    G32 Error:´´ Z probe was not triggered during probing move´´
    Firmware installation
    4.7k
    • fcwiltundefined
      fcwilt @dutti
      @barbarossa-cologne
      G32 invokes bed.g.
      In bed.g you have G29 S3 with the comment "Clear bed height map".
      You want to use S2 to clear the bed height map.
      See if that makes a difference.
      duttiundefined 2 Replies Last reply Reply Quote 1
      • duttiundefined
        dutti @fcwilt
        @fcwilt thanks... I´ll try!
        • duttiundefined
          dutti @fcwilt
          @fcwilt
          same problem.... with G29 S2.
          Also still a problem: After doing a single z probe, I have to reconnect the BL Touch before it´s working again. When doing G32, it´s doing G29. BUT then the BL is able to make a few probing points without stopping/ flashing.
          I hate the BL haha
          duttiundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
          • duttiundefined
            dutti @dutti
            @barbarossa-cologne
            is that normal.... doing G32 --> but the Duet Made a G29
            • fcwiltundefined
              fcwilt @dutti
              @barbarossa-cologne
              Comment out everything in bed.g and add this M291 P"BED.G" R"BED.G" T0
              From the DWC execute a G32.
              You should get the popup message generated by M291.
              As to the probe working sometimes and not others I would think perhaps the probe needs adjusting or the wiring is being affected by motion due to a bad crimp or almost broken wire.
              https://duet3d.dozuki.com/Wiki/BLTouch_Troubleshooting
              duttiundefined 1 Reply Last reply Reply Quote 1
              • duttiundefined
                dutti @fcwilt
                @fcwilt said in G32 Error:´´ Z probe was not triggered during probing move´´:
                ; bed.g
                ; Called using G32
                ; Called to perform True Autolevel using 4-point probe
                ; generated by RepRapFirmware Configuration Tool v3.1.3 on Tue Jun 23 2020 22:36:44 GMT+0200 (Mitteleuropäische Sommerzeit)
                G29 S2; Clear bed height map
                ; Probe 4-point
                G30 P0 X150 Y135 Z-9999 ; Front Right
                G30 P1 X550 Y135 Z-9999 ; Front Left
                G30 P2 X550 Y565 Z-9999 ; Back Left
                G30 P3 X150 Y565 Z-9999 S4 ; Back Right
                like this?
                what do you mean with execute a G32 in combination of M291?
                sry english is not my mother tongue. to be clear I have to aks. I had to long time problems with the BL.
                Wiring should be fine.. is not the biggest deal at the moment.
                • fcwiltundefined
                  fcwilt
                  English is a problem - understood.
                  OK what I want to be sure is that bed.g is executing and nothing else is happening causing the G29 issue.
                  So I would like you to have in your bed.g file JUST the following - you can delete or comment out everything else
                  M291 P"BED.G is running" R"Click to exit" S1 T0
                  Invoking G32 from the Duet Web Control (DWC) should run bed.g and you should see the popup message and nothing else should happen.
                  As to the height map when you created it using G29 did you first do a G30 ?
                  The purpose of the G30 is to allow the firmware to determine exactly there Z=0 is.
                  • duttiundefined
                    dutti
                    @fcwilt english is fine but especially person from the US or Australia uses expressions which I haven´t learned in school. I have to practice!
                    As to the heatmap.... I made a G32 but the Duet made a G29.
                    Before I made a nomral G30.
                    I know about G30.
                    Invoking G32 let the nozzle move to the first probe point of a G29 command. So the Duet makes a G29 instead of G32. How can so many things be wrong 😞
                    Richard
                    • duttiundefined
                      dutti @fcwilt
                      @fcwilt
                      how can I make a G32 when my bed.g file isn´t there anymore?
                      I thought the software is calculating the high of each probing point in raleation to the leadscrews...
                      • fcwiltundefined
                        fcwilt @dutti
                        @barbarossa-cologne said in G32 Error:´´ Z probe was not triggered during probing move´´:
                        @fcwilt
                        I want you to have a bed.g file but I only want it to contain the M291 command, for now, just as a test.
                        You invoke it with G32 which is access from the Duet Web Control (DWC) on the Dashboard, using the "Compensation and Calibration" drop down menu.
                        Once I am sure that nothing other than beg.g is running in response to G32 then we will insure the normal commands for auto bed leveling are back into bed.g and the M291 is gone.
                        That's why I said you can just comment everything else out and add the single M291 command. Commenting the other lines out will allow you to restore them just by removing the comment character.
                        • duttiundefined
                          dutti
                          ok I understand!
                          so what can I do for the next steps?
                          richard
                          • fcwiltundefined
                            fcwilt @dutti
                            @barbarossa-cologne
                            You mean after I'm sure that bed.g is running and nothing else unexpected happens?
                            duttiundefined 1 Reply Last reply Reply Quote 0
                            • duttiundefined
                              dutti @fcwilt
                              @fcwilt
                              to fix my multiple problems...
                              • fcwiltundefined
                                fcwilt @dutti
                                @barbarossa-cologne
                                I am focusing on just two problems right now.
                                1. Making sure the probe is working.
                                2. Making sure bed.g is working.
                                Anything else you want to work on?
                                • duttiundefined
                                  dutti @fcwilt
                                  @fcwilt
                                  Probe is working.
                                  I don´t know what I have to change in my bed.g file...
                                  you told me you wanna make a test. So I did it.... and now? 😞
                                  I made a G32 and it´s doing a G29. Why? 😕
                                  I just wanna make a 4 point true auto level.... thats the last thing I have to do before printing. SOS
                                  • fcwiltundefined
                                    fcwilt @dutti
                                    @barbarossa-cologne
                                    When you did the G32 did you see the popup message saying beg.g was running?
                                    • duttiundefined
                                      dutti @fcwilt
                                      @fcwilt
                                      drives to the first probe point of mesh compension and --> g32 -->
                                      Error: Z probe already triggered before probing move started
                                      • duttiundefined
                                        dutti
                                        only this message came
                                        • fcwiltundefined
                                          fcwilt @dutti
                                          @fcwilt
                                          And this was with bed.g only having the M291 command?
                                          • duttiundefined
                                            dutti @fcwilt
                                            @fcwilt yes
