    Toolboard 1LC Heater voltage
    • BeosDocundefined
      BeosDoc
      Quick question about the toolboard with 24V supplied to the board. I know the fans are 12V, but is the heater voltage at 24V or 12V?
      Thanks
        A Former User
        Output Out0 uses Vin while Out1 and Out2 uses 12v.
        So with Vin=24v the heater would be 24v.
        • BeosDocundefined
          BeosDoc
          Great, thank you. I have some toolboards coming and needed to know if I had to order different heaters or not.
          Aquiluxundefined 1 Reply Last reply Reply Quote 1
          • Aquiluxundefined
            Aquilux @BeosDoc
            @T3P3Tony , might want to add this to your documentation, there's no mention of this in either the new or old docs.
              T3P3Tony administrators @Aquilux
              @aquilux thanks, I have added that to the hardware specification and description of connections in the docs:
              https://docs.duet3d.com/en/Duet3D_hardware/Duet_3_family/Duet_3_Toolboard_1LC#description-of-connections
