    K Type Thermocouple Installing a capsule
    • qubitundefined
      qubit
      Hi all,
      I purchased an unencapsulated K-type thermocouple from E3D, and have crimped a metal cap onto it to avoid contact issues. I configured it using M305 P1 T"K" X150
      It appears to read the right room temperature, but the measured temperature appears to asymptote at 200°C as I run it through a tune using M303. The heater was working fine before and easily reaching 250°C, which makes me suspect that the temperature being measured is wrong, not the heater and the fact it doesn't give short to other wiring (which were occuring without a capsule) suggests it isn't the capsule itself that is the issue, but I am not sure.
      I have inserted the thermocouple into the printer as shown in the pictures below, which sticks out slightly as the cartridge maybe 5 mm too long. I suspect either it is misconfigured in software or that there is an issue with heat conduction. I saw on another thread it can be worth grounding the cartridge can help.
      I'd love to hear your suggestions so I can get printing again!
      I am using a Duet 2 Wifi with RepRap 2.
      photo5872925305910441249.jpg photo5872925305910441250.jpg photo5872925305910441251.jpg
        T3P3Tony administrators
        do you have another temperature measuring sensor you can try together with this to confirm if its reading wrong or there is another problem?
        qubitundefined 1 Reply Last reply Reply Quote 0
        • qubitundefined
          qubit @T3P3Tony
          @T3P3Tony I don't currently have another means of measuring temperatures above 100C, which is where the issues start happening - the heating rate begins to level off until an asymptote at 200C . However, I know that I was able to melt PLA at around 215C (according to my thermistor) before changing the thermistor with the thermocouple , and I haven't changed anything else, hence why I think it is an issue with the temperature sensing or conduction of heat.
            T3P3Tony administrators @qubit
            @qubit you can try the other channel on the thermocouple daughterboard (X151). also what version of the TC daughterboard and RepRapFirmware are you using?
