    Macros on control page
    PanelDue
    • Olivimagesundefined
      Olivimages
      I see that on PanelDue 4 macros are normally on the main page.
      I have all my macros on the macro page, and refreshing perfectly but i cannot populate the main page.
      There is plenty of room, it's a cnc machine and only heat bed is displayed.
      How these 4 macros are displayed ? Automatically ? The 4 first in alphabetical order i think.
      • resamundefined
        resam
        Whats your PanelDue firmware version? You can check in the Setup page.
        The "4 macros on the control page" was introduced in v1.20.
        Olivimagesundefined 1 Reply Last reply Reply Quote 0
          Olivimages @resam
          @resam said in Macros on control page:
          I was on 1.23.2 and now upgraded to 1.24
          • resamundefined
            resam
            that should be recent enough...
            The macros you are looking for show up in the web interface?
            Did you use any special folder or file name?
              Olivimages @resam
              Yes the macros appears on web interface and macro page without any problem.
              • resamundefined
                resam
                It might be related to your CNC config - since you don't have a tool / extruder / hotend defined, this condition might kick in and hide all macros:
                https://github.com/Duet3D/PanelDueFirmware/blob/master/src/UserInterface.cpp#L2421
                just to confirm, can you try and define a dummy tool - I think the macros should show up then.
                Olivimagesundefined 1 Reply Last reply Reply Quote 2
                  Olivimages @resam
                  Yessss perfect
                  I created tool 0 "M563 P0 H0 S"Default tool" ; Create dummy tool"
                  And now it works, i have the 4 macros.
                  Thank you 🙂
