G32 Error:´´ Z probe was not triggered during probing move´´
Firmware installation
4.6k
    dutti @fcwilt
    @fcwilt
    ok. I´m sry
      dutti @fcwilt
      @fcwilt
      Removing M401- M402 is not working
        But it works for homeall? Or a single g30?
        undefined 1 Reply Last reply 31 Jul 2020, 22:33 Reply Quote 0
          dutti @Phaedrux
          @Phaedrux
          yes... but only one time. z probe is triggering but then flashing and not moving any more (m402/m401). when I reconnect the BL is working fine... for one time.
          When using G32 after the first probe happnes the same but with -->´´z-probe-was-not-triggered-during-probing-move´´
            fcwilt
            So if you reset the firmware, home everything, move to the center of the bed and do a single G30 the probe pin drops, retracts but then begins to flash?
            Is that correct?
            undefined 1 Reply Last reply 31 Jul 2020, 22:49 Reply Quote 0
              dutti @fcwilt
              @fcwilt
              hmm yes... retract --> bl touches the bed --> bed stops as usual -- flashing and no deploy.
                dutti
                after reconnect the bl - touch. m401 / m402 are working normally
                undefined 1 Reply Last reply 31 Jul 2020, 22:51 Reply Quote 0
                  fcwilt @dutti
                  @barbarossa-cologne said in G32 Error:´´ Z probe was not triggered during probing move´´:
                  So your problem is solved?
                  undefined 1 Reply Last reply 31 Jul 2020, 22:53 Reply Quote 0
                    dutti @fcwilt
                    @fcwilt
                    no 😕
                    after the flashing begins I have to reconnect the Bl Touch to do a sinlge probe.
                    everytime.....
                    undefined 1 Reply Last reply 31 Jul 2020, 22:55 Reply Quote 0
                      dutti @dutti
                      @barbarossa-cologne
                      retract --> bl touches the bed --> bed stops as usual -- flashing and no deploy --> reconnect cable --> working fine till the first probe -->
                      undefined 1 Reply Last reply 31 Jul 2020, 23:11 Reply Quote 0
                        fcwilt @dutti
                        @barbarossa-cologne
                        When you say "retract" do you mean the pin is DOWN or UP?
                        If the BLTouch has a problem when probing it starts to flash and nothing more can be done with it until the error condition is reset.
                        Executing a M280 P0 S160 command should clear the error condition.
                        undefined 2 Replies Last reply 31 Jul 2020, 23:13 Reply Quote 0
                          dutti @fcwilt
                          @fcwilt
                          retract means the pin goes down.
                          hmm ok
                          what can it be?
                          undefined 1 Reply Last reply 31 Jul 2020, 23:18 Reply Quote 0
                            dutti @fcwilt
                            M280 P0 S160 is working.. now the question is what makes this problem ´..
                              fcwilt @dutti
                              @fcwilt
                              hmm ok
                              what can it be?
                              OK we have a word problem.
                              DEPLOY means lower the pin. RETRACT means raise the pin.
                              So the M401 command should lower the pin and the M402 command should raise the pin
                              Is that happening?
                              undefined 1 Reply Last reply 31 Jul 2020, 23:20 Reply Quote 1
                                dutti @fcwilt
                                @fcwilt
                                ok I´m sry for that..
                                yes. It works (till the first probe point touches the Bl)
                                undefined 1 Reply Last reply 31 Jul 2020, 23:22 Reply Quote 0
                                  fcwilt @dutti
                                  @fcwilt
                                  SO if the printer is just sitting there doing nothing and the BLTouch is far enough away from the bed so that the pin won't touch if it drops can you repeatedly raise and lower the pin using M401/M402 commands without any errors?
                                  undefined 1 Reply Last reply 31 Jul 2020, 23:23 Reply Quote 0
                                    dutti @fcwilt
                                    @fcwilt
                                    yes..
                                    undefined 1 Reply Last reply 31 Jul 2020, 23:26 Reply Quote 0
                                      fcwilt @dutti
                                      @fcwilt
                                      yes..
                                      OK good.
                                      When the problem occurs is the pin hitting the bed when it tries to drop?
                                      IF that happens it will cause an error.
                                      The pin needs to be all the way down BEFORE the bed moves to touch the pin.
                                      undefined 1 Reply Last reply 31 Jul 2020, 23:28 Reply Quote 0
                                        dutti @fcwilt
                                        @fcwilt
                                        No. There is almost 1cm between the pin and the bed.
                                        undefined 1 Reply Last reply 31 Jul 2020, 23:32 Reply Quote 0
                                          fcwilt @dutti
                                          @fcwilt
                                          SO the pin drops, does NOT touch the bed before it should, the bed moves towards the pin, touches the pin and THEN the error occurs?
                                          13 out of 95
