ATX power off confirmation?
Why i don't get question if i would realy like to turn printer off with ATX power off
i have RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later + DueX5
Is this in regards to using the button in DWC or sending
M81
Usign DWC button
That's a tough one. Why did it do the thing you asked it to do?
I can move this to the DWC wishlist as a feature request for confirmation before powering off.
if in this DWC.js file is that question. @Phaedrux this is for that problem if you remember that i want to add one step before printer turn off ?
Ah yes, I see. If that's the intention and it's not doing the confirmation that would be a bug. Just to confirm, you're using firmware 3.1.1 and DWC 3.1.1?
that Duet Web Control v1.22.6 i found in reprap.thm file
where and how can i update DWC to 3.1.1
i can't find file that i can copy in WWW folder on my SD card? -
https://github.com/Duet3D/DuetWebControl/releases/tag/3.1.1
download the zip and upload it to the systems tab in DWC. Don't unzip it, DWC will handle all that -
@jay_s_uk thanks
@matej1006 Looking at your screen grab, that's not DWC 1.22.6, so you're on at least DWC 2.x already. DWC 2.x and 3.x shows the version in the 'General' tab; I'm not sure you can check the DWC version from the files on the SD card, or with a gcode command, and I don't think it's reported in the object model.
The reprap.htm is DWC 1.22.6, but you can have both DWC 2.x (or 3.x) and DWC 1.x on the SD card at the same time, and you will connect to the newer version as standard. You can connect to DWC 1.x by connecting to http://[printer ip address]/reprap.htm
The file structure for an SD card with DWC 1.22.6 only (no DWC 2 or 3) is shown here: https://duet3d.dozuki.com/Wiki/SD_Card#Section_Creating_the_file_structure
i will try today with 3.1.1 DWC and i hope that will work
