    Feature request: please have M303 printing the recomanded M307.
    Firmware wishlist
    • zaptaundefined
      zapta
      Upon completion of PID tuning, the M303 prints to the console a summary of the PID coefficients.
      Please print also the recommended M307 command. Some of us do not use configoverride.g and edit the M307 command in config.g (with proper github version control).
      E.g.
      Recommended PID parameters: M307 H0 A283.1 C1724.9 D1.6 V24.1 B0
        A Former User
        i think you can just run m307 with no parameters to get it? but its not very intuitive no.
        • zaptaundefined
          zapta @A Former User
          Thanks bearer, I will give it a try next time. This is what the documentations says:
          Alternatively, construct a M307 command with the model parameters and add it to config.g. For example, if after tuning you run M307 H0 and see this:
          M307 H0
          Heater 0 model: gain 199.0, time constant 962.6, dead time 4.5, max PWM 1.00, calibration voltage 12.3
          then you should add the following to config.g to preserve this model:
          M307 H0 A199.0 C962.6 D4.5 V12.3 B0
          Wouldn't it be much easier to just print the recommended M307 command in the first place? 😉
          • fcwiltundefined
            fcwilt @zapta
            @zapta
            I just use M500 to create the entry in config_override.g and copy and paste from there.
            • zaptaundefined
              zapta @fcwilt
              Thanks @fcwilt, I saw your post in the other thread, and then you delete config_override.g. Wouldn't it be easier to just copy/paste from the console?
              • fcwiltundefined
                fcwilt @zapta
                @zapta said in Feature request: please have M303 printing the recomanded M307.:
                Yes it would and I have often wondered why it doesn't work as you suggest.
                  Moved to the wishlist.
