    Duet 3 2 wire Fan
    • rothundefined
      roth
      Hello
      i want to install a 2 wire Fan.
      But i have the Problem the Fan is always on.
      I connect it to GND and V_OUTLC1
      M950 F0 C"out4" Q500                               ; create fan 0 on pin out4 and set its frequency
      M106 P0 S0 H-1                                     ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"out5" Q500                               ; create fan 1 on pin out5 and set its frequency
      M106 P1 S0 H-1                                     ; set fan 1 value. Thermostatic control is turned off
        A Former User
        v_outlc1 is a fixed voltage and ground is a fixed voltage.
        you need to connect the fan between v_outlc1 an out4 to be able to control the fan with M106.
        seems https://duet3d.dozuki.com/Wiki/Connecting_and_configuring_fans isn't updated to reflect the naming of the duet3.
        vfan = v_outlc1
        vfan0- = out4
        CharlesL40undefined 1 Reply Last reply Reply Quote 1
        • rothundefined
          roth
          Thanks works fine.
          pin 2 and last pin.
          • CharlesL40undefined
            CharlesL40 @A Former User
            Thank you, have been looking for this information for a while concerning the V_OUTLC1 pin and wiring of 3 wire fans.
            Charles
