    Mechanical filament sensor config
    348
    • Dad003undefined
      Dad003
      so i was looking to had a mechanical filament sensor using a simple switch , but on the wiki i couldn't find the line of code i will need to had to my Duet 3
      the example in the wiki show : M591 P3 C"e0_stop" S1 ; filament monitor connected to E0_stop
      I have 2 extruder so should my line of code look like this ?
      M591 P1 C"!io3.in"e0_stop" S1 ; filament monitor connected to E0_stop
      M591 P1 C"!io4.in"e1_stop" S1 ; filament monitor connected to E1_stop
      If not good, what should be the correct line just want to make sure i have the correct things.
      • dhusoloundefined
        dhusolo
        This is something I'm actually working on getting setup. I'm using a simple NC mechanical end stop switch. This is my code in config.g
        M591 D0 P1 C"io3.in" S1
        If I run M591 D0 i Get the correct response if filament is present or not. I know on my Duet 2 Wifi I also had to configure M581 and M582 in config.g but I'm not sure if we need to do the same in RRF3
          Phaedrux Moderator @dhusolo
          @dhusolo said in Mechanical filament sensor config:
          I don't think that's required anymore.
          https://duet3d.dozuki.com/Wiki/Gcode#Section_M591_RepRapFirmware_Num_3
          • Dad003undefined
            Dad003
            @Dad003 said in Mechanical filament sensor config:
            THank you , i printed my part put the switch and inserted the Gcode line and it work , both extruder need to have filaments in them .
            IT there a way that one could had a line of code that would only check the switch of the current extruder in the job ? so that if extruder 2 is not used and has no filament that nothing pop up ? can duet do that or it asking too much .
            anyway it work so i dont have to keep watching when the spool it getting low !
            Phaedruxundefined maicolspazziniundefined 2 Replies Last reply Reply Quote 0
            • Dad003undefined
              Dad003
              here a picture
                Phaedrux Moderator @Dad003
                I suppose you could have separate filament monitor gcode commands in the tool change files for either tool so that it enables or disables the monitor as the tools are changed by the slicer tool calls. Maybe. Not sure if that would work or not.
                • maicolspazziniundefined
                  maicolspazzini @Dad003
                  Hi, what do you add on config.g? I Use
                  M591 D0 P1 C"e0stop" S1
                  M591 D1 P1 C"e1stop" S1
                  But during print there are some notifications ''bad command .... '' How can I resolve?
                    Phaedrux Moderator @maicolspazzini
                    @maicolspazzini said in Mechanical filament sensor config:
                    Please create a new thread with your issue and include as much detail as poissble.
