    SD Cards do occasionally fail...
    777
    • Kolbiundefined
      Kolbi
      @bearer Yup, couple ways to skin the cat.
      Since I'm usually involved in multiple projects at one time, and bounce back and forth with month gaps sometimes, I made a private home forum several years ago to capture all my notes and associated files. This way each project, piece of gear, learning, or other has it's own topic and all my notes are organized under it. Along with that, I upload the files and comment on them so it is always easy to pick up where I left off.
      Funny enough I was doing all this for the sys and macro folders, but like I said - totally forgot about the filament directory😖 ...
        A Former User
        I recently had more than a few brand new brand name SD cards failing, after a few recommendations from some users here, I have gone over to using Industrial SD cards, I bought 30 to replace what I have in machines this is my "spares pile" we will see how they perform.
        Industrial SD cards
        Kolbiundefined 1 Reply Last reply Reply Quote 2
        • Leavundefined
          Leav @A Former User
          @bearer said in SD Cards do occasionally fail...:
          i find this very usefull https://github.com/wilriker/rfm for backups without removing the card.
          Would love to use this. Is this Linux only?
            A Former User @Leav
            @Leav said in SD Cards do occasionally fail...:
            Is this Linux only?
            afaik wilriker provides builds for win/mac/linux, and sources in go so you could built it for whatever go runs on
            Kolbiundefined Leavundefined 2 Replies Last reply Reply Quote 0
            • Kolbiundefined
              Kolbi @A Former User
              @CaLviNx Nice, didn't cross my mind... Cheap too, seeing 5 for $40.
              • Kolbiundefined
                @bearer Good call on this script, messed around with it last night.
                BUT - DWC should have a Backup-All and a Restore-All function.
                A Former User? gnydickundefined 2 Replies Last reply Reply Quote 0
                  A Former User @Kolbi
                  @Kolbi said in SD Cards do occasionally fail...:
                  I'm not gonna disagree, but the development team is pretty limited and when the community provides good alternatives I'm OK with other features given priority by the developers (but thats just my opinion)
                  • Leavundefined
                    Leav @A Former User
                    @bearer
                    Yup! I'm just bad at navigating GitHub.
                    [Releases page](link url)
                    I agree with both of you. Perhaps there is a middle ground? is it possible to contribute to the project?
                    Kolbiundefined A Former User? 2 Replies Last reply Reply Quote 0
                    • Kolbiundefined
                      Kolbi @Leav
                      @Leav I've taken a look at the repository...
                      @bearer suggestion is solid, and it does work. I've combined that with cron on my home server and it is looking good.
                      I guess the way I see it is that the assumed mechanics to do a system backup, as suggested, are mostly existing but at this point in time it's a bit past my current skill set and available time to learn it.
                      • gnydickundefined
                        gnydick @Kolbi
                        @Kolbi click "Select All" check mark on list of files. Right-click, choose download.
                        It's not one step for all, but at least it's one step for each area.
                          A Former User @Leav
                          "of course" most of the code is under various repositories under https://github.com/Duet3D/ and you can submit pull requests
                          • Kolbiundefined
                            Kolbi @gnydick
                            @gnydick Thanks much, this is what I normally do.
