    Typo error in documentation.
    • chas2706undefined
      chas2706
      Have just noticed this typo error in the Gcode documentation:
      M851: Set Z-Probe Offset (Marlin Compatibility)
      RepRapFirmware 2.02 and later
      M851 Znn is implemented for backwards compatibility with other firmware. It sets the Z probe trigger in the same way as G31 Z-nn (note the sign reversal). It also flags the Z-probe G31 parameters as to be saved in config-override.g if the M500 command is used.
      G31 should be used in preference to M581.
      Obviously it should refer to M851 not M581.
      droftartsundefined 1 Reply Last reply Reply Quote 1
        droftarts administrators @chas2706
        @chas2706 Thanks, fixed.
