    G29 mesh probing & bed compensation with 4 Z-motors
    483
    • wieman01undefined
      wieman01 @Dougal1957
      @Dougal1957 said in G29 mesh probing & bed compensation with 4 Z-motors:
      You are missing the G30 steps in your BED.G that needs to come between the G28 and the G29
      see this
      Thank you. I was under the impression that M557 in "config.g" would suffice to define the mesh size & spacing. That information is stored in "heightmap.csv" would could be used for bed compensation.
      Is G30 therefore really necessary when the mesh size, etc. is already there? I may be missing something here.
      • Dougal1957undefined
        Dougal1957
        Leveling and Mesh are 2 totally different systems if you have a bed that is inherently flat then you don't need a mesh but will still need to level it G30 tells it to probe a point near to a leadscrew and then move to another one and repeat till you get to the last one where you need a Sx where x is the number of motors so in your case your last G30 will be G30 Xxxx Yxxx S4.
        You need to define your probe points to be in the same sequence as your motors are defined.
        I am sure someone with a lot more experience of this will come forward soon enough (I have yet to implement the system in a Cube style printer)
          droftarts administrators @wieman01
          @wieman01 I think you're confusing 'mesh compensation' and 'bed levelling'. Ideally you level the bed physically with 'bed levelling' first, which adjusts the bed to create a level plane. Then any anomalies in bed shape/height are compensated with the mesh compensation. If you have independently connected Z motors, you can do the bed levelling automatically rather than manually.
          For bed levelling with independent Z motors, see https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
          It sounds like you already have your mesh compensation sorted. You don't need to have this running from bed.g; it would be more normal to have the bed levelling running in bed.g, and called by G32, then run mesh compensation afterwards.
          Bed levelling should run every time the printer is turned on, because it's possible for Z motors to move, or jump to different full steps, each time they are turned on. Mesh compensation should be more consistent, so once a mesh map has been created, it can be loaded after the bed has been levelled, rather than redoing the mesh compensation every time.
          Dougal1957undefined 1 Reply Last reply Reply Quote 1
            Dougal1957 @droftarts
            @droftarts That Ian is a very common mistake made by those coming from the marlin community
            • wieman01undefined
              wieman01
              @Dougal1957 & @droftarts
              Thank you both for your explanation, it does make more sense to me now. In fact I was not aware of the difference between bed leveling and mesh compensation, you are spot-on.
              Mesh compensation should be okay then, I will now try to figure out how to level the bed as @Dougal1957 has explained. That is a good starting point.
              I'll let you know how it goes.
                @wieman01 This link I posted https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors explains it all, and has code examples (admittedly for 2- and 3-motor Z axes, but a 4th motor shouldn't be difficult to add).
                  @droftarts same link as I posted Ian
                  droftartsundefined 1 Reply Last reply Reply Quote 1
                    droftarts administrators @Dougal1957
                    @Dougal1957 Ah, yes, I didn't see the 'see this'!
                    • wieman01undefined
                      wieman01
                      Thank you, I saw the post earlier and followed it to the letter. Bed leveling now works and I'll post my "bed.g" later.
                      Is there any way I can increase the maximum correction of 1mm? This is a clay printer with a wooden bed, so my tolerances are of very different nature. 🙂
                      The web interface displays an error message because of the set limit of 1mm.
                      Other than this I think I am done thanks to your help.
                        Dougal1957 @wieman01
                        @wieman01 said in G29 mesh probing & bed compensation with 4 Z-motors:
                        On the M671 the S parameter set the adjustment amount (if left of it defaults to 1mm) but remember that with 4 screws you run a serious risk of warping the bed you can of course run the routine several times and it will converge.
                        wieman01undefined 1 Reply Last reply Reply Quote 1
                        • wieman01undefined
                          Thank you, my friend. That is perfect. Warping won't be an issue, my printer is designed such that it should withstand greater differences well enough. If not, I will try again. 😀
                          This is a working copy of my "bed.g":
                          ; Bed calibration
                          G28 							; home
                          M401 							; deploy Z probe
                          G30 P0 X380 Y355 H0 Z-99999
                          G30 P1 X380 Y10 H0 Z-99999
                          G30 P2 X10 Y10 H0 Z-99999
                          G30 P3 X10 Y355 H0 Z-99999 S4
                          M402 							; retract probe
                          Here is the relevant section from "config.g":
                          ; Bed leveling geometry & leveling
                          M671 X470:470:-70:-70 Y400:-40:400:-40 S5
