    M117 Error following upgrade to 3.1.1
    • oddjobundefined
      oddjob
      Re: M117 Bad Command
      Hi all,
      I updated one of my machines to 3.1.1 yesterday. I am getting some curious issues with M117. If I leave the string unquoted [as indicated in the Reprap documentation wiki] the command returns an error
      9f248353-61f2-4b72-9563-de0f81db368d-image.png .
      However if I quotation wrap the string then the returned message loops endlessly.
      M117 Msg repeating (Quotations used).png .
      The only way I can clear this is to restart the machine.
      Not a major issue but it would be good to see what I might be getting this wrong.
        A Former User @oddjob
        @oddjob said in M117 Error following upgrade to 3.1.1:
        but it works with quotes? that could be a RRF3 thing as some other command needs quotes in RRF3 but didnt in RRF2.
        • oddjobundefined
          oddjob
          Yes M117 works with quotes but the returned message then loops. Which requires an reset to halt.
          • oddjobundefined
            oddjob
            My initial post was not the best formatting. I had addditional comments nested between the 2 attachements.
            • oddjobundefined
              oddjob
              Hi all,
              It seems that 3.1.1 doesn't like the old web interface. If I run the latest version of DWC M117 is fine. Again if I choose the revert to old DWC option M117 returns errors or loops.
                droftarts administrators @oddjob
                @oddjob The old web interface is untested and unsupported with RRF 3. It works, but there may be glitches. For this one, try using M118 rather than M117.
