    M117 Bad Command
    608
    • mitchundefined
      mitch
      Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.01-beta3 (2020-01-29b1)
      Duet2 Ethernet
      I have been getting errors in scripts randomly that use the M117 command. Some work. Some don't.
      • jens55undefined
        jens55
        Try using double quotes around the message as in
        M117 "purging material"
        • mitchundefined
          mitch
          It is indeed in the simplify 3d Start script:
          ; Ender 5 Custom Start G-code
          M80; Turn on Printer
          M117 Pre-heating Bed
          M140 S[bed0_temperature] ; Set Heat Bed temperature
          M190 S[bed0_temperature] ; Wait for Heat Bed temperature
          M117 Pre-heating extruder
          M117 Heating extruder
          M104 S[extruder0_temperature] ; Set Extruder temperature
          G28 ; Home all axes
          M117 Auto bed-leveling
          G29 ; Auto bed-level (BL-Touch)
          G92 E0 ; Reset Extruder
          M109 S[extruder0_temperature] ; Wait for Extruder temperature
          G1 Z1.0 F3000 ; move z up little to prevent scratching of surface
          G1 X0.1 Y20 Z0.3 F5000.0 ; move to start-line position
          M117 Purging Material
          G1 X0.1 Y200.0 Z0.3 F1500.0 E15 ; draw 1st line
          G1 X0.4 Y200.0 Z0.3 F5000.0 ; move to side a little
          G1 X0.4 Y20 Z0.3 F1500.0 E30 ; draw 2nd line
          G92 E0 ; reset extruder
          G1 Z1.0 F1500 ; move z up little to prevent scratching of surface
          M117 Printing
          ; End of custom start GCode
          However, the "Purging Material" lines seems to be the only one that the Duet complains about. Several of the other M117 commands execute just fine.
          • jens55undefined
            jens55
            Just for curiosity sake, put the quotation marks around it and see what happens.
            I know it doesn't make sense but humour me, please !
            • mitchundefined
              mitch
              Will do. I have a print still running for the rest of the day. I will try that as soon as this one completes.
              The only thing I see that makes that line unique is the blank line before it??
              • jens55undefined
                jens55
                Yes, I have noticed that as well. The reason I am asking you to run that line with quotes is because I had a similar issue where some M117 commands without quotes didn't work and then worked fine once quoted. According to DC42, both quoted and unquoted should work (and they do for you) but since I have seen the weirdness before, I think it is worthwhile testing it.
                  I dunno what happened to me in my formative years, but having a string WITHOUT quotes makes me nervous.
                    @mitch, please can you post (either here or on a file sharing site such as Dropbox) a GCode file that demonstrates the problem, so that I can try to reproduce the problem and fix it.
                    I have already tested that your failing M117 line preceded by a blank line works for me.
                    mitchundefined 1 Reply Last reply Reply Quote 0
                    • mitchundefined
                      mitch @dc42
                      Will do. I am on travel so it may be a few days but happy to post a file with the issue when I return.
                      • mitchundefined
                        mitch
                        eyeball4_2 trunkcated.gcode
                        I truncated the file to meet the upload limit but here is the offending file. same error on that same M117 line every print.
                        I haven't tried with quotes. Pretty confident that would fix it. But I get that it should work both ways and you want to see why is causing the problem. Much appreciated.
                        thanks
