    Duet 3 SBC Low voltage
    • mrenz999undefined
      mrenz999
      I keep getting a low voltage symbol (Lightening bolt)
      on my screen. I do run a small monitor from the raspberry pi. It has it's own power source. Should I plug in the raspberry pi to it's own power source ? Raspberry pi 4.
      • evomotorsundefined
        evomotors
        RPi4 requires 3A supply. I believe Duet 3 does not provide enough current. I had the same issue and had to use dedicated power supply to power RPi.
        Hope this helps.
