    Sending command to move Z moves X axis, (X commands also move X)
    My Duet controlled machine
    • codycundefined
      codyc
      Hi there,
      I have a Cartesian set up, with dual motors on the X and also dual motors on Z. Single Y, single extruder.
      As the title says, every command that is sent to move the Z axis instead causes the X axis to move. Right now I can't get the Z to move at all. Commands to move X or Y do so normally.
      I'll post my config below, but I'm very flabbergasted. I've triple checked that my physical connections match where my M584 command maps them to. (M584 X0.0:0.1 Y0.2 Z0.3:0.4 E0.5)
      Things were working well(ish) before I switched the X motors from running off a single driver with spliced wires.
      Only thing I can think of is that I am only using one end stop for the dual X motors, could that roll over and cause this sort of problem?
      Config Below
      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Mar 05 2020 02:18:09 GMT+0000 (Greenwich Mean Time)
      M550 P"Duet 3" ; set printer name
      M569 P0.0 S1 ;
      M569 P0.1 S0 ;
      M569 P0.2 S1 ;
      M569 P0.3 S1
      M569 P0.4 S1 ;
      M569 P0.5 S0;
      M584 X0.0:0.1 Y0.2 Z0.3:0.4 E0.5 ; set drive mapping
      M671 X-80:780 Y150:150 S5;Set location of z-rods
      M92 X80.00 Y80.00 Z720.00 E409.00 ; set steps per mm
      M906 X1000 Y1000 Z800 E1100 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      ; Axis Limit
      M208 X700 Y320 Z387 S0 ; set axis maxima
      M574 X1 S0 P"io0.in" ; configure active-low endstop for low end on X via pin io0.in
      M574 Y1 S0 P"io1.in" ; configure active-low endstop for low end on Y via pin io1.in
      M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
      M558 P9 C"io7.in" H1 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X0 Y-30 Z0.84 ; set Z probe trigger value, offset and trigger height
      M557 X0:700 Y0:280 S70 ; define mesh grid
      M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.060000e-8 ; configure sensor 1 as thermistor on pin temp1
      M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency
      M106 P0 S0.7 H1 T45 ; set fan 0 value. Thermostatic control is turned on
      M950 F1 C"out8" Q500 ; create fan 1 on pin out8 and set its frequency
      M106 P1 S0 H-1 ; set fan 1 value. Thermostatic control is turned off
        droftarts administrators @codyc
        @codyc firmware version? Are you using the Duet 3 with SBC or standalone? Early RRF 3 versions needed the M584 command splitting onto separate lines where multiple motors were defined on multiple axes, eg
        M584 X0.0:0.1 Y0.2
        M584 Z0.3:0.4 E0.5 ; set drive mapping
        So you could try that.
        • codycundefined
          codyc
          Ah, still on an earlier version. I'll give that a shot right now. Duet 3 with SBC.
          • codycundefined
            codyc
            And that made it work. Thanks for sharing your knowledge @droftarts !
