Toolboard 1LC Driver Issue
@choblet maybe you need a T0 at the end of the config?
@JoergS5 I will give that a shot and report back. I needed to get some parts out, so I just rewired and remapped the extruder to the Mainboard.
@choblet if T0 is not working, checking tfree0, tpost0 and config-override would be necessary also.
If the hemera worked as the same tool T0 on the mainboard then changing which driver drives the tool uses wouldn't necessitate any other config changes than the
M569
andM584
. Presumably user or slicer is selecting the tool before use.As you say sensor
20.temp0
is working there shouldn't be an extruder related reason for the driver not working; but it wouldn't hurt to swap say X and EM584 E0.0 Y0.1 Z0.2 X20.0
and see if the hemera moves with the X axis (presuming there is no filament loaded). You may need to issue let sayG92 X100
to be able to jog X without homing. -
I am wondering about the failedOp 0x80 for the driver in M122, but I don't find documentation about it. And lot of timeouts.
@bearer That's really clever, nice one.
config:; Configuration file for Duet 3 (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.1.4 on Thu Jul 23 2020 13:32:55 GMT-0700 (Pacific Daylight Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"3DP" ; set printer name ; Drives M569 P0.0 S0 ; physical drive 0.0 goes backwards M569 P0.1 S1 ; physical drive 0.1 goes forwards M569 P0.2 S1 ; physical drive 0.2 goes forwards M569 P20.0 S1 ; physical drive 20.0 goes forwards, 1LC ;M569 P0.3 S1 ; extruder driver goes forwards, Mainboard ;M584 X0.0 Y0.1 Z0.2 E20.0 ; set drive mapping for 1LC ;M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping for Mainboard M584 E0.0 Y0.1 Z0.2 X20.0 ; set drive mapping for E/X swap testing M350 X16 Y16 Z32 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y400.00 Z400.00 E409.00 ; set steps per mm M566 X6.00 Y6.00 Z3.60 E3.00 ; set maximum instantaneous speed changes (mm/min) M203 X900.00 Y900.00 Z900.00 E800.00 ; set maximum speeds (mm/min) M201 X700.00 Y700.00 Z700.00 E250.00 ; set accelerations (mm/s^2) M906 X850 Y850 Z1000 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X140 Y140 Z200 S0 ; set axis maxima ; Endstops M574 X1 S1 P"!^io0.in" ; configure active-high endstop for low end on X via pin !^io0.in M574 Y1 S1 P"!^io1.in" ; configure active-high endstop for low end on Y via pin !^io1.in M574 Z1 S1 P"!^io2.in" ; configure active-high endstop for low end on Z via pin !^io2.in ; Z-Probe M558 P0 H20 F120 T3000 ; disable Z probe but set dive height, probe speed and travel speed M557 X15:85 Y15:85 S5 ; define mesh grid ; Heaters M308 S0 P"20.temp0" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 0 as thermistor on pin temp0 at address 20 (20.0) M950 H1 C"20.out0" T0 ; H1 for the extruder heater. H0 typically bed heater. *Does this need an address? M143 H1 S285 ; Maximum H1 (Extruder) heater temperature (low for testing) M307 H1 A340.0 C140.0 D5.5 S1.00 V0.0 B0 ; Default Tool Heater Parameters...? ; Fans M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency M106 P0 S0 H1 T45 ; set fan 0 value. Thermostatic control is turned on M950 F1 C"20.out1" Q500 ; create fan 1 on pin 20.out1 and set its frequency M106 P1 S0 H-1 ; set fan 1 value. Thermostatic control is turned off ; Tools M563 P0 D0 H1 S"1LC" F1 ; Define tool 0 G10 P0 X0 Y0 Z0 ; Set tool 0 axis offsets G10 P0 S-273 R-273 ; Set tool 0 operating and standby temperatures(-273 = "off") ; Custom settings are not defined ; Miscellaneous M501 ; load saved parameters from non-volatile memory T0 This did not make the extruder motor work, unfortunately. If you could check the code to make sure I understood and executed it correctly, my thanks.
@JoergS5 I really wish it could have been as easy as adding the
T0
to the end of the file. I just ran theM122 B20
again and received the same error you were curious about. Timeouts were 7511 this time. -
@choblet unfortinately the toolboard is so new, there is only few data available about it. The only thing was if you change the address from 121 to a different address, you have to reboot the board.
There is a sample config from dc42 you could check against for the settings.
@choblet what you can do is run
M98 P"config.g"
to see whether it reports an error processing the config. -
The easiest way to test the motor is to map an axis to it e.g. X, then you must set the current, then try jogging it:
M584 X20.0 M906 X1000 G91 G1 H2 X100 You can send these commands from the console.
You can ignore the "failedOp" as long as there is no more than 1 write error recorded.
EDIT: actually the problem is this:
timeouts 10471
I'm not aware of a configuration reason that can cause that. Please ask your supplier to replace the tool board.
@dc42 Understood, I will get in contact with them and talk to them about it. I don't know what their return policy is, but I think I've had it for about two months, which seems way too long to qualify for a return. I'll keep you posted though.
Those who walked me through the syntax, showed me where I was missing information in error messages, how to utilize the different commands to cleverly debug and troubleshoot problems, I can't tell you how valuable that was. I learned quite a bit over the last few days. Thank you.
@choblet said in Toolboard 1LC Driver Issue:
I approve a replacement, so your supplier should replace it. Please refer them to this forum thread.
@dc42 Thank you. That is so helpful to me right now, I can't even tell you.
No problem, and I'm sorry that you received what I believe to be a faulty tool board.
@dc42 It's no problem at all. The offer for a replacement along with how much I picked up over the past few days more than makes up for it.
