    Ayuda core xy con duet2wifi
    3.0k
      droftarts administrators @Fabián
      @Fabián Send M122 and post reply, to show the firmware version. I suspect you are using RepRapFirmware v2.xx, but your config.g is for v3. You probably need to update your Duet 2 WiFi firmware.
      • Fabiánundefined
        Fabián
        Gracias a los por responder, esta tarde lo pruebo y les comento si mejora
        • Fabiánundefined
          Fabián
          M122
          === Diagnostics ===<LF>RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later<LF>Board ID: 0JD0M-9K662-MG5TD-6JTDG-3SJ6K-1BLYW<LF>Used output buffers: 1 of 24 (20 max)<LF>=== RTOS ===<LF>Static ram: 27980<LF>Dynamic ram: 93828 of which 60 recycled<LF>Exception stack ram used: 312<LF>Never used ram: 8892<LF>Tasks: NETWORK(ready,348) HEAT(blocked,1224) MAIN(running,1824) IDLE(ready,80)<LF>Owned mutexes: WiFi(NETWORK)<LF>=== Platform ===<LF>Last reset 00:00:56 ago, cause: power up<LF>Last software reset at 2020-08-19 09:23, reason: User, spinning module GCodes, available RAM 8940 bytes (slot 2)<LF>Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN<LF>Error status: 0<LF>MCU temperature: min 35.9, current 37.1, max 37.4<LF>Supply voltage: min 24.1, current 24.2, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes<LF>Driver 0: standstill, SG min/max not available<LF>Driver 1: standstill, SG min/max not available<LF>Driver 2: standst[Warning: Maximal number of bytes per line exceeded! Check the EOL (end-of-line) settings or increase the limit in the advanced terminal settings.]
            @Fabián Okay, you're running firmware 3.1.1, and your config.g is correct for this version. If the temperature sensor is still showing -273, you need to post a picture of your wiring. Also note that you are using the default thermistor, which may not be the same as your actual thermistor. Please post what thermistor you are using.
            Try sending M308 S0 to show the thermistor settings. I think you may need to change the Y parameter from Y"termistor" to Y"thermistor".
            • Fabiánundefined
              Fabián
              Hola Droftarts, pone lo siguiente:
              9/8/2020 13:35:35: M308 S0: Sensor 0 type Thermistor using pin bedtemp, reading 26.8, last error: sensor not ready, T:100000.0 B:4138.0 C:0.00e+0 R:4700.0 L:0 H:0
              • Fabiánundefined
                Fabián
                luego de ver la version del panel due que es la 1,24 , ahora se ve la temp. de la cama , pero el hotend no, te paso fotoIMG_20200819_134028.jpg IMG_20200819_134016.jpg
                Fabiánundefined 1 Reply Last reply Reply Quote 0
                • Fabiánundefined
                  Fabián @Fabián
                  @Fabián Perdon por mi ignorancia , todo esto es nuevo para mi y estoy muy perdido en programacion, solo quiero que imprima
                    @Fabián It looks like the thermistors are not being linked to the bed or tool. Can you post your config.g again, as it appears now?
                    Also send M308 S1 to check the second thermistor.
                    • Fabiánundefined
                      Fabián
                      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Aug 18 2020 23:41:07 GMT+0200 (hora de verano de Europa central)
                      M550 P"CoreXY" ; set printer name
                      M669 K1 ; select CoreXY mode
                      M552 S1 ; enable network
                      M586 P0 S1 ; enable HTTP
                      M586 P1 S0 ; disable FTP
                      M586 P2 S0 ; disable Telnet
                      M569 P1 S0 ; physical drive 1 goes forwards
                      M569 P2 S0 ; physical drive 2 goes backwards
                      M350 Z16 E16 I0 ; configure microstepping without interpolation
                      M350 X16 Y16 I1 ; configure microstepping with interpolation
                      M92 X80.00 Y80.00 Z2756.00 E406.00 ; set steps per mm
                      M566 X900.00 Y900.00 Z150.00 E600.00 ; set maximum instantaneous speed changes (mm/min)
                      M203 X30000.00 Y30000.00 Z300.00 E6000.00 ; set maximum speeds (mm/min)
                      M201 X5000.00 Y5000.00 Z100.00 E1000.00 ; set accelerations (mm/s^2)
                      M906 X800 Y800 Z500 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
                      M84 S30 ; Set idle timeout
                      M208 X330 Y330 Z400 S0 ; set axis maxima
                      M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
                      M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
                      G31 P500 X37 Y0 Z1.5 ; set Z probe trigger value, offset and trigger height
                      M557 X15:280 Y15:280 S20 ; define mesh grid
                      M308 S0 P"bedtemp" Y "thermistor" T100000 B4138 R4700 ; configure sensor 0 as thermistor on pin bedtemp
                      M307 H0 B0 S1.00 ; dissable bang-bang mode for heater and set PWM limit
                      M308 S1 P"e0temp" Y"thermistor" T100000 B4138 R4700 ; configure sensor 1 as thermistor on pin e0temp
                      M950 H1 C"e0heat" ; create nozzle heater output on e0heat and map it to sensor 1
                      M307 H1 B0 S1.00 ; dissable bang-bang mode for heater and set PWM limit
                      M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
                      M106 P2 S1 H1 T180 ; set fan 2 value. Thermostatic control is turned on
                      M563 P0 S"Hotend" D0 F0 ; define tool 0
                      M575 P1 S1 B115200 ; enable support for PanelDue
                      • Fabiánundefined
                        Fabián
                        19/8/2020 14:53:15 M308 S1
                        Tipo de sensor 1 Termistor usando pin e0temp, lectura 26.2, último error: sensor no listo, T: 100000.0 B: 4138.0 😄 0.00e + 0 R: 4700.0 L: 0 H: 0
                        • Fabiánundefined
                          Fabián
                          19/8/2020 14:53:48: M308 S1: Sensor 1 type Thermistor using pin e0temp, reading 26.2, last error: sensor not ready, T:100000.0 B:4138.0 C:0.00e+0 R:4700.0 L:0 H:0
                          • Fabiánundefined
                            Fabián
                            el termistor es el original de Titan aero E3D , conectado al E0 de la placa duet2 y la cama caliente es de silicona 220v/750w aliexpress china que viene con su termistor colocado sin datos , esta conectada a un mosfet externo
                              @Fabián For the heated bed, change the order of commands (M140 must come after M950, but before M143):
                              If you can find the specification of the thermistor that is in your heated bed (maybe the AliExpress link?), post the details and we can update the M308 with the correct values.
                              For the hot end, your tool does not have a heater/thermistor defined! Change to:
                              M563 P0 S"Hotend" D0 H1 F0 ; define tool 0
                              For an E3D Semitec 104-GT2 thermistor (used in the Titan Aero), change M308 to this:
                              M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
                              You will also need to tune the hot end heater and bed with M303 to get accurate values for M307; see https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M303_Run_heater_tuning
                              • Fabiánundefined
                                Fabián
                                Hola de nuevo Ian, la cama de silicona el fabricante dice que es NTC 100K 3950 180ºC
                                • Fabiánundefined
                                  Fabián
                                  Comprueba si lo modifique bien por favor el config sys
                                  Configuration file for Duet WiFi (firmware version 3)
                                  M308 S0 P"bedtemp" Y "thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
                                  M143 H0 S180 ; set temperature limit for heater 0 to 180C
                                  M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8; configure sensor 1 as thermistor on pin e0temp
                                  M140 H0 ; map heater 1
                                  • Fabiánundefined
                                    Fabián
                                      @Fabián looks good. Does it show correctly on PanelDue and DWC now?
                                      • Fabiánundefined
                                        Fabián
                                        no sigue siendo desigual Ian
                                        • Fabiánundefined
                                          Fabián
                                          Ian acabo de pedir una duet2wifi original a DUET y una Placa PT100,
                                          • Fabiánundefined
                                            Fabián
