    G32 Error:´´ Z probe was not triggered during probing move´´
    Firmware installation
    4.7k
    • fcwiltundefined
      fcwilt @dutti
      @barbarossa-cologne
      You mean after I'm sure that bed.g is running and nothing else unexpected happens?
      duttiundefined 1 Reply Last reply Reply Quote 0
      • duttiundefined
        dutti @fcwilt
        @fcwilt
        to fix my multiple problems...
        • fcwiltundefined
          fcwilt @dutti
          @barbarossa-cologne
          I am focusing on just two problems right now.
          1. Making sure the probe is working.
          2. Making sure bed.g is working.
          Anything else you want to work on?
          duttiundefined 1 Reply Last reply Reply Quote 1
          • duttiundefined
            dutti @fcwilt
            @fcwilt
            Probe is working.
            I don´t know what I have to change in my bed.g file...
            you told me you wanna make a test. So I did it.... and now? 😞
            I made a G32 and it´s doing a G29. Why? 😕
            I just wanna make a 4 point true auto level.... thats the last thing I have to do before printing. SOS
            • fcwiltundefined
              fcwilt @dutti
              @barbarossa-cologne
              When you did the G32 did you see the popup message saying beg.g was running?
              • duttiundefined
                dutti @fcwilt
                @fcwilt
                drives to the first probe point of mesh compension and --> g32 -->
                Error: Z probe already triggered before probing move started
                • duttiundefined
                  dutti
                  only this message came
                  • fcwiltundefined
                    fcwilt @dutti
                    @barbarossa-cologne said in G32 Error:´´ Z probe was not triggered during probing move´´:
                    @fcwilt
                    And this was with bed.g only having the M291 command?
                    • duttiundefined
                      dutti @fcwilt
                      @fcwilt yes
                      • fcwiltundefined
                        fcwilt @dutti
                        @fcwilt yes
                        And you didn't see the popup message about bed.g running?
                        • duttiundefined
                          dutti @fcwilt
                          @fcwilt no. just the message you see on the screenshot.
                          • fcwiltundefined
                            fcwilt @dutti
                            @barbarossa-cologne
                            Do you know how to enter commands directly into Duet Web Control using the Console page?
                            • duttiundefined
                              dutti @fcwilt
                              @fcwilt yes
                              • fcwiltundefined
                                fcwilt @dutti
                                @barbarossa-cologne
                                Good.
                                Enter M98 P"bed.g" and let me know what happens.
                                duttiundefined 2 Replies Last reply Reply Quote 0
                                • duttiundefined
                                  dutti @fcwilt
                                  @fcwilt said in G32 Error:´´ Z probe was not triggered during probing move´´:
                                  M98 P"bed.g"
                                  • duttiundefined
                                    dutti @fcwilt
                                    @fcwilt
                                    and bed hasn´t reached the pin of the BL. I think it goes back to the same high then the bed was before the comand started.
                                    • fcwiltundefined
                                      fcwilt @dutti
                                      @barbarossa-cologne
                                      Well it seems the bed.g file you edited to enter the M291 command is not the bed.g file that G32 is executing.
                                      Are you editing the bed.g file that is in the system directory - the directory where the config.g file is located?
                                      • duttiundefined
                                        dutti @fcwilt
                                        @fcwilt
                                        for your question:
                                        • duttiundefined
                                          dutti @fcwilt
                                          @fcwilt something to do with this code in config.g?
                                          M558 P9 C"io4.in" H10 F200 T1800 ; set Z probe type to bltouch and the dive height + speeds
                                          M950 S0 C"io4.out" ; create servo pin 0 for BLTouch
                                          G31 P25 X-20 Y-20 Z2.5 ; set Z probe trigger value, offset and trigger height
                                          M557 X15:650 Y15:650 S200 ; define mesh grid
                                          • fcwiltundefined
                                            fcwilt
                                            Now we are getting somewhere I think.
                                            Notice on the left hand side you have MACROS selected.
                                            Is that correct?
                                            If so the files there are not the system files the firmware is using.
                                            Those file are in the SYSTEM directory - the item below the MACROS item.
                                            Select the SYSTEM item and take a look and see what is there.
