    Height Map from my updated MarkForged style printer
    My Duet controlled machine
    1.3k
    • Kolbiundefined
      Kolbi @jens55
      @jens55 Did the OO file work?
      • jens55undefined
        jens55
        Yes it did except it did not display the graphs of the rows and column values which although neat, is not that important to me.
        I have not had an opportunity to look at the underlying code yet.
        Kolbiundefined 1 Reply Last reply Reply Quote 0
        • Kolbiundefined
          Kolbi @jens55
          @jens55 Ok, try this link: https://docs.google.com/spreadsheets/d/1bdS7_B9p3vgNE9e71yBYNnUnAmfwfWXXh8C6L9pC56s/edit?usp=sharing
          • jens55undefined
            jens55
            It doesn't give me permission to access.
            • jens55undefined
              jens55
              I now have permission - thanks
              • Kolbiundefined
                Kolbi @jens55
                @jens55 👍
                • jens55undefined
                  jens55
                  Looking at the code behind the spreadsheet, there seems to be nothing there that sets the colour. Is that something that is done through formatting or similar (ie not on a cell level)?
                  As you can tell, my spreadsheet foo is very low 😞
                  • Kolbiundefined
                    Kolbi @jens55
                    @jens55 No worries, that's called 'conditional formatting' - check this out: https://support.google.com/docs/answer/78413?co=GENIE.Platform%3DDesktop&hl=en
                    So, if you select all the cells with red/blue/white and do a 'right-click' - you should have a menu pop-up. On the near bottom of the menu should be 'conditional formatting'. Select that and you should see the formatting rule for those blocks on the upper left on the screen. Click on that and you'll see the logic it uses to colorize the cells.
                    • jens55undefined
                      jens55
                      I don't get the option of the formatting ... probably because the document is read only.
                      No matter, I have learned a lot. I have also found conditional formatting in OO and will explore things through OO.
                      Thanks for your help!
                      • Kolbiundefined
                        Kolbi @jens55
                        @jens55 No worries, I just a copy of my saved sheet so I changed it to edit enable - give it a shot if you want, can't really hurt anything.
                        And I just tried loosening the screws and retighten while hot, it didn't really do anything. So I'll probably get brass standoffs, put those on, measure mesh, and lightly sand down offsets until satisfied.
                        • jens55undefined
                          jens55
                          Why would you bother to reduce the offsets? It's an excellent height map to begin with but then you also have the bed compensation to look after the remaining error. More than likely, you are trying to make improvements well beyond the capabilities of the printer itself.
                          I find that the kind of lightweight printers most of us have are so full of compromises everywhere that unless there is a likelihood of substantial improvements, I don't bother. Most minor improvements like this get drowned out in the overall picture and only get realized in combination with other improvements. By the time you actually see the difference of your improvement, there isn't much left of the original printer.
                          An example - I have a CR10-S5 printer that has a 4 mm glass plate on the build plate and therefore considerable mass that gets moved back and forth for the Y travel. I get a fair bit of ringing. The table that the printer sits on is lag bolted to the wall in 5 or 6 locations and it easily handles me jumping up and down on it (I am overweight). Nevertheless, with all that mass and strength, the printer rattles the wall the table is bolted to and therefore the house. It is simply the wrong kind of design for a 500 mm * 500 mm printer.
                          I am sure I can tweak things here or there for marginal improvements (and I do) but no matter what I do short of slowing this thing to a crawl, I will never get rid of ringing and related issues.
                          Kolbiundefined 2 Replies Last reply Reply Quote 0
                          • Kolbiundefined
                            Kolbi @jens55
                            @jens55 All good points. Out of habit, I always try to get everything as perfect as I can, however futile it may be at times. For now it really comes down to how bored I get (on covid lockdown now - so pretty bored), how much money it costs (maybe $5 dollars for standoffs - but already have them), and how much time it will take.
                            • jens55undefined
                              jens55
                              Sounds good ... more power to you !
                              As an additional point, I find that my height map changes a bit every time I run it. Even if I got it juuuust right, the next time I run the height mapping it would be off.
                              My height map also looks more like the rocky mountains then your plains of Saskatchewan (yes, I am in Canada)
                              • Kolbiundefined
                                Kolbi @jens55
                                @jens55 said in Height Map from my updated MarkForged style printer:
                                Yup, mine used to shift the same way until I ripped the frame apart and did the Zaribo 10mm upgrade. Since then the repeatability, and quality, has been amazing. Maybe shifting from the PindaV2 to BLTouch also helped.
                                😂 I have been in the Rockys, but I don't think I ever made to Saskatchewan - closest I got was the Canada Falls side and further yet, Halifax.
                                • jens55undefined
                                  jens55
                                  Had to look that up but amazing that upgrading a couple of rods from 8 mm to 10 mm would make such a difference. This is just to upgrade the Z axis round rods right ?
                                  • Kolbiundefined
                                    Kolbi @jens55
                                    @jens55 All rods, this is the base now: https://zaribo.com/home/205-2314-zaribo-220-mk3s-rel-3.html#/84-extruder-bondtech_mk3s/94-psu-320_w_meanwell/100-steel_sheet-thekkiinngg/102-hotend-mosquito/103-heater-e3d_40w/135-rods-10mm/138-display-lcd/140-therm-e3d/143-carriage-mk52_blocks
                                    Other stuff was done like different motors, redesigned extruder with BLTouch, and some others.
                                    • jens55undefined
                                      jens55
                                      Ahh, that makes more sense now. Thanks for clarifying.
                                      • Kolbiundefined
                                        Kolbi @jens55
                                        @jens55 No worries. I have been slowly redesigning the entire extruder assembly in Solidworks, so that it is more compact and that the weight is evenly distributed between front and back - current design has all the weight on the front side which I do not like.
                                        For your printer shaking, have you tried to decouple it from the table it's on? For example, mine is on a marble slab with jell feet between the marble and table - made quite a difference for me.
                                        • jens55undefined
                                          jens55
                                          It is decoupled to some extent but could be improved.
                                          IMHO decoupling will prevent the printer shaking the house but that won't help with the quality of the print because it is still shaking all over the place. The only way to solve the shaking is to go to a design that doesn't try to sling a heavy dead weight (build plate) all over the place.
                                          • Kolbiundefined
                                            Kolbi
                                            Yeah, nothing is perfect. I guess it all comes down to managing; accuracy <--> habitability <--> feasibility
