    Duet 2 Wifi Bad Drivers
    596
    • Chris2010undefined
      Chris2010 @Phaedrux
      @Phaedrux Great point lol. And Ill give lowering the current a try. Thanks for the suggestion!
        I don't think there is any extreme error in the config. At least none that should generate the problem observed.
        Mainly you're missing M584 to create the U axis.
        The current is high for X and Y, so worth a try reducing it, but I don't think it would generate the issue seen.
          I might also suggest getting a fresh config from the web tool with just the basics. No Duex connected. Just the default drivers defined and test that.
          https://configtool.reprapfirmware.org/Start
          Chris2010undefined 1 Reply Last reply Reply Quote 0
            Chris2010 @Phaedrux
            @Phaedrux Thats a good Idea as well. Guess Ill try that next.
              Chris2010
              So XY currents were dropped to 1560 mA and retested. No luck. Still no movement. On to the new config test...
                Chris2010
                Ok, retested with fresh config, Z moves (connect to tool lock) X and Y do not. It looks like the drivers to me. Any other ideas?
                  Please contact filastruder and initiate a warranty exchange for the Duet Wifi. Link to this thread as authorization.
                  I'd still be curious to see photos front and back when you get it out.
                    When RRF reports both phases of a driver may be disconnected, it's rarely a driver issue.
                    Are you sure you have identified the driver numbers correctly? Your photo of the Duet WiFi shows a motor connected to the Z driver, which is driver 2, and nothing connected to driver 0 or driver 1.
                      Chris2010
                      You are correct it seems odd to me about the drivers as well, but the pictures posted didnt show the 0 and 1 drivers. Here is a pic of that. Again, the motors for X and Y worked when plugged into Z but not on their respective spots.back wiring.jpg
                        Chris2010
                        Ok so here is the removed board front and back. As far as I can tell there are no bad solders or visible damage.board back.jpg
                          Chris2010
