    Height Map from my updated MarkForged style printer
    My Duet controlled machine
    1.3k
    • Kolbiundefined
      Kolbi @jens55
      @jens55 No worries. I have been slowly redesigning the entire extruder assembly in Solidworks, so that it is more compact and that the weight is evenly distributed between front and back - current design has all the weight on the front side which I do not like.
      For your printer shaking, have you tried to decouple it from the table it's on? For example, mine is on a marble slab with jell feet between the marble and table - made quite a difference for me.
      • jens55undefined
        jens55
        It is decoupled to some extent but could be improved.
        IMHO decoupling will prevent the printer shaking the house but that won't help with the quality of the print because it is still shaking all over the place. The only way to solve the shaking is to go to a design that doesn't try to sling a heavy dead weight (build plate) all over the place.
        • Kolbiundefined
          Kolbi
          Yeah, nothing is perfect. I guess it all comes down to managing; accuracy <--> habitability <--> feasibility
          • fcwiltundefined
            fcwilt @jens55
            @jens55 said in Height Map from my updated MarkForged style printer:
            ...that doesn't try to sling a heavy dead weight (build plate) all over the place.
            I've never had a "bed slinger".
            I understand they are economical but the whole idea seems somewhat flaky and they take up more space then other styles.
            I will admit to having ordered a PrusaMini for my next door neighbor's son who had expressed interest in 3D printing.
            jens55undefined Kolbiundefined 2 Replies Last reply Reply Quote 1
            • jens55undefined
              jens55 @fcwilt
              @fcwilt said in Height Map from my updated MarkForged style printer:
              Yup, you got that all nicely characterized in a single sentence 🙂
              • Kolbiundefined
                Kolbi @fcwilt
                economical
                For me, I didn't really think about the economics - I wanted to try a bed-slinger for curiosity. For the longest time I used my Makerbot R2, and had other similar homegrown printers, but when I got deployed I donated them to the local schools because I knew they'd be sitting for a long time. Once I got back I needed one to make custom dive parts and figured to give the Prusa MK3s a go. 100% I could have easily got a Railcore or similar - and should have. Actually I think it would have been cheaper... But once I have something, I can't help but make it the best that it could be, and should have been - hence Zaribo 10mm upgrade and others. As it stands now, I get awesome results but it was a long, and somewhat ridiculous road - mostly because I am stubborn.
                Even though I like my printer very, very much, I do not advise friends to get a bed-slinger. When having kids around, it is even more dangerous as small hands with fingers can get right into pinch areas.
                jens55undefined 1 Reply Last reply Reply Quote 1
                • jens55undefined
                  jens55 @Kolbi
                  @Kolbi said in Height Map from my updated MarkForged style printer:
                  It has it's uses. I got a CR10 as my first printer before I knew anything. It was great for that. Anybody that just wants to play around a bit, a bed slinger is great. Once you fall into the 3D printer black hole, it's not such a good idea. The price point is very attractive and it's easy to go that route until your knowledge level goes up a bit.
                  When I bought the cr10-S5 I knew I wanted to modify it with a Duet and double extruders but was not aware of a whole lot of other things.
                  Kolbiundefined 1 Reply Last reply Reply Quote 1
                  • Kolbiundefined
                    Kolbi @jens55
                    @jens55 Oh yeah - no doubt. With the stage that my printer is at, I don't think I'd be apt to trade it in for something else.
                    And I must admit, by my nature I enjoy tinkering and modifying all my stuff - so it's always fun and a learning experience. Only thing I haven't modified is my coffee machine, but it knows I'm watching it...
                    • jens55undefined
                      jens55
                      ESP 8266 module and node red to the rescue ......
                      Kolbiundefined 1 Reply Last reply Reply Quote 0
                      • Kolbiundefined
                        Kolbi @jens55
                        @jens55 I did mess around with the ESP module to have it play with my SKR1.4 board (other printer), a bit fiddly to program since I used an Arduino to do such - but not awful. I haven't messed around with node-red, have seen it mentioned, but never opened it up... yet. The jura machine has an upgraded attachment which I think is just that... hmm...
                        • Kolbiundefined
                          Kolbi @jens55
                          Why would you bother to reduce the offsets?
                          This was a great point... It was a lot of work for barely marginal gains.
                          Brass standoffs were not up to the task, with very light torquing two broke off inside the attaching Y-plate threaded mounting points and caused a few hours of fun - stainless steel standoffs proved to be a much better option.
