    Problem with calibrating magnetic filement sensor
    Filament Monitor
    1.3k
      Phaedrux Moderator @Frankzz
      @Frankzz said in Problem with calibrating magnetic filement sensor:
      I sanded it down after first post. Now agc is 103. But still have issues
      That's promising. Can you sand it further?
      • Frankzzundefined
        Frankzz
        I did. Now agc is 86-82
        I see that measured sensitivity still goes up during print.
        It started with
        14:15:59M591 D0
        Duet3D magnetic filament monitor on input 2, enabled, sensitivity 25.58mm/rev, allow 10% to 125%, check every 5.0mm, version 3, mag 132 agc 84, measured sensitivity 26.65mm/rev, min 96% max 106% over 160.7mm
        After 40 min printing it started to go down. It is fine for what I am doing. If it would kept rising it would be a problem. Have a Modix 120X. 2 weeks for a print is not common but it happens. The sensor will fix the problems I had before.
        Here is the read out in the end of print
        14:53:42M591 D0
        Duet3D magnetic filament monitor on input 2, enabled, sensitivity 25.58mm/rev, allow 10% to 125%, check every 5.0mm, version 3, mag 131 agc 82, measured sensitivity 29.32mm/rev, min 22% max 117% over 31084.6mm
        14:51:24M591 D0
        Duet3D magnetic filament monitor on input 2, enabled, sensitivity 25.58mm/rev, allow 10% to 125%, check every 5.0mm, version 3, mag 130 agc 82, measured sensitivity 29.45mm/rev, min 22% max 117% over 29104.8mm
        14:49:12M591 D0
        Duet3D magnetic filament monitor on input 2, enabled, sensitivity 25.58mm/rev, allow 10% to 125%, check every 5.0mm, version 3, mag 130 agc 82, measured sensitivity 29.49mm/rev, min 22% max 117% over 27375.1mm
        14:46:19M591 D0
        Duet3D magnetic filament monitor on input 2, enabled, sensitivity 25.58mm/rev, allow 10% to 125%, check every 5.0mm, version 3, mag 132 agc 82, measured sensitivity 29.50mm/rev, min 22% max 117% over 24965.7mm
          So it seems to be functioning better now? Keep us posted.
          Frankzzundefined 1 Reply Last reply Reply Quote 0
          • Frankzzundefined
            Frankzz @Phaedrux
            @Phaedrux
            Yes it is working. Don´t like that the sensitivity changes. Will see how it works on a larger print.
            I do have question though. I have read everything I can find on the forum but no answer.
            My magnetic sensor is very close to the extruder. It means when the filement runs out it is not sticking up from the extruder when runing just the magnetic sensor.
            So I planned to use the standard filement run-out sensor (microswitch).
            I changed the P from 3 to 4 but it just says "no filement present"
            So I figured the sensor (microswitch) needed to be reversed (NO vs NC) and modified the sensor.
            It did not help.
            I did some testing with both NC and NO to make sure it has nothing to do with wiring.
            The microswitch is connected to E0 stop and the magnet sensor to Z stop.
            Reading on the forum I found a post implicit suggesting that both should be connected to the same I/O.
            It does not make sense. Then there would be no need to have 5 pins on the magnetic sensor.
            But how does the Duet know which input is which when using magnetic sensor AND micro switch? (P4)
            Can you please clarify?
            Frank
              When are where was the sensor purchased? Perhaps to save any further frustration with testing etc we should try exchanging it in case the issues is the sensor itself.
              • Frankzzundefined
                Frankzz @Phaedrux
                @Phaedrux
                I bought it in the beginning of July from hobby store in Poland. Simply because they had it in stock.
                I can live with the sensitivity slipping as long as it does not mean that it goes out of tolerance.
                To check this I need to run a larger print which I was about to today once I solved the run out switch problem.
                But I would like to know the answer to the micro switch question.
                Just to clarify, the micro switch I am using worked fine before I changed the config file to accommodate the magnetic sensor.
                When writing this I think I figured out the problem. I am 99% sure that I erased the line configuring the micro switch.
                Will test this tomorrow.
                • Frankzzundefined
                  Frankzz
                  Ok I put the M591 line defining simple microswitch runut sensor (like it was prior to magnetic sensor) and kept the M591 line for the magnetic sensor.
                  It did not work.
                  So question still stands. How to wire the runout sensor to make this work?
                  Maybe this should be separate thread. Tell me and I will repost it.
                  Frank
                  • Frankzzundefined
                    Frankzz
                    Ok now I figured it out.
                    It is kind of obvious that the microswitch is to be connected to the magnetic switch.
                    I thought it should still be connected to the Duet board.
                    Could not figure out why the magnetic switch had the 2 pins, that is what solved it.
                    Now I only need to route 4 more meters of cable and find the connectors.
                    Frank
                      Glad you got it figured out.
                      • Frankzzundefined
                        Frankzz @Phaedrux
                        @Phaedrux
                        Yes, I did the wiring yesterday, did some testing and started a 60 hour print.
                        It worked for about an hour then it started saying "too little movement"
                        I have set the tolerance to 10%-125%, just as stated before.
                        But there are no problems, no clog and filament extrudes fine when doing it manually at highest speed.
                        I tried to make it work for 2 hours. In the end I got sensitivity value in the 1000 and it would not work at all.
                        I tried it this morning with the same result.
                        So I actually think there is something wrong with the sensor.
                        So yes, I would like a replacement sensor.
                        Frank
                          [EDITED] I suspect that the reason for the small sensitivity changes is that the average print speed is changing and your extruder suffers from nonlinear extrusion, i.e. the steps/mm goes up a little as the extrusion rate increases.
                          When the sensitivity gets very high (you mentioned 1000), does the AGC still read in the 80 to 90 region?
                          • Frankzzundefined
                            Frankzz @dc42
                            AGC is 76-78. Now the sensor is not working at all.
                            I can´t post the respons from printer since I am at work. Will do that later today.
                            The problem just escalated until it stopped completely.
                            When printer pauses I can extrude manually with highest speed. Then I resume and it just went shorter and shorter distance until it paused again.
                            I the end it pause direct but I see it extruding.
                            So right now I like to try a new sensor.
                            Frank
                            • Frankzzundefined
                              Frankzz
                              Here is the last numbers when the sensor still kind of worked
                              00:49:42M591 D0
                              Duet3D magnetic filament monitor with switch on input 2, enabled, sensitivity 25.58mm/rev, allow 10% to 125%, check every 5.0mm, version 3, mag 131 agc 76, measured sensitivity 29.46mm/rev, min 26% max 112% over 407.0mm
                              00:49:28M591 D0
                              Duet3D magnetic filament monitor with switch on input 2, enabled, sensitivity 25.58mm/rev, allow 10% to 125%, check every 5.0mm, version 3, mag 131 agc 76, measured sensitivity 28.48mm/rev, min 60% max 108% over 307.8mm
                              00:48:54M591 D0
                              Duet3D magnetic filament monitor with switch on input 2, enabled, sensitivity 25.58mm/rev, allow 10% to 125%, check every 5.0mm, version 3, mag 131 agc 76, measured sensitivity 27.06mm/rev, min 97% max 102% over 102.0mm
                              00:48:47M591 D0
                              Duet3D magnetic filament monitor with switch on input 2, enabled, sensitivity 25.58mm/rev, allow 10% to 125%, check every 5.0mm, version 3, mag 131 agc 76, measured sensitivity 27.00mm/rev, min 97% max 102% over 61.4mm
                              • Frankzzundefined
                                Frankzz
                                Here is the read out last night when it just gave up
                                00:58:28M591 D0
                                Printing paused at X744.9 Y222.7 Z6.0
                                Duet3D magnetic filament monitor with switch on input 2, enabled, sensitivity 25.58mm/rev, allow 10% to 125%, check every 5.0mm, version 3, mag 130 agc 76, measured sensitivity 17063.90mm/rev, min 100% max 100% over 16.7mm
                                I just tried again. First it just stopped more or less direct.
                                18:01:03M591 D0
                                Printing paused at X424.3 Y225.9 Z6.0
                                Duet3D magnetic filament monitor with switch on input 2, enabled, sensitivity 25.58mm/rev, allow 10% to 125%, check every 5.0mm, version 3, mag 129 agc 76, measured sensitivity infmm/rev, min 0% max 0% over 14.4mm
                                Guessing it is not spinning so I pulled the filament and tested so the sensor rotor moved. It did.
                                Resumed again and got this far
                                18:04:43M591 D0
                                Printing paused at X135.5 Y298.0 Z6.0
                                Duet3D magnetic filament monitor with switch on input 2, enabled, sensitivity 25.58mm/rev, allow 10% to 125%, check every 5.0mm, version 3, mag 132 agc 78, measured sensitivity 28.65mm/rev, min 1% max 110% over 108.8mm.
                                Can you please give advise what to do?
                                Frank
                                  Hi Frank, I authorise a replacement sensor for you under warranty. Please contact your supplier and refer them to this forum post for authorization.
                                  • Frankzzundefined
                                    Frankzz @dc42
                                    Ok will do.
                                    I just stopped the print, deleted the M591 line in config and will try to resurrect the print with out sensor
                                    If that works it is definently the sensor
                                    • Frankzzundefined
                                      Frankzz
                                      Now it is printing fine. It will not tell me if it stops extruding but I can find the height and use resurrect.
                                      But just when the print started I got this message on webinterface
                                      Connection Lost
                                      The connection between the browser and your machine has been interrupted.
                                      Reason: Unknown (SyntaxError: Unexpected token , in JSON at position 845)
                                      Please reload the web interface to proceed.
                                      Tried to reload, restart computer and restart router. Nothing helped.
                                      Don´t want to restart printer in mid print.
                                      Is this a known issue?
                                      • BoAundefined
                                        BoA
                                        Got similar problem. AGC - 122. I ended up sanding resin case and the magnet sensing IC. Now agc is 56 and all problems solved.
                                        • Frankzzundefined
                                          Frankzz @BoA
                                          @BoA
                                          I started out with AGC 114. (See previous posts)
                                          AGC now is around 80 and that is well within specs.
                                          It did work fine for a while and that tells me the issue is the sensor.
                                          But If the next sensor does the same I will try to this one more to see if it helps.
                                          Does anyone know the lower tolerence of AGC ?
                                          Frank
                                            Connection Lost
                                            What version of firmware and DWC are you running? There may be a version mismatch.
                                            Currently supported versions are FW 2.05.1 and DWC 2.0.7 and FW 3.1.1 and DWC 3.1.1
