    Automatic Bed Leveling with Conditional Gcode Iterations
    Gcode meta commands
    6.9k
    • fcwiltundefined
      fcwilt @A Former User
      @bearer said in Automatic Bed Leveling with Conditional Gcode Iterations:
      there is also this overview https://duet3d.dozuki.com/Wiki/Macros#Section_System_Macros
      Thanks - I had not seen that.
        I use start.g for general print prep. Homing, preheat. Then it passes off to the slicer for setting the temps for the print. Then in the slicer start gcode section it calls a macro to print a prime line and then start the print. I do it this way so that the prime line is printed at the right temp for the material being used.
        The slicer end gcode just contains M0 and then stop.g has all of the actual end of print commands.
        I kind of wish there was just an end.g that could take the place of M0 -> stop.g
        • fcwiltundefined
          fcwilt @Phaedrux
          @Phaedrux said in Automatic Bed Leveling with Conditional Gcode Iterations:
          As you may have noticed in my print_begin.g macro I rely on the filament feature to set bed/filament temps.
          I do wait for the temps to be reached before starting to print. I don't know what a "prime line" is - I just print a 2 line skirt so I can watch to see how the first layer is going down and adjust baby-stepping or abort, as needed.
            Phaedrux Moderator @fcwilt
            @fcwilt said in Automatic Bed Leveling with Conditional Gcode Iterations:
            "prime line"
            In my case:
            ;M98 P"0:/sys/PrimeNozzle.g"
            G90 			; Absolute positioning
            G1 X1 Y270 F6000 	; Move to rear left corner
            M400 			; clear movement buffer
            M116 			; Wait for temps
            G1 Z0.3 F100		; Move Z to prime height
            G91 			; Relative positioning
            M83 			; Relative extrusion
            G1 X40 E10 F300 	; Prime nozzle
            G10			; Retract
            G1 Y-1 X1 F10000 	; Wipe nozzle
            M400
            And start.g since we're being transparent.
            M106 P2 F30000 S0.5 H-1 C"Duet Fans"
            M140 S65		; set heated bed to 65 and release
            T0			; Select Tool 0
            M291 P"Print Started. Preheating and Homing." T10
            G4 S1
            M98 P"0:/macros/Musical Tunes/LuckyTune.g" ; Lucky tune to start print off on the right foot
            G4 S1
            M220 S100		; Set speed factor back to 100% in case it was changed
            M221 S100		; Set extrusion factor back to 100% in case it was changed
            M290 R0 S0		; clear babystepping
            M106 S0			; Turn part cooling blower off if it is on
            G10 P0 R0 S80		; Set extruder to 80 and release
            M190 S65		; set heated bed to 65 and wait
            G28			; home XYZ
            G29 S1			; load heightmap
            M400
            G10 P0 R80 S180	; Set extruder to 180 and release
            M98 P"0:/sys/ZSpeedsPrint.g"	; Load Z speeds for printing
            M98 P"0:/sys/CurrentsPrint.g"	; Load print motor currents
            ; Slicer Start Gcode begins.
            and stop.g for the hell of it.
            ; stop.g
            ; called when M0 (Stop) is run (e.g. when a print from SD card is cancelled)
            ; Also called by slicer end gcode by M0
            M400			; Finish move queue
            M104 S0 		; Extruder heater off
            M140 S0 		; Bed heater off
            M106 S255 		; Fan at 100 to cool nozzle and bed
            G1 E-2 F9000			; Retract filament 2mm
            G1 X5 Y5 F9000		; Wipe nozzle
            G1 Z20 F500			; raise nozzle 5mm from printed part
            G90				; absolute positioning
            G1 X150 Y130 F6000		; Move x and Y axis over to bed center so probe is on top of bed
            ;M104 S35		; Set hot end low and wait
            G4 S60			; Wait 5 minutes
            ;M116			; wait for temp to drop
            G28 X Y			; Home X and Y
            G28 X Y			; Home it again, Sam.
            M84			; Steppers off
            M98 P"ZSpeedsNormal.g"	; Load normal z speed settings again.
            M106 S0			; Fan off
            M106 P2 F30000 L0.1 X0.8 B0.5 T35:70 H100:101:102 C"Duet Fans"
            ;Play a little beep beep beep to show print ended.
            M400			; Clear queue again before jingle
            G4 S1
            M300 P250 S750
            G4 P251
            M300 P200 S1250
            G4 P201
            M300 P250 S750
            G4 P251
            M300 P200 S1250
            G4 P201
            M300 P250 S2500
            G4 P251
            M300 P150 S2000
            G4 P151
            M300 P150 S2500
            G4 P151
            M300 P350 S3700
            G4 P351
            Kolbiundefined 1 Reply Last reply Reply Quote 2
            • Kolbiundefined
              Kolbi @Phaedrux
              @Phaedrux Thanks for sharing. Do you use filament/config.g or just use slicer start code?
                Phaedrux Moderator @Kolbi
                @Kolbi said in Automatic Bed Leveling with Conditional Gcode Iterations:
                I haven't used the filaments function for a long time. I use prusa slicer and cura interchangeably. I use prusa slicer for the filaments library and refer to it when I'm setting up a print in Cura.
                • Kolbiundefined
                  Kolbi
                  @Phaedrux As of thus far, me too. For some reason, it feels a bit to foreign to me to offload stuff from the slicer's start and end code spots. I do plan to slowly start migrating stuff over but only after I have everything else on point.
                  fcwiltundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                  • Kolbiundefined
                    Kolbi
                    @Phaedrux For prime line I made a crude random(ish) number generator to not get a 'prime line gutter' on my plates. It gives a numeric swing of 9 to -9.
                    floor(10*(cos(sqrt(sensors.analog[0].lastReading * state.upTime))))
                    So for the prime line, it would be (using Y as an example / with a .1mm randomness, targeted at -2):
                    Before:
                    G1 X0 Z0.6 Y-3.0 F3000.0;
                    After:
                    G1 X0 Z0.6 Y{-2+(0.1*(floor(10*(cos(sqrt(sensors.analog[0].lastReading * state.upTime))))))} F3000.0;
                    So my use is to have the M98 P"0:/sys/PrimeLine.g" called after temps are set and obtained by the slicer's gcode.
                    ;M98 P"0:/sys/PrimeLine.g"
                    ;This sets up the prime to be initiated at a 'randomized' Y positon from -1.1 to -2.9
                    G92 E0.0
                    G1 Z0.2 X100.0 E30.0 F1000.0 ; prime line
                    G92 E0.0
                    • fcwiltundefined
                      fcwilt @Kolbi
                      My goal was to have as little filament related items (like temps) in the slicer since I hoped to avoid going back to the slicer to generate a new gcode file just to change a temp.
                      So far that approach is working for me.
                      YMMV.
                      Good luck.
                      Kolbiundefined 1 Reply Last reply Reply Quote 1
                      • Kolbiundefined
                        Kolbi @fcwilt
                        @fcwilt That is my eventual goal also, but because from within the slicer - I use inner-slicer variables, that portion would get somewhat lost?
                        I'm slowly brain-storming different ways to skin-the-cat, but as of this moment, it feels like I happen to be dealing with skinning Schrödinger's cat.
                        • fcwiltundefined
                          fcwilt @Kolbi
                          @fcwilt I use inner-slicer variables, that portion would get somewhat lost?
                          I have not found that to be a problem - yet. What variables do you use?
                          Hard to skin a cat that won't stay in one place.
                          • Kolbiundefined
                            Kolbi
                            Mostly the temps for hotend and bed.
                            While I do use the filament option in duet/dwc to get me to the overall-generic temp for the chosen/loaded filament type, I still use the slicer to vary the temps for each different brand/batch of the filament within the choose type range. I'll most likely use the start.g script to do most of the setup and prime line, then the slicer start-gcode could bring the temps to the exact settings, and then start printing. This would simplify switch between slicers and give a one-stop-shop to adjust the starting sequence as needed.
                            Cheers,
                            Kolbi
                            • fcwiltundefined
                              fcwilt @Kolbi
                              @Kolbi
                              Thanks for the info.
                              I make an filament entry in the DWC for each filament brand/kind/color that I find needs different settings. Currently the settings that I control in the config file for each filament are the temps and the extrusion multiplier.
                              My goal was to allow using different slicers with as little duplication as possible by moving what I can to the Duet.
                              In the three slicers I use they each call two macros "print_begin.g" and "print_end.g"
                              I tried using start.g but it is called before the slicers set temps whereas the locations in the slicer to call "print_begin.g" happen just before the gcode that actually prints the object. So my filament config files get to override any slicer temp settings.
                              • Kolbiundefined
                                Kolbi @fcwilt
                                @fcwilt All makes sense. I guess it just goes back to cats, preference to work-flow, and ingrained habit.
                                Cheers,
                                Kolbi
                                • fcwiltundefined
                                  fcwilt @Kolbi
                                  Cheers,
                                  Kolbi
                                  I'm a dog person myself. They don't insist on hiding their location. 😉
                                  • Kolbiundefined
                                    Kolbi
                                    @fcwilt Me too - that's why I only talk about skinning cats 😂
                                    • Kolbiundefined
                                      Kolbi
                                      @fcwilt , @Phaedrux , @bearer
                                      During the day's events, I thought of the above conversations and formulated and blend of both ways (dwc/slicer stop/stop gcodes) to handle filament specific settings. I just made the following setups - all is working very well. It is very basic/generic but will grow from here.
                                      Let me know any thoughts.
                                      /sys/start.g:
                                      ; 0:/sys/start.g
                                      ; Executed before each print - BEFORE ANY SLICER CODE IS RAN
                                      ; This also loads the heightmap from the system's set filament type directory
                                      ; (0:/filaments/XXXX/heightmap.csv), if the heightmap does not exist, it will
                                      ; create one, and then save in the filament's directory. The HotMesh macro is
                                      ; a better choice to generate the heightmap as it performs a heat stabilization
                                      ; routine for ~5 minutes.
                                      M122                                                       ; Clear diagnostic data to cleanly capture print evolution statistics.
                                      T0                                                         ; Ensure the tool is selected.
                                      M280 P0 S160                                               ; BLTouch, alarm release.
                                      G4 P100                                                    ; BLTouch, delay for the release command.
                                      M572 D0 S0.0                                               ; Clear pressure advance.
                                      M220 S100                                                  ; Set speed factor back to 100% in case it was changed.
                                      M221 S100                                                  ; Set extrusion factor back to 100% in case it was changed.
                                      M290 R0 S0                                                 ; Clear any baby-stepping.
                                      M106 S0                                                    ; Turn part cooling blower off if it is on.
                                      M703                                                       ; Execute loaded filament's config.g.
                                      G28                                                        ; Home all.
                                      ;G1 Z5 X100 Y100                                           ; [PINDA] Place nozzle center of the bed, 5mm up.
                                      G1 Z160 F300                                               ; [BLTouch] Last chance to check nozzle cleanliness.
                                      M300 S4000 P100 G4 P200 M300 S4000 P100                    ; Give a double beep.
                                      M116                                                       ; Wait for all temperatures.
                                      M300 S4000 P100                                            ; Give a single beep.
                                      ; [BLTouch] Start countdown - use Z as indicator
                                      G91                                                        ; [BLTouch] Set to Relative Positioning.
                                      while iterations <=9                                       ; [BLTouch] Perform 10 passes.
                                          G4 S12                                                 ; [BLTouch] Wait 12 seconds.
                                          G1 Z-15 F300                                           ; [BLTouch] Move Z 15mm down.
                                      G90                                                        ; [BLTouch] Set to Absolute Positioning.
                                      ;G4 S120                                                   ; [PINDA] wait an additional 2 minutes for the bed to stabilize.
                                      G32                                                        ; Level the gantry.
                                      G29 S1 [P{"0:/filaments/" ^ move.extruders[0].filament ^ "/heightmap.csv"}] ; Load bed mesh for the system's set filament type.
                                      if result > 1                                              ; If the file doesn't exist, perform mesh and save.
                                         G29                                                     ; Perform mesh now.
                                         G29 S3 [P{"0:/filaments/" ^ move.extruders[0].filament ^ "/heightmap.csv"}] ; Save heightmap.csv to filament type's directory.
                                      M400                                                       ; Finish all moves, clear the buffer.
                                      G90                                                        ; Absolute Positioning.
                                      M83                                                        ; Extruder relative mode.
                                      M98 P"0:/sys/current-sense-normal.g"                       ; Ensure that motor currents and sense are set for printing.
                                      G1 X0 Y0 F800                                              ; Final position before slicer's temp is reached and primeline is printed.
                                      G1 Z2 F300                                                 ; Final position before slicer's temp is reached and primeline is printed.
                                      ; The primeline macro is executed by the slicer gcode to enable direct printing.
                                      ; of the primeline at the objects temp and to immediately print the object.
                                      ; following primeline completion.
                                      ; Slicer generated gcode takes it away from here.
                                      /filaments/PETG/config.g
                                      M300 S1000 P200 G4 P500 M300 S3000 P300          ; play some tones
                                      M140 S75                                         ; set bed temp
                                      M104 S150                                        ; set extruder warm-up temp
        ; active temp set from slicer gcode
                                      ; Insert additional filament specific settings here
                                      ideaMaker Start GCode:
                                      ; ideaMaker Start G-Code
                                      ; Layer height={layer_height}                    ; Pass layer height information to DWC
                                      ; Set nozzle and bed to the specific temperatures declared within this slicer
                                      M140 S{temperature_heatbed}                      ; Set bed temp
                                      M104 S{temperature_extruder1}                    ; Set extruder temp
                                      ; Run macro to print primeline at a 'randomized' Y position from -1.1 to -2.9
                                      M98 P"0:/sys/primeLine.g"                        ; Primeline macro
                                      ; Set pressure advance
                                      M572 D0 S0.07                                    ; Set pressure advance
                                      /sys/primeline.g:
                                      ; 0:/sys/primeline.g
                                      ; Print prime-line at a 'randomized' Y position from -1.1 to -2.9
                                      ; Charge! tune
                                      G4 S1
                                      M300 P200 S523.25
                                      G4 P200
                                      M300 P200 S659.25
                                      G4 P200
                                      M300 P200 S739.99
                                      G4 P250
                                      M300 P285 S880.00
                                      G4 P450
                                      M300 P285 S880.00
                                      G4 P285
                                      M300 P625 S1108.73
                                      G4 S1
                                      M400
                                      G92 E0.0                                                   ; Reset the extrusion distance.
                                      G1 E8                                                      ; Purge Bubble.
                                      G1 X60.0 E11.0 F1000.0                                     ; Intro line part 1.
                                      G1 X120.0 E16.0 F1000.0                                    ; Intro line part 2.
                                      G1 X122.0 F1000.0                                          ; Wipe 2mm of filament.
                                      ideaMaker/S3D/PS End GCode:
                                      ; ideaMaker End G-Code
                                      M400                                             ; Make sure all moves are complete
                                      M0                                               ; Stop everything and run sys/stop.g
                                      /sys/stop.g:
                                      ; 0:/sys/stop.g
                                      ; Called when M0 (Stop) is run (e.g. when a print from SD card is canceled)
                                      M83                                                        ; Set extruder to relative mode.
                                      M106 S255                                                  ; Turn the part cooling fan fully on.
                                      M220 S100                                                  ; Set the speed factor back to 100% incase it was changed.
                                      M221 S100                                                  ; Set the extrusion factor back to 100% incase it was changed.
                                      G1 E-2                                                     ; Retract 2mm of filament.
                                      M104 S-273                                                 ; Turn off the hotend.
                                      M140 S-273                                                 ; Turn off the heatbed.
                                      G1 F1000.0                                                 ; Set feed rate.
                                      M98 P"current-sense-homing.g"                              ; Adjust the current and sensitivity for homing routines.
                                      ; Let cool and wiggle for bit to reduce end stringing
                                      G91                                                        ; Set to Relative Positioning.
                                      G1 Z2 F400                                                 ; Move Z axis up 3mm.
                                      ; Start countdown - use X/Y as indicators of counting
                                      while iterations <=9                                       ; Perform 10 passes.
                                          G4 S6                                                  ; Wait 6 seconds.
                                          G1 X1 Y1 F1000                                         ; Wiggle +1mm.
                                          G1 Z0.5 X-1 Y-1 F1000                                  ; Wiggle -1mm, Z +0.5.
                                      G90                                                        ; Set to Absolute Positioning.
                                      G1 X220 Y205 Z205 F400                                     ; Place nozzle to the right side, build plate to front, Z at top.
                                      M107                                                       ; Turn off the part cooling fan.
                                      M18 YXE                                                    ; Unlock the X, Y, and E axis.
                                      ; Play a triumphant tune to celebrate a successful print.
                                      G4 S1
                                      M300 P250 S750
                                      G4 P251
                                      M300 P200 S1250
                                      G4 P201
                                      M300 P250 S750
                                      G4 P251
                                      M300 P200 S1250
                                      G4 P201
                                      M300 P250 S2500
                                      G4 P251
                                      M300 P150 S2000
                                      G4 P151
                                      M300 P150 S2500
                                      G4 P151
                                      M300 P350 S3700
                                      G4 P351
                                      Simplify3D Start GCode:
                                      ; Simplify3D Start G-Code
                                      M140 S[bed0_temperature]                         ; set bed temp
                                      M104 S[extruder0_temperature]                    ; set extruder temp
                                      M116                                             ; wait for all temperatures
                                      ; Run macro to print primeline at a 'randomized' Y positon from -1.1 to -2.9
                                      M98 P"0:/sys/primeLine.g"                        ; primeline macro
                                      M572 D0 S0.07                                    ; set pressure advance
                                      PrusaSlicer Start GCode:
                                      ; PrusaSlicer Start G-Code:
                                      M140 S[first_layer_bed_temperature]              ; set bed temp
                                      M104 S[first_layer_temperature]                  ; set extruder temp
                                      Cheers,
                                      Kolbi
                                      • fcwiltundefined
                                        fcwilt
                                        Just FYI you don't need both M140 and M190.
                                        They both set the temp and activate the heater.
                                        The difference is that M140 doesn't wait for the temp to be reached whereas M190 does.
                                        The same applies to M104 and M109.
                                        There is also M116. From the docs, M116 by itself it does:
                                        waits for all temperatures and other slowly-changing variables to arrive at their set values.
                                          When you use multiple slicers it makes it a lot easier to manage.
                                          • Kolbiundefined
                                            Kolbi @fcwilt
                                            Thanks @fcwilt! I didn't know I was messing that up. I re-read the gcode documentation on this, I believe the following would be the most efficient.
                                            M116                                             ; waits for all temperatures
