    Duet 2 Ethernet and SBC
    Beta Firmware
    29
    302
    33.2k
    • wilrikerundefined
      wilriker @smoki3
      @smoki3 Do you have the possibility to change homing to something other than stallGuard to test with that? Using stallGuard would fit into the issue that was found so far that was blocking updates on my setup.
      Also can you please confirm that print simulation is working? And if possible heating of bed/hotend. So far it looks to be bound to the motion system (the communication to the TMC2660 in particular) but it's unclear if there are other things that will trigger fault states.
      Manuel
      My Tool Collection
      smoki3undefined 1 Reply Last reply Reply Quote 0
      • smoki3undefined
        smoki3 @wilriker
        @wilriker said in Duet 2 Ethernet and SBC:
        To disable stallGuard I have to do some more work. (Solder some endstops and so on, I can do but need some time)
        Heating my hotend is fine. It is heating up as it should. Then I now tried to simulate a print: Then I get the same issue as when I try to home my printer. The simulation starts but hang forever. Then I also not able to send any command to the printer. But at this time I don't see any checksum errors in the terminal.
        [info] Selected file /opt/dsf/sd/gcodes/Dreher.gcode
        [info] Starting file print
        [info] File: Optional macro file start.g not found
        I also tried homing all my axis separately and this is working fine.
        • smoki3undefined
          smoki3
          Update: I also tried now to simulate a few times more. Now I get some checksum error and resets.
            A Former User @smoki3
            @smoki3 said in Duet 2 Ethernet and SBC:
            if you disconnect the motors you could just attach some wires to the endstop signal pin and short them to ground to simulate real endstops. you might also want to reduce the feedrate to give you plenty of time to carefully simulate the switches with the short.
            • smoki3undefined
              smoki3 @A Former User
              @bearer said in Duet 2 Ethernet and SBC:
              I now disabled stall detection in the config. But still not able to run a simulation.
              • wilrikerundefined
                wilriker @smoki3
                @smoki3 Can you then please post your config.g as well as your home*.g files?
                I was able to simulate a print as well as (air) print without issues. Basically everything worked for me except flashing new firmware so it must be something in your config that I do not have that might help to narrow down the problem further.
                Manuel
                My Tool Collection
                smoki3undefined A Former User? 2 Replies Last reply Reply Quote 0
                • smoki3undefined
                  smoki3 @wilriker
                  I don't think it has something to do with the config. I believe that the issue is more randomly. Because I sometimes get a "hanging forever printer", sometimes the printer resets.
                  config.g:
                  G90                                                					; Send absolute coordinates
                  M83                                                					; relative extruder moves
                  ;Panel Due
                  M575 P1 S1 B57600
                  M584 X7 Y8 Z0 E5:6:2:1 U9 V4 W3                         			; Map Drives to Axis
                  M669 K1                                            					; Select CoreXY mode
                  M569 P0 S0                                         					; Drive 0 goes forwards
                  M569 P1 S0                                         					; Drive 1 goes forwards
                  M569 P2 S0                                         					; Drive 2 goes forwards
                  M569 P3 S1                                         					; Drive 3 goes forwards
                  M569 P4 S1                                         					; Drive 4 goes forwards
                  M569 P5 S0                                         					; Drive 5 goes forwards
                  M569 P6 S1                                         					; Drive 6 goes forwards
                  M569 P7 S0                                        					; Drive 7 goes forwards
                  M569 P8 S0                                        					; Drive 8 goes forwards
                  M569 P9 S0                                        					; Drive 9 goes forwards
                  M350 X16 Y16 Z16 E16:16:16:16 V16 W16 I1                   			; Configure microstepping with interpolation
                  M350 U8 I0					   		                    			; Configure microstepping without interpolation
                  M92 X100 Y100 Z1600 U100 V400 W400 E420:420:420:420          		; Set steps per mm
                  M566 X600 Y600 Z35 U2 V8 W8 E800:800:800:800         		        ; Set maximum instantaneous speed changes (mm/min)
                  M203 X35000 Y35000 Z1200 U5000 V1200 W2400 E5000:5000:5000:5000    	; Set maximum speeds (mm/min)
                  M201 X6000 Y6000 Z400 U500 V400 W400 E2500:2500:2500:2500         	; Set accelerations (mm/s^2)
                  M906 X1650 Y1650 Z1100 U400 V1000 W1000 E1450:1000:1000:1450 I30    ; Set motor currents (mA) and motor idle factor in per cent
                  M84 S120                                           					; Set idle timeout
                  M208 X-35 Y-49 Z0 U0 V0 W0 S1                          		    	; Set axis minima
                  M208 X328.5 Y243 Z300 U500 V34 W34 S0                     			; Set axis maxima
                  ; Thermal Sensors
                  M308 S0 P"bedtemp" Y"thermistor" T100000 B3950                   	; Set thermistor + ADC parameters for heater 0
                  M308 S1 P"duex.e2temp" Y"thermistor" T100000 B4725 C7.060000e-8     ; Set thermistor + ADC parameters for heater 1
                  M308 S2 P"e0temp" Y"thermistor" T100000 B4725 C7.060000e-8       	; Set thermistor + ADC parameters for heater 2
                  M308 S3 P"duex.e3temp" Y"thermistor" T100000 B4725 C7.060000e-8     ; Set thermistor + ADC parameters for heater 3
                  M308 S4 P"duex.e4temp" Y"thermistor" T100000 B4725 C7.060000e-8     ; Set thermistor + ADC parameters for heater 4
                  ; Hardware
                  M950 H0 C"bedheat" T0							; Bed Heater
                  M950 H1 C"duex.e2heat" T1						; Tool 0 Heater
                  M950 H2 C"e0heat" T2							; Tool 1 Heater
                  M950 H3 C"duex.e3heat" T3						; Tool 2 Heater
                  M950 H4 C"duex.e4heat" T4						; Tool 3 Heater
                  M950 F0 C"fan0"									; Tool 1 PCF
                  M950 F1 C"fan1"									; Tool 1 HEF
                  M950 F3 C"duex.fan3"							; Tool 0 PCF
                  M950 F4 C"duex.fan4"							; Tool 0 HEF
                  M950 F5 C"duex.fan5"							; Tool 2 PCF
                  M950 F6 C"duex.fan6"							; Tool 2 HEF
                  M950 F7 C"duex.fan7"							; Tool 3 PCF
                  M950 F8 C"duex.fan8"							; Tool 3 HEF
                  M950 F9 C"duex.e5heat"							; LED
                  ; Max Temp Protection
                  M140 H0
                  M143 H0 S140                                   	; Set temperature limit for heater 0 to 140C
                  M143 H1 S275                                   	; Set temperature limit for heater 1 to 270C
                  M143 H2 S275                                   	; Set temperature limit for heater 2 to 270C
                  M143 H3 S275                                   	; Set temperature limit for heater 3 to 270C
                  M143 H4 S275                                   	; Set temperature limit for heater 4 to 270C
                  ; Fanmapping
                  M106 P3 S0 I0 F500 H-1 C"Tool 0"               	; Set fan 3 value, PWM signal inversion and frequency. Thermostatic control is turned off
                  M106 P0 S0 I0 F500 H-1 C"Tool 1"               	; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                  M106 P5 S0 I0 F500 H-1 C"Tool 2"               	; Set fan 5 value, PWM signal inversion and frequency. Thermostatic control is turned off
                  M106 P7 S0 I0 F500 H-1 C"Tool 3"               	; Set fan 7 value, PWM signal inversion and frequency. Thermostatic control is turned off
                  M106 P9 S0 I0 F500 H-1 C"LED"               	; Set LED value, PWM signal inversion and frequency. Thermostatic control is turned off
                  M106 P4 S1 I0 F500 H1 T75                      	; Set fan 4 value for Tool 0, PWM signal inversion and frequency. Thermostatic control is turned on
                  M106 P1 S1 I0 F500 H2 T75                      	; Set fan 1 value for Tool 1, PWM signal inversion and frequency. Thermostatic control is turned on
                  M106 P6 S1 I0 F500 H3 T75                      	; Set fan 6 value for Tool 2, PWM signal inversion and frequency. Thermostatic control is turned on
                  M106 P8 S1 I0 F500 H4 T75                      	; Set fan 8 value for Tool 4, PWM signal inversion and frequency. Thermostatic control is turned on
                  ;M915 H300 X Y S4 R0 F0 	    					; Set Stall detection sensitivity
                  ;M915 V S2 H350 F0 R0                        	; Calibration
                  ;M915 W S2 H350 F0 R0                          	; Cleaner
                  ;M574 Y1 S3                           			; Set endstops controlled by motor load detection
                  ;M574 X1 S3                            			; Set endstops controlled by motor load detection
                  ;M574 U0                             			; Set endstops controlled by motor load detection
                  ;M574 V1 S3                           			; Set endstops controlled by motor load detection
                  ;M574 W1 S3                         				; Set endstops controlled by motor load detection
                  M558 K0 P5 C"^!zprobe.in" H3 F180 T25000	   	; Z probe connected to Z endstop input
                  G31 K0 X0 Y0 Z0.15 P500          	            ; Set Z probe offset + naher ran - weiter weg
                  M557 X10:290 Y20:180 S40 					   	; Define mesh grid
                  ; Tool Probe
                  M558 K1 P8 C"!e0stop" H5 F80 T3000  		  	; Tool probe connected to Z endstop input
                  G31 K1 X0 Y0 Z0 P500          	               	; Set Z probe offset + naher ran - weiter weg
                  M563 P0 D0 H1 F3                               	; Define tool 0, Fan 3
                  M563 P1 D1 H2 F0                               	; Define tool 1, Fan 0
                  M563 P2 D2 H3 F5                               	; Define tool 2, Fan 5
                  M563 P3 D3 H4 F7                               	; Define tool 3, Fan 7
                  ; PID Settings Tools
                  M307 H1 A595.9 C199.5 D4.5 S1.00 V24.1 B0      	; Set PID settings tool 0
                  M307 H2 A775.0 C252.4 D8.2 S1.00 V24.1 B0      	; Set PID settings tool 1
                  M307 H3 A716.5 C237.1 D8.7 S1.00 V24.1 B0      	; Set PID settings tool 2
                  M307 H4 A567.7 C241.0 D6.7 S0.80 V24.1 B0      	; Set PID settings tool 3
                  M307 H0 A181.4 C631.5 D4.9 S1.00 V24.1 B0      	; Bed PID Settings
                  ; Tools Temperatures
                  G10 P0 R0 S0                                   	; Set initial tool 0 active and standby temperatures to 0C
                  G10 P1 R0 S0                                   	; Set initial tool 1 active and standby temperatures to 0C
                  G10 P2 R0 S0                                   	; Set initial tool 2 active and standby temperatures to 0C
                  G10 P3 R0 S0                                   	; Set initial tool 3 active and standby temperatures to 0C
                  ; Calibrate MCU Temperature
                  M912 P0 S-8
                  ; LED
                  M106 P9 S0.5
                  ; DAA
                  M593 F50
                  ; Pressure Advance
                  ; M572 D0:3 S0.5
                  M572 D1:2 S0.05
                  ; Load config override
                  M501
                  homeall.g:
                  ; homeall.g
                  ; called to home all axes
                  M98 P"/sys/homey.g"
                  M98 P"/sys/homex.g"
                  M98 P"/sys/homez.g"
                  M98 P"/sys/homeu.g"
                  M98 P"/sys/homev.g"
                  M98 P"/sys/homew.g"
                  homex.g:
                  ; homex.g
                  ; called to home the x axis
                  G91 			; use relative positioning
                  G1 H2 X0.5 Y-0.5 F10000		; energise
                  M913 X25 Y25		; drop motor currents to 50%
                  G1 H2 Z3 F5000		; lift Z 3mm
                  G1 H1 X-400 F3200 	; move left 400mm, stopping at the endstop
                  G4 P100
                  G1 X2 F2000
                  G1 H2 Z-3 F1200		; lower Z
                  G90 			; back to absolute positioning
                  M400 			; make sure everything has stopped before we reset the motor currents
                  G4 P100			; wait 400ms
                  M913 X100 Y100 		; motor currents back to 100%
                  homey.g:
                  ; homey.g
                  ; called to home the Y axis
                  M913 X25 Y25 		; drop motor currents to 25%
                  G1 H1 Y-400 F3200 	; move to the front 400mm, stopping at the endstop
                  G4 P200
                  G1 Y2 F2000
                  homez.g:
                  ; homez.g
                  ; called to home the Z axis
                  ; generated by RepRapFirmware Configuration Tool on Wed Sep 19 2018 21:12:53 GMT+0200 (MitteleuropƤische Sommerzeit)
                  G29 S2
                  G1 X150 Y100 F25000 ; go to first probe point
                  G30              ; home Z by probing the bed
                  G91
                  G1 Z20 F2500
                  G90              ; absolute positioning
                  G1 X0 Y-40 F25000
                  homeu.g:
                  ; homeu.g
                  ; called to home the U axis (coupler)
                  ;crashu
                  G92 U500
                  M913 U40
                  G1 U-500 F2400
                  M400
                  M913 U100
                  G1 U1 F5000
                  G92 U0
                  ;Open Coupler
                  M98 P"/macros/Toolhead/1. Toolhead unlock"
                  homev.g:
                  G91
                  M913 V70		; drop motor currents to 50%
                  G1 H1 V-50 F1000 	; move left 400mm, stopping at the endstop
                  G4 P100
                  G1 V2 F600
                  M913 V100 		; motor currents back to 100%
                  homew.g:
                  G91
                  M913 W70		; drop motor currents to 50%
                  G1 H1 W-50 F1000 	; move left 400mm, stopping at the endstop
                  G4 P100
                  G1 W2 F600
                  M913 W100 		; motor currents back to 100%
                    A Former User @wilriker
                    Ditto. I notice hes using a Duex5 - are you? I'm not.
                    smoki3undefined wilrikerundefined 2 Replies Last reply Reply Quote 0
                    • smoki3undefined
                      Maybe it also make a difference if you have just 4 Motor drivers active. I actually have all 10 drivers active
                        if you upload a sliced file we could test if it is the config or physical presence that makes a difference (if either). running just your config doesn't seen to be a problem with or without Vin, but my simulation doesn't use multiple tools.
                        • smoki3undefined
                          Without the duex5 you should get a lot of errors that the motor drivers are not connected. My test file also was just one tool head.
                          • wilrikerundefined
                            wilriker @A Former User
                            No, I'm not but since the reason so far is that it's caused by interrupts clashing somehow having to handle more interrupts when DueX5 is connected will probably even worsen the situation.
                            No, it's not even having the drivers active but in a powered state, i.e. input voltage is > ~10V . Whenever this state is detected it will enable an interrupt to receive data from the drivers. On my setup without DueX5 and without stallGuard I can solve the issue of flashing by just disabling the corresponding interrupt handler in the preparation steps for flashing. But of course this cannot be done in regular printer use.
                            Manuel
                            My Tool Collection
                            • JoergS5undefined
                              JoergS5 @wilriker
                              I always wanted to know but did not find the answer yet, but you may know: is the interrupt request lost then or is it queued?
                              • wilrikerundefined
                                wilriker @JoergS5
                                @JoergS5 TBH I am not 100% certain but my understanding is that if the IRQ handler is disabled there is no one interested in this event and then it's discarded. Also since interrupts are high priority "look at me NOW!" events I don't think it would even make sense to queue them.
                                Manuel
                                My Tool Collection
                                • JoergS5undefined
                                  JoergS5 @wilriker
                                  @wilriker thank you! I feared it. I am currently reading books about Cortex MCUs, but this question is not answered yet.
                                  • wilrikerundefined
                                    wilriker @JoergS5
                                    @JoergS5 I would assume that this behavior is not limited to microcontrollers but due to the NOW!-nature of interrupts it doesn't make sense on any platform to store them - I imagine this similar to dropping broken/not-fetched-in-time frames in video playback since it would not make sense to insert them at a later point in the stream.
                                    Manuel
                                    My Tool Collection
                                    • JoergS5undefined
                                      JoergS5 @wilriker
                                      @wilriker the Cortex interrupts can nest, ie a higher priority can interrupt an interrupt, the original one proceeding after. I ask because in RRF is a place with interrupt disabled with the comment to hold execution time as short as possible. Makes sense then.
                                      • wilrikerundefined
                                        wilriker @JoergS5
                                        @JoergS5 Oh, you mean when there actually are handlers for different interrupts. I thought you were talking about what happens when the interrupt handler is disabled. Misunderstanding. 🤦
                                        That's actually a field of learning for me still, too.
                                        But more relevant to this topic again: it's not simply interrupts clashing but interrupts also using DMA. So there are multiple priorities to juggle.
                                        Manuel
                                        My Tool Collection
                                        • JoergS5undefined
                                          JoergS5 @wilriker
                                          @wilriker no, you understood me correctly, I meant it the way you answered.
                                          I was talking about nested interrupts (NVIC) only because they are in a sense a queuing mechanism, because if a higher interrupt comes, the interrupt which is running is saved and later proceeded.
                                          • smoki3undefined
                                            smoki3
                                            I give up!
                                            I can not get any stable connection between my raspberry and the duet.
                                            I tried different cables, removed all high current wires in the near of the raspberry. Connected every GND Pin directly to my Power Supply.
