Duet3 + 3HC Dual Y-Axis CAN Problem
@dc42 Thank you for your answer!
I use NPN inductive sensors on all axes.
I will test the changes in my homey.g file and give you feedback!
@CR3D said in Duet3 + 3HC Dual Y-Axis CAN Problem:
Thanks. An inductive sensor should provide a clean transition. However, when it is not triggered the sensor is essentially open circuit, so the endstop input is held high only by the 27K pullup resistor in the Duet. So the wire connecting it to the Duet endstop input may pick up noise, especially if it is an unshielded cable and it runs close to a stepper motor wire.
I recommend that you you use shielded cable for these wires. Another possibility is to connect a lower value pullup resistor between the IN and +5V pins of the endstop IO_x connector.
I tested the changes at the homey.g file
here the new one:
; homey.g ; called to home the Y axis ; G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G1 H1 Y550 F5000 ; move quickly to Y axis endstop and stop there (first pass) G1 H2 Y-10 F360 ; go back a few mm G4 P100 G1 H1 Y455 F360 ; move slowly to Y axis endstop once more (second pass) G1 H2 Z-5 F6000 ; lower Z again G90 ; absolute positioning
unfortunately, this change did not help either.
Thanks. With that Y homing file, I can reproduce the problem - probably because I no longer need to release the Y endstop switch as quickly as I needed to using your original file. I will investigate it tomorrow.
PS - I can see what is happening. When the firmware executes the second G1 H1 move, which involves only stepper drivers connected to the expansion board, it doesn't wait for that move to complete before scheduling the next move - and in scheduling the next move, it disables the endstop.
I'm on the way to solving this, but meanwhile I have a temporary workaround. Between every pair of G1 H1/H2 moves that involve only drivers on the expansion board, insert a move that involves a motor on the main board. For example, this works for me:
; homey.g ; called to home the Y axis ; G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G1 H1 Y550 F5000 ; move quickly to Y axis endstop and stop there (first pass) G1 H2 Z0.1 G1 H2 Y-10 F360 ; go back a few mm G1 H2 Z-0.1 G1 H1 Y50 F360 ; move slowly to Y axis endstop once more (second pass) G1 H2 Z0.1 G1 H2 Y-10 G1 H2 Z-5.1 F6000 ; lower Z again G90 ; absolute positioning
This is getting strange! The problem goes away if I reduce the length of the second homing move slightly, or I increase the speed of that move slightly. For example, this homing file fails:
; homey.g ; called to home the Y axis ; G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G1 H1 Y550 F5000 ; move quickly to Y axis endstop and stop there (first pass) G1 H2 Y-10 F360 ; go back a few mm G1 H1 Y455 F360 ; move slowly to Y axis endstop once more (second pass) G1 H2 Z-5 F6000 ; lower Z again G90 ; absolute positioning
but it works if I reduce Y455 in the second G1 H1 line to Y450, or if I increase F360 to F361.
Found it! It was a subtle timing issue. Fixed firmware build at https://www.dropbox.com/s/p28vp6fbnkc4rbz/Duet3Firmware_MB6HC.bin?dl=0.
@dc42 said in Duet3 + 3HC Dual Y-Axis CAN Problem:
@dc42 Might that be the reason why my Z homing switch doesn't work at 600mm/min minute but works fine at 300mm/min (yet XY and U all work at 1200 mm/min+) as per this thread https://forum.duet3d.com/topic/17404/z-switch-on-expansion-board-latency-issue/20
It might be if your Z drivers are not on the main board.
Ok thank you very much! I will test it
sensational david ... you did it!
thank you for this !!!!
Now it works...
