Move axis without homing
I recently started building a CoreXY printer, first printer being built entirely from scratch and first time using a Duet3D product. Built the frame and have put just the basics for the XY axis together, i.e. timing belts, steppers, rails. Have not put any limit switches or Z axis together yet.
When I connect the motors to the board, and power up, the board indicates that the various axes are not yet homed, which is correct. I am hoping to just move the XY axes to insure that I have the configuration and building of the XY correct. Is there a way to do this without homing all axes?
@pjn2973 to test the single CoreXY especially, see https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter#Section_Testing_motor_movement
The G1 S parameters are replaced by H parameters for RRF 3. -
https://forum.duet3d.com/topic/14971/vcore-pro-core-xy-the-x-and-y-axis-home-issue/4?_=1595628809652
Core XY can get confusing. Take a look at that post to try and keep it straight.
Thanks, guys; finally got back to this. Got the motors to move and test correctly using all of the information you posted.
