    Duet 3 Tool Board motor driver issue
    490
    • fcwiltundefined
      fcwilt
      Do you have a tool defined?
      evomotorsundefined 1 Reply Last reply Reply Quote 0
      • evomotorsundefined
        evomotors @fcwilt
        @fcwilt said in Duet 3 Tool Board motor driver issue:
        This what I have
        M563 P0 S"Frankenstein" D0 H1 F0 ; define tool 0
        • fcwiltundefined
          fcwilt
          Did you try this from the docs:
          Check that you can communicate with the Tool Board, by sending M115 B121 (if that fails, try M115 B10).
            evomotors @fcwilt
            Communication with board is fine:
            M115 B121
            Board TOOL1LC firmware 3.1.0 (2020-05-15b1)
            Heater and temperature reading also work
            • fcwiltundefined
              fcwilt
              I notice that in the docs for the tool board they suggest using 20 for the first tool board address.
              Perhaps the current firmware has a problem with numbers like 121 for E?
              That, however, seems like grasping at straws.
              How about as a test change Z to just Z0.2 and see what happens?
                evomotors
                Sorry guys, my fault. It's my change filament macro.
                  evomotors
                  This is my first Duet board.
                  • fcwiltundefined
                    fcwilt @evomotors
                    @evomotors said in Duet 3 Tool Board motor driver issue:
                    No problem
                    But could you explain what the macro did that caused the issue?
                      evomotors @fcwilt
                      No problem
                      I had it
                      G28				; home
                      in the filament config.g file
                      • fcwiltundefined
                        fcwilt @evomotors
                        @evomotors
                        Thanks for the reply.
                        As you found out you don't want to do that.
                        Just FYI, the things I set in my filament config files are the hotend temp, bed temp and extrusion multiplier.
