dual extruder setup
I'm working on a custom printer with the duet 3 and dual slice mosquito magnums. I've selected everything to do with dual drives,fans, heaters, two tools ( one for each print head) etc.
When I turn on the printer/screen Only one extruder shows up. Is that normal? I feel like two should show up for manual control.; Configuration file for Duet WiFi (firmware version 3)
; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Aug 03 2020 14:22:54 GMT-0500 (Central Daylight Time); General preferences
M550 P"My Printer" ; set printer name
M669 K1 ; select CoreXY mode; Network
M551 P"Kregtool!" ; set password
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P4 S1 ; physical drive 4 goes forwards
M584 X0 Y1 Z2 E3:4 ; set drive mapping
M92 X80.00 Y80.00 Z4000.00 E420.00:420.00 ; set steps per mm
M566 X900.00 Y900.00 Z12.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z20.00 E250.00:250.00 ; set accelerations (mm/s^2)
M906 X1600 Y1600 Z800 E800:800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X900 Y600 Z500 S0 ; set axis maxima; Endstops
M574 Z1 S1 P"zstop" ; configure active-high endstop for low end on Z via pin zstop; Z-Probe
M558 P1 C"zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
M557 X15:900 Y15:500 S60 ; define mesh grid; Heaters
M308 S1 P"e0temp" Y"thermistor" T50000 B4723 ; configure sensor 1 as thermistor on pin e0temp
M308 S2 P"e1temp" Y"thermistor" T50000 B4723 ; configure sensor 2 as thermistor on pin e1temp
M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
M106 P0 S1 H1 T45 ; set fan 0 value. Thermostatic control is turned on
M106 P1 S1 H2 T45 ; set fan 1 value. Thermostatic control is turned on; Tools
M563 P0 S"Print head One" D0 H1 F0 ; define tool 0
M563 P1 S"Print head Two" D1 H2 F0 ; define tool 1
G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C; Custom settings are not defined
T0 ; select first tool -
Yes both tools should show up in DWC. Try running M98 P"config.g" to see if any error messages are reported. Btw the T value for the Slice thermistor is 500000 not 50000.
Can you verify that your firmware version and DWC version is 3.1.1.?
@dc42 I"m running it in standalone mode since i have a new duet3 board- when i did the online reprap configuation i selected the duet 2- Pretty sure i read that i need to do that for standalone mode right? Should i try the m98 p "config.g" in yat? I also don't have the motors and stuff hooked up. i was just trying to get the firmware aspect ready to go. that shouldn't matter right?
I'll change the t value good catch
Also while hooking up the panel due i checked the pin out and the none of them lined up. the 5 volt line on the panel went to the ground pin on the board. the ground was on a different pin etc. so the panel didnt turn on at all. I put the pins in right location and it started working. the difference between these two images is the IO in and outs being switched. I assume the "out" of the panel should be going to the "in" of the board and vice versa for the other In/Out\
as you can see it changes if it connects and gets rid of the temp of the extruder
@Phaedrux 3.1.4 according to the config file
3.1.4 is the version of the config tool.
Send M115 to get the version of the firmware. For DWC version, check the settings page.
@kaduhn1 said in dual extruder setup:
No, you must still select Duet 3.
No, choose Duet 3. There is a checkbox for standalone right below the board drop down for Duet 3 "Run in standalone mode without SBC"
If you have a Duet 3 your config will not work because all of the pin names refer to Duet 2. So you'll need to generate a new config.
@Phaedrux FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.01-RC9 ELECTRONICS: Duet 3 MB6HC v1.01 or later FIRMWARE_DATE: 2020-04-21b1<LF>ok<LF>
@dc42 I redid it with duet 3 this morning and selected the standalone mode. fixed the thermistor value. the diag led light stays flashing, the panel due will stay on the "connecting" mode unless i swap the in/pins like i mentioned in my previous comment.
with out all the motors and what not selected the hot ends should still show up as if they are there and the connecting should switch to busy or ready? -
@Phaedrux yup- i redid it this morning already- see my response to DC
Update your firmware first off.
Upload this zip file as is to the /sys folder in DWC
https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/Duet2and3Firmware-3.1.1.zipThe diag light will pulse steadily in normal use.
The paneldue should say idle when it is connected and ready to go. You will need
M575 P1 S1 B57600
in your config.g to enable support for PanelDue in recent firmwares.Post your new config.g.
@Phaedrux Do i have to be using web control for this with standalone? Right now it's not an option due to no ports- I'm at work. I could find a longer cord and go to the next room if need be.
if not do i just unzip that folder into the SD Card into that same directory? -
@Phaedrux
New config file. it just reads busy and the temp boxes for the extruder are gone unless i switch the two io pins. then they come back but it sits on connecting
; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Aug 04 2020 13:08:09 GMT-0500 (Central Daylight Time); General preferences
M550 P"My Printer" ; set printer name; Network
M569 P0.4 S1 ; physical drive 0.4 goes forwards
M584 X0.0 Y0.1 Z0.2 E0.3:0.4 ; set drive mapping
M92 X80.00 Y80.00 Z400.00 E420.00:420.00 ; set steps per mm
M906 X800 Y800 Z800 E800:800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X900 Y900 Z200 S0 ; set axis maxima; Endstops
M574 X1 S1 P"io0.in" ; configure active-high endstop for low end on X via pin io0.in
M574 Y1 S1 P"io1.in" ; configure active-high endstop for low end on Y via pin io1.in
M574 Z1 S1 P"io2.in" ; configure active-high endstop for low end on Z via pin io2.in; Z-Probe
M558 P5 C"^io3.in" H5 F120 T6000 ; set Z probe type to switch and the dive height + speeds
M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
M308 S1 P"temp1" Y"thermistor" T500000 B4723 C1.19622e-7 ; configure sensor 1 as thermistor on pin temp1
M308 S2 P"temp2" Y"thermistor" T500000 B4723 C1.19622e-7 ; configure sensor 2 as thermistor on pin temp2
M950 H2 C"out2" T2 ; create nozzle heater output on out2 and map it to sensor 2
M950 F0 C"out3" Q500 ; create fan 0 on pin out3 and set its frequency
M950 F1 C"out4" Q500 ; create fan 1 on pin out4 and set its frequency
M563 P0 S"Head 1" D0 H1 F0 ; define tool 0
M563 P1 S"head 2" D1 H2 F0 ; define tool 1
M575 P1 S1 B57600 ; enable support for PanelDue -
Yes.
You could do the manual firmware update process if you only have access to the board via USB terminal. Extract the zip file, copy just the firmware bin file to the SD card in the /sys folder. Connect via USB and send M997 S0.
https://duet3d.dozuki.com/Wiki/Gcode#Section_M997_Perform_in_application_firmware_update
For the DWC files, download this zip file and extract it to the /www folder
https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/DuetWebControl-SD-3.1.1.zip
Once you are updated, send M115 to confirm and then try sending M98 P"config.g" and report any errors.
@Phaedrux i downloaded that zip folder and unzipped it and they're mostly .gz f files and nothing named firmware.bin or similar.
Should i be downloading this firmware bin from DC's github?https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/Duet3Firmware_MB6HC.bin
@Phaedrux
ok so i unzipped that same file again and now a bunch of .bin files are showing up. I'll copy the duet 3 mb6hc to the sys folder and do the m997 etc -
@Phaedrux copied the Duet3Firmware_MB6HC.bin into the SYS folder, did the M997 S0 and its give me this error
Error: M997: Firmware binary "Duet3Firmware_MB6HC.bin" not found<LF>ok<LF> -
It would be substantially easier if we had network access to DWC.
