes->IsPaused()) 										? 6		// Paused / Stopped
                      			: (printMonitor->IsPrinting() && gCodes->IsSimulating())	? 7		// Simulating
                      			: (printMonitor->IsPrinting())							  	? 8		// Printing
                      			: (gCodes->IsDoingToolChange())								? 9		// Changing tool
                      			: (gCodes->DoingFileMacro() || !move->NoLiveMovement() ||
                      			   gCodes->WaitingForAcknowledgement()) 					? 10	// Busy
                      			:															  11;	// Idle
                      • Kolbiundefined
                        Kolbi @dc42
                        @dc42 THANKS!
                        • Kolbiundefined
                          Kolbi
                          @dc42 said in Single Macro for filament handling?:
                          So something such as following? See any pitfalls?
                          if state.status != "printing"
                             ; Printer is not currently printing!
                                M98 P"0:/macros/Filament Handling"; run again
                             else
                          else
                             M291 P"Press OK to begin filament change, else press CANCEL to exit." R"Filament Handling" S3
                             M98 P"0:/sys/filament-change.g" ; call filament-change.g
                             M98 P"0:/sys/resume.g" ; call resume.g
                          • Kolbiundefined
                            Kolbi
                            Didn't work when printing from SD card, had to use
                            if state.status != "Processing"
                            It needs some refinement but it meets the original goal:
                            If anyone wants to see all the sys and macro files, they are located here: https://github.com/rkolbi/RRF-machine-config-files/tree/master/Prusa MK3s
                            • Kolbiundefined
                              Kolbi
                              I updated the macro set abit. Now the load/unload routine sets the filament type system-wide / in DWC. This is good because then when in DWC, it shows the correct filament loaded and also that if you're using the filament config.g you're good to go.
                              The other change is that the 'Set Filament Type' macro will not let you change filament type if the filament is currently loaded - makes sense to me.
                              Since I don't use DWC when normally using the printer, the load/unload filament macros within DWC are empty - when in DWC I'll still use my macro.
                              The three macro files are here:
                              https://github.com/rkolbi/RRF-machine-config-files/tree/master/Prusa MK3s/macros
                              I'm happy with the macro set operation and usability. If you have any thoughts on how to improve them please let me know.
                              Cheers,
                              Kolbi
                                Well done.
                                • Kolbiundefined
                                  Kolbi @Phaedrux
                                  @Phaedrux Thanks!
                                  • Kolbiundefined
                                    Kolbi
                                    This is the latest version - most likely won't change until variables are enabled in the firmware.
                                    💡Use the included Macros for filament handling.
                                    To make filament loading, unloading, and changing the most straightforward and simplistic possible evolution, I have made a macro set that is readily accessible from the PanelDue. To take full advantage of the duet filament system you will need to make the system filaments PLA, PETG, ABS, and PC. This will allow you to have custom instructions for each different filament, by adding such to the filament's config.g file. !Note: Based on my current macro version, it is required that each filament's load.g and unload.g remain empty. Placing code into these files will make these macro fail.
                                    "Set Filament Type" asks what type filament you are going to use; PLA, PETg, ABS, or PC. Based on the selection, this macro rewrites the "Heat Nozzle" macro to heat the nozzle for the selected filament type. !Note: This macro only has to be executed once for the given filament type change as it's settings are nonvolatile, regardless of reset or power off. !Note: The script will not let you change the filament type while filament is loaded.
                                    "Filament Handling" is for any filament unloading, loading, and changing regardless of the printer's state, printing or not. This macro will load, unload, and change filament based on two conditions; whether it detects filament is currently loaded or not, and if a print is in progress or not. !Note: The logic function in the macro retrieves the current status of the filament sensor to base the perceived desired action to enact. If your printer's filament is currently empty and you intend to load filament, please do not place it into the extruder until requested to do so by the macro. Else the macro will determine that filament is loaded and that you desire to unload filament, instead of load.
                                    "Heat Nozzle" is created by the "Set Filament Type" macro and can be selected to heat the hotend to the set temperature for the last chosen filament type. You do not need to run this to change filament, the "Filament Handling" macro automatically runs this macro to perform the heating of the hotend to carry out the filament handling, whether it be loading, unloading, or changing.
                                    /macros
                                    ; 0:/macros/Filament Handling
                                    ; Macro used for all filament handling evolutions
                                    if state.status != "processing"                            ; Printer is not currently printing!
                                       if sensors.filamentMonitors[0].filamentPresent = true   ; Filament is detected, currently loaded
                                          M98 P"0:/macros/Heat Nozzle"                         ; Heat nozzle to predetermined temp
                                          T0 M702                                              ; Select tool 0, set filament is unloaded
                                          M104 S-273                                           ; Turn off hotend
                                          M140 S-273                                           ; Turn off heatbed
                                          M98 P"0:/macros/Filament Handling"; run again        ; Now that filament is unloaded, lets ask to load filament
                                       else
                                          G1 E150 F450                                         ; Feed 150mm of filament at 600mm/min
                                          M98 P"0:/sys/filaset"                                ; Set system filament type
                                    else
                                       M291 P"Press OK to begin filament CHANGE, else press CANCEL to exit." R"Filament Handling" S3
                                       M98 P"0:/sys/filament-change.g"                         ; Call filament-change.g
                                       M24                                                     ; Start/resume SD print
                                    /macros/Heat Nozzle
                                    ; 0:/macros/Heat Nozzle
                                    ; Heat nozzle to set temp
                                    M291 R"Filament Handling" P"Heating nozzle for PETg, please wait." S0 T10
                                    T0                                                         ; Select Tool 0
                                    M109 S230                                                  ; set temp to 230c and wait
                                    /macros/Set Filament Type
                                    ; 0:/macros/Set Filament Type
                                    ; Macro used to set system's loaded filament type
                                    if sensors.filamentMonitors[0].filamentPresent = false        ; if filament is loaded then reject action to change filament type
                                      M291 P{"System filament is currently set to " ^ move.extruders[0].filament ^ ". Press OK to change filament type, else press CANCEL to exit."} R"Filament Handling" S3
                                      ; Set PLA temp
                                      M28 "0:/macros/Heat Nozzle"                                 ; Begin writing to SD card file
                                      M291 R"Filament Handling" P"Heating nozzle for PLA, please wait." S0 T10
                                      M109 S200                                                   ; set temp to 200c and wait
                                      M29                                                         ; Stop writing to SD card
                                      M28 "0:/sys/filaset"                                        ; Begin writing to SD card file
                                      T0 M702                                                     ; Set system filament as UNLOADED
                                      T0 M701 S"PLA"                                              ; Set system filament as PLA
                                      ; Set PETg temp
                                      T0 M701 S"PETG"                                             ; Set system filament as PETG
                                      ; Set ABS temp
                                      M291 R"Filament Handling" P"Heating nozzle for ABS, please wait." S0 T10
                                      M109 S250                                                   ; set temp to 250c and wait
                                      T0 M701 S"ABS"                                              ; Set system filament as ABS
                                      ; Set PC temp
                                      M291 R"Filament Handling" P"Heating nozzle for PC, please wait." S0 T10
                                      M109 S270                                                   ; set temp to 270c and wait
                                      T0 M701 S"PC"                                               ; Set system filament as PC
                                    else
                                      M291 S3 R"Filament Handling" P"Filament is currently loaded. Please unload filament before changing filament type."
                                    filament.pdf
                                    • mitchundefined
                                      mitch
                                      This post is deleted!
                                      • VirtualBrownundefined
                                        VirtualBrown
                                        Is there a relatively easy way to edit these macros to work if one doesn't have a filament sensor?
