    G32 Error:´´ Z probe was not triggered during probing move´´
    Firmware installation
    4.7k
    • fcwiltundefined
      fcwilt @dutti
      @barbarossa-cologne said in G32 Error:´´ Z probe was not triggered during probing move´´:
      @fcwilt
      how can I make a G32 when my bed.g file isn´t there anymore?
      I thought the software is calculating the high of each probing point in raleation to the leadscrews...
      I want you to have a bed.g file but I only want it to contain the M291 command, for now, just as a test.
      You invoke it with G32 which is access from the Duet Web Control (DWC) on the Dashboard, using the "Compensation and Calibration" drop down menu.
      Once I am sure that nothing other than beg.g is running in response to G32 then we will insure the normal commands for auto bed leveling are back into bed.g and the M291 is gone.
      That's why I said you can just comment everything else out and add the single M291 command. Commenting the other lines out will allow you to restore them just by removing the comment character.
      • duttiundefined
        dutti
        ok I understand!
        so what can I do for the next steps?
        richard
        • fcwiltundefined
          fcwilt @dutti
          @barbarossa-cologne
          You mean after I'm sure that bed.g is running and nothing else unexpected happens?
          duttiundefined 1 Reply Last reply Reply Quote 0
          • duttiundefined
            dutti @fcwilt
            @fcwilt
            to fix my multiple problems...
            • fcwiltundefined
              fcwilt @dutti
              @barbarossa-cologne
              I am focusing on just two problems right now.
              1. Making sure the probe is working.
              2. Making sure bed.g is working.
              Anything else you want to work on?
              duttiundefined 1 Reply Last reply Reply Quote 1
              • duttiundefined
                dutti @fcwilt
                @fcwilt
                Probe is working.
                I don´t know what I have to change in my bed.g file...
                you told me you wanna make a test. So I did it.... and now? 😞
                I made a G32 and it´s doing a G29. Why? 😕
                I just wanna make a 4 point true auto level.... thats the last thing I have to do before printing. SOS
                • fcwiltundefined
                  fcwilt @dutti
                  @barbarossa-cologne
                  When you did the G32 did you see the popup message saying beg.g was running?
                  • duttiundefined
                    dutti @fcwilt
                    @fcwilt
                    drives to the first probe point of mesh compension and --> g32 -->
                    Error: Z probe already triggered before probing move started
                    • duttiundefined
                      dutti
                      only this message came
                      • fcwiltundefined
                        fcwilt @dutti
                        @fcwilt
                        And this was with bed.g only having the M291 command?
                        • duttiundefined
                          dutti @fcwilt
                          @fcwilt yes
                          • fcwiltundefined
                            fcwilt @dutti
                            @fcwilt yes
                            And you didn't see the popup message about bed.g running?
                            • duttiundefined
                              dutti @fcwilt
                              @fcwilt no. just the message you see on the screenshot.
                              • fcwiltundefined
                                fcwilt @dutti
                                @barbarossa-cologne
                                Do you know how to enter commands directly into Duet Web Control using the Console page?
                                • duttiundefined
                                  dutti @fcwilt
                                  @fcwilt yes
                                  • fcwiltundefined
                                    fcwilt @dutti
                                    @barbarossa-cologne
                                    Good.
                                    Enter M98 P"bed.g" and let me know what happens.
                                    duttiundefined 2 Replies Last reply Reply Quote 0
                                    • duttiundefined
                                      dutti @fcwilt
                                      @fcwilt said in G32 Error:´´ Z probe was not triggered during probing move´´:
                                      M98 P"bed.g"
                                      • duttiundefined
                                        dutti @fcwilt
                                        @fcwilt
                                        and bed hasn´t reached the pin of the BL. I think it goes back to the same high then the bed was before the comand started.
                                        • fcwiltundefined
                                          fcwilt @dutti
                                          @barbarossa-cologne
                                          Well it seems the bed.g file you edited to enter the M291 command is not the bed.g file that G32 is executing.
                                          Are you editing the bed.g file that is in the system directory - the directory where the config.g file is located?
                                          • duttiundefined
                                            dutti @fcwilt
                                            @fcwilt
                                            for your question:
