    Automatic Bed Leveling with Conditional Gcode Iterations
    Gcode meta commands
    6.6k
      Phaedrux Moderator @fcwilt
      @fcwilt said in Automatic Bed Leveling with Conditional Gcode Iterations:
      I think you will find that a G91 G1 Z20 will raise Z by 20 unless it doesn't have that much room left of the axis.
      Correct. G90 moves to an absolute point, G91 is relative to the current position.
      https://duet3d.dozuki.com/Wiki/Gcode#Section_G90_Set_to_Absolute_Positioning
      mwolterundefined 1 Reply Last reply Reply Quote 1
      • mwolterundefined
        mwolter @Phaedrux
        @Phaedrux If the command G90 G1 Z20 is used in one line, does G91 have to be used to return to absolute mode?
        Phaedruxundefined A Former User? fcwiltundefined 3 Replies Last reply Reply Quote 1
          Phaedrux Moderator @mwolter
          @mwolter That's a good question, and I'm not sure off the top of my head. Would have to test to see if it sticks in that format or not.
          • Kolbiundefined
            Kolbi
            Another thing I noticed is repeatability with PindaV2 probe is not as consistent as BLTouchV3.1... So being that I use a bondtech bmg mosquito, I've made this modified version to scrap the Pinda and welcome the BLTouch. Will get it sorted on the printer and test it fully this weekend.
            mwolterundefined 1 Reply Last reply Reply Quote 0
            • mwolterundefined
              mwolter @Kolbi
              @Kolbi looks good! Is that SLS or MJF printed?
              Kolbiundefined 1 Reply Last reply Reply Quote 0
              • Kolbiundefined
                Kolbi @mwolter
                @mwolter It was done on an HP Multijet Fusion (MJF), using Nylon PA12.
                  A Former User @mwolter
                  @mwolter said in Automatic Bed Leveling with Conditional Gcode Iterations:
                  yes, g-code knows nothing about white space or line breaks
                  (optionally you can use push and pop, M120, M121)
                  Kolbiundefined 1 Reply Last reply Reply Quote 1
                  • fcwiltundefined
                    fcwilt @mwolter
                    G90 is absolute, G91 is relative.
                    • mwolterundefined
                      mwolter @fcwilt
                      @fcwilt
                      That’s why I used that command. Pulled that command from another macro and couldn’t remember why it was created. It’s used to move some amount from the current position without needing to bounce back and forth from absolute to relative and back to absolute positioning.
                      • fcwiltundefined
                        fcwilt @mwolter
                        @fcwilt
                        But there is no reason not to make use of the two positioning modes, there is no downside to using them.
                        There is nothing to be gained by emulating relative mode using the object model as you are doing.
                        • Kolbiundefined
                          Kolbi @A Former User
                          @bearer said in Automatic Bed Leveling with Conditional Gcode Iterations:
                          @bearer I read the gcode manual but these two functions still made little sense to me - best I can derive is a save state / restore state? Could you expand a little on these and give me some use examples?
                          Many thanks,
                          Kolbi
                            A Former User @Kolbi
                            @Kolbi does https://forum.duet3d.com/topic/17854/retrieve-the-position-of-an-axis/5?_=1596130135808 help?
                            • Kolbiundefined
                              @bearer Maybe because I just woke or hadn't gone on my run yet - but it is not completely crystal clear to me. Given the example below:
                              M120              ;push
                              G91               ; relative positioning
                              G0Z30             ; move Z 30mm
                              M121              ;pop
                              I gather that 'M120; push' saves the current kinematic control state, then the user issues G91 & G0Z30 to relatively move the Z axis, and then returns to the previous control state by issuing an M121 - meaning that no M90 command was needed as M121 sorted that out?
                                @Kolbi said in Automatic Bed Leveling with Conditional Gcode Iterations:
                                yes - but more importantly if you for reasons unknown already were in relative mode you would not return to absolute in error.
                                • Kolbiundefined
                                  Kolbi
                                  @bearer Ah ok - thanks! Besides rel/nonrel state changes - what would be an additional use case?
                                    @Kolbi ref M120 docs; i only used for absolute/relative and feedrate
                                    • Kolbiundefined
                                      @bearer Thanks! I'll read the docs again and go for a run to let it soak in.
                                      • Kolbiundefined
                                        If I'm understanding correctly; If you are in currently in relative positioning and then you issue a G91 again - it would toggle, putting you in absolute positioning?
                                        • fcwiltundefined
                                          fcwilt @Kolbi
                                          G90 sets the mode to absolute. Sending it again changes nothing.
                                          G91 sets the mode to relative. Sending it again changes nothing.
                                          • Kolbiundefined
                                            Kolbi @fcwilt
                                            Ok, rgr that. So given the following:
                                            M120: Push
                                            Example
                                                M120
                                            Push the state of the machine onto a stack. Called automatically when a macro file is run. It pushes the following values on the stack:
                                                Current feedrate
                                                Extruder positions
                                                Whether moves (and separately extrusion) are relative or absolute
                                            M121: Pop
                                            Example
                                                M121
                                            Recover the last state pushed onto the stack.
                                            Could use M120 before issuing any homing related current/sensing changes and then instead of changing them all back via individual commands - just use M121? I'm thinking no, but figure it doesn't hurt to ask.
                                            I guess what I'm trying to figure out and ask is, what exactly is saved in the 'stack'? Also, the documentation states that M120 is called automatically when a macro file is run - I assume this means any gcode file that resides in the macros directory and that this would not apply to files in the sys directory?
                                            BTW, @fcwilt & @bearer Thanks for helping me understand this.
