    Faster / Better home-z possible?
    500
    • jens55undefined
      jens55
      This is how I do my Z homing.
      Note the A10 bit - this probes until two successive probe runs agree within a certain range. It does up to 10 probes. It will stop if two runs agree and it will fault out if there is no agreement within 10 runs.
      This is for a BLTouch.
      For mapping the bed, I also lower jerk and acceleration.
      M558 F2000 A1 ; set for rapid decent for one probe
      G30 ; do quick probe
      ;this is to rapidly lower the nozzle in case it is quite high
      M558 F60 A10 ; return to normal (slow) probing speed
      • Kolbiundefined
        Kolbi
        Thanks @jens55 Just got done with a print, tested some options, and found this to work nicely. Nice use on the 'A' option - thanks for that.
        G1 X105 Y105 F6000                                         ; go to probe point
        M558 F1000                                                 ; fast z-probe, first pass
        G1 H0 Z5 F400                                              ; lift Z to the 5mm position
        M558 F50 A9                                                ; slow z-probe, second pass
        M558 F200 A1                                               ; normal z-probe, set to normal speed
          @Kolbi said in Faster / Better home-z possible?:
          Could / Should I use the following?
          M558 F800                                                  ; BLTouch, connected to Z probe IN pin - fast
          M558 F60                                                   ; BLTouch, connected to Z probe IN pin - slow
          G30
          Yes, there is no need to redefine the Z probe type when just changing the other parameters. Also, lifting Z between the two G30 probes (as you are now doing) is probably needed.
          • Kolbiundefined
            Kolbi
            Thanks @dc42 , @jens55 !
            • fcwiltundefined
              fcwilt
              I would not be comfortable use A1 as the default setting.
              It's fine for doing your "high speed" probe but for everything else I would at least use A2. I use A5.
              Kolbiundefined fcwiltundefined 2 Replies Last reply Reply Quote 1
              • Kolbiundefined
                Kolbi @fcwilt
                @fcwilt Thanks Frederick!
                • fcwiltundefined
                  fcwilt @fcwilt
                  Hi again.
                  Just FYI did you know you can force the averaging of a fixed number of readings?
                  For example A5 S-1 will cause 5 readings to be taken and the average computed.
                  Kolbiundefined jens55undefined 2 Replies Last reply Reply Quote 1
                  • Kolbiundefined
                    Kolbi @fcwilt
                    @fcwilt Just so I'm square on this; when A5 is used without the S-1 switch it will conduct up to five probes or until two back-to-back probes match, and the S-1 switch will cause it to probe 5 times and then yield the average of those 5?
                    • Kolbiundefined
                      Kolbi
                      AH... got it:
                      The A and S parameters control multiple probing. Probing is repeated until two consecutive probe attempts produce results that differ by no more than the S parameter; then the average of those two results is used. However, if the number of attempts specified by the A parameter is reached without getting two consecutive results within tolerance of each other, no further probe attempts are made and the average result of all the attempts is used.
                      • fcwiltundefined
                        fcwilt @Kolbi
                        Correct.
                        Consider, getting two consecutive readings doesn't mean that the readings are accurate, just that they are the same, within the tolerance specified by a positive S value.
                        The downside to averaging is it takes longer.
                        • jens55undefined
                          jens55 @fcwilt
                          @fcwilt said in Faster / Better home-z possible?:
                          Hi again.
                          Thanks Frederick - did not know that!
