    Automatic Bed Leveling with Conditional Gcode Iterations
    Gcode meta commands
    6.5k
    • mwolterundefined
      mwolter @Kolbi
      @Kolbi looks good! Is that SLS or MJF printed?
      Kolbiundefined 1 Reply Last reply Reply Quote 0
      • Kolbiundefined
        Kolbi @mwolter
        @mwolter It was done on an HP Multijet Fusion (MJF), using Nylon PA12.
          A Former User @mwolter
          @mwolter said in Automatic Bed Leveling with Conditional Gcode Iterations:
          If the command G90 G1 Z20 is used in one line, does G91 have to be used to return to absolute mode?
          yes, g-code knows nothing about white space or line breaks
          (optionally you can use push and pop, M120, M121)
          Kolbiundefined 1 Reply Last reply Reply Quote 1
          • fcwiltundefined
            fcwilt @mwolter
            @Phaedrux If the command G90 G1 Z20 is used in one line, does G91 have to be used to return to absolute mode?
            G90 is absolute, G91 is relative.
            mwolterundefined 1 Reply Last reply Reply Quote 0
            • mwolterundefined
              mwolter @fcwilt
              @fcwilt
              That’s why I used that command. Pulled that command from another macro and couldn’t remember why it was created. It’s used to move some amount from the current position without needing to bounce back and forth from absolute to relative and back to absolute positioning.
              • fcwiltundefined
                fcwilt @mwolter
                @fcwilt
                But there is no reason not to make use of the two positioning modes, there is no downside to using them.
                There is nothing to be gained by emulating relative mode using the object model as you are doing.
                • Kolbiundefined
                  Kolbi @A Former User
                  @bearer said in Automatic Bed Leveling with Conditional Gcode Iterations:
                  @bearer I read the gcode manual but these two functions still made little sense to me - best I can derive is a save state / restore state? Could you expand a little on these and give me some use examples?
                  Many thanks,
                  Kolbi
                    A Former User @Kolbi
                    @Kolbi does https://forum.duet3d.com/topic/17854/retrieve-the-position-of-an-axis/5?_=1596130135808 help?
                    • Kolbiundefined
                      @bearer Maybe because I just woke or hadn't gone on my run yet - but it is not completely crystal clear to me. Given the example below:
                      M120              ;push
                      G91               ; relative positioning
                      G0Z30             ; move Z 30mm
                      M121              ;pop
                      I gather that 'M120; push' saves the current kinematic control state, then the user issues G91 & G0Z30 to relatively move the Z axis, and then returns to the previous control state by issuing an M121 - meaning that no M90 command was needed as M121 sorted that out?
                        @Kolbi said in Automatic Bed Leveling with Conditional Gcode Iterations:
                        yes - but more importantly if you for reasons unknown already were in relative mode you would not return to absolute in error.
                        • Kolbiundefined
                          Kolbi
                          @bearer Ah ok - thanks! Besides rel/nonrel state changes - what would be an additional use case?
                            @Kolbi ref M120 docs; i only used for absolute/relative and feedrate
                            • Kolbiundefined
                              @bearer Thanks! I'll read the docs again and go for a run to let it soak in.
                              • Kolbiundefined
                                If I'm understanding correctly; If you are in currently in relative positioning and then you issue a G91 again - it would toggle, putting you in absolute positioning?
                                • fcwiltundefined
                                  fcwilt @Kolbi
                                  G90 sets the mode to absolute. Sending it again changes nothing.
                                  G91 sets the mode to relative. Sending it again changes nothing.
                                  • Kolbiundefined
                                    Kolbi @fcwilt
                                    Ok, rgr that. So given the following:
                                    M120: Push
                                    Example
                                        M120
                                    Push the state of the machine onto a stack. Called automatically when a macro file is run. It pushes the following values on the stack:
                                        Current feedrate
                                        Extruder positions
                                        Whether moves (and separately extrusion) are relative or absolute
                                    M121: Pop
                                    Example
                                        M121
                                    Recover the last state pushed onto the stack.
                                    Could use M120 before issuing any homing related current/sensing changes and then instead of changing them all back via individual commands - just use M121? I'm thinking no, but figure it doesn't hurt to ask.
                                    I guess what I'm trying to figure out and ask is, what exactly is saved in the 'stack'? Also, the documentation states that M120 is called automatically when a macro file is run - I assume this means any gcode file that resides in the macros directory and that this would not apply to files in the sys directory?
                                    BTW, @fcwilt & @bearer Thanks for helping me understand this.
                                    • Kolbiundefined
                                      Kolbi
                                      ...Maybe if I get one of these, all will be clear 😂
                                      • fcwiltundefined
                                        fcwilt @Kolbi
                                        @Kolbi
                                        I've never used Push & Pop.
                                        Yes there are places where I switch to relative (G91) and shortly thereafter switch back to absolute (G90) but not that many places, primarily in the homing macros.
                                        If you were to look at all of the .g files in my sys directory the numbers of G90s or G91s would be small in comparison with all the other code.
                                        I've simply never worried about it - I use them as needed.
                                        • Kolbiundefined
                                          Kolbi @fcwilt
                                          Thanks @fcwilt, much like what you have stated - I have never used M120/1 and haven't had any issues.
                                          But on the other side of the coin, it makes me wonder if I could/should be doing things better by employing it's use? It seems to me, with my limited duet experience, that such command would be most usefully employed by a macro being called while performing an actual print, so that the desired settings set by the slicer would 'pick up where the macro leaves off' & not so important while performing homing evolutions before a print is started.
                                          • fcwiltundefined
                                            fcwilt @Kolbi
                                            @Kolbi
                                            I don't rely on the commands my slicer sets at the beginning of a print.
                                            Here is my "print begin" macro called by the slicer at the beginning of a print.
                                            None of those slicer commands matter because my code overrides them all.
                                            ; S3D inserts the following 5 lines of code just before calling this file
                                            ;G90                                            ; absolute XYZ moves
                                            ;M83                                            ; relative E moves
                                            ;M106 S0                                        ; fan off
                                            ;M140 S60                                       ; bed temp to 60
                                            ;M104 S190 T0                                   ; extruder temp to 190
                                            M98 P"test_if_homed.g"				; aborts print if not homed
                                            T0                                              ; select tool 0 so extruder commands below will work
                                            M703                                            ; configure selected filament (sets bed/extruder temps)
                                            M106 P2 S255                                    ; lights on
                                            M106 P3 S255                                    ; lights on
                                            M106 P4 S255                                    ; lights on
                                            G90                                             ; absolute moves
                                            G1 Z75      F1200                               ; position for cleaning
                                            G1 X0 Y-145 F6000                               ; position for cleaning
                                            M291 R"Heating Extruder/Bed" P"Please wait..." T0
                                            M116                                            ; wait for temps to reach set points
                                            M291 R"Priming Extruder" P"Please wait..." T0
                                            G92 E0                                          ; reset the extruder logical position
                                            M83                                             ; extruder relative mode
                                            G1  E10 F120                                    ; prime the extruder
                                            M400                                            ; wait for extruding to finish
                                            M291 R"Clean Nozzle and Bed" P"Click OK to begin printing" S3
                                            M98 P"mesh_comp_map_load.g"                     ; load height map based on height map mode
