    Z height issue
    531
    • alexicundefined
      alexic
      My printer is configured and printing well, it has dual motors for Z and I have a 3d touch probe to home the Z axis, do auto bed leveling and the bed mesh.
      I have a big issue that sometimes, something happens and the Z height gets messed up, the result is that the printing starts at a few milimeters in the air above the bed.
      Lately I was just homing the printer and loading the previously measured bed heigth map, and still the issue happenend.
      I have added all the code that migh get involved in a print procedure, homing, stoping the print.
      config.g
      M111 S0                             ; Debug off
      M550 P"V-King CXY"    			        ; Machine name (can be anything you like)
      M551 Preprap                        ; Machine password
      M667 S1                             ; select CoreXY mode
      M552 S1
      M586 P0 S1                          ; enable HTTP
      M586 P1 S0                          ; disable FTP
      M586 P2 S0                          ; disable Telnet
      M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED ; MAC Address
      M552 P0.0.0.0					            	; IP address (0 = use DHCP)
      M554 P192.168.1.1                   ; Gateway
      M553 P255.255.255.0                 ; Netmask
      M555 P2                             ; Set output to look like Marlin
      ; Panel Due
      M575 P1 B57600 S1				           	; Comms parameters for PanelDue
      ; Movement section
      G21                                 ; Work in millimetres
      G90                                 ; Send absolute coordinates...
      M83                                 ; ...but relative extruder moves
      M569 P0 S1                          ; Drive 0 goes forwards (change to S0 to reverse it)
      M569 P1 S1                          ; Drive 1 goes forwards
      M569 P2 S1                          ; Drive 2 goes forwards
      M569 P3 S0                          ; Drive 3 goes forwards
      M569 P4 S1                          ; Drive 4 goes forwards
      M584 X0 Y1 Z2:4 E3                    ; set drive mapping
      M671 X160:160 Y-140:320 S5            ; leadscrews position
      M208 X-11:281 Y-87:256                ; carriage max move positions
      M906 X800 Y800 Z1000 E600 I30         ; Set motor currents (mA)
      M84 S30                               ; Set idle timeout
      M201 X3000 Y3000 Z120 E1000           ; Accelerations (mm/s^2)
      M203 X18000 Y18000 Z600 E12000        ; Maximum speeds (mm/min
      M566 X900 Y900 Z150 E600              ; Allowable instantaneous speed change mm/minute
      M92 X80 Y80 Z1600 E400.66				      ; Set axis steps/mm
      M350 Z16 I0                           ; configure microstepping without interpolation
      M350 X16 Y16 E16 I1                   ; configure microstepping with interpolation
      M208 X-11 Y-87 Z-0.2 S1					; set axis minimum (adjust to make X=0 and Y=0 the edge of the bed)
      M208 X281 Y256 Z200 S0					; set axis maxima (adjust to suit your machine)
      M574 X1 S1 P"xstop"                            ; configure active-high endstop for low end on X via pin xstop
      M574 Y1 S1 P"ystop"                            ; configure active-high endstop for low end on Y via pin ystop
      M574 Z1 S2                                     ; configure Z-probe endstop for low end on Z
      M307 H3 A-1 C-1 D-1 ; release pin
      M950 S0 C"exp.heater3"                         ; create servo pin 0 for BLTouch
      M558 P9 C"zprobe.in+zprobe.mod" H5 F320 T18000 A30 S0.02 ; set Z probe type to bltouch and the dive height + speeds
      G31 P25 X32 Y-2 Z2.95                          ; set Z probe trigger value, offset and trigger height (Bigger Z offset means closer to bed)
      M557 X0:270 Y5:255 S20                         ; define mesh grid
      ; Heater and thermistor section
      M950 H0 C"bedheat" T0                          ; create bed heater output on bedheat and map it to sensor 0
      M143 H0 S80                                    ; set temperature limit for heater 0 to 120C
      ;M307 H0 B1 ; bit-bang mode, does not work
      M307 H0 B0 S1.00                               ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                        ; map heated bed to heater 0
      M308 S1 P"e0temp" Y"thermistor" T100000 B4138
      M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
      M143 H1 S300                                   ; set temperature limit for heater 1 to 300C
      M307 H1 B0 S1.00                               ; disable bang-bang mode for heater  and set PWM limit
      M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1                                 ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"fan1" Q500                           ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H1 T100                              ; set fan 1 value. Thermostatic control is turned on
      M950 F2 C"fan2" Q500                           ; create fan 2 on pin fan2 and set its frequency
      M106 P2 S1 H1 T180                             ; set fan 2 value. Thermostatic control is turned on
      ; Tool definition section
      M563 P0 D0 H1 F0                    ; Define tool 0 to use extruder drive 0 and heater 1
      G10 P0 S0 R0                        ; Set tool 0 operating and standby temperatures
      G10 P0 X0 Y0 Z0                     ; set tool 0 axis offsets
      M572 D0 S0.5 ; pressure advance
      ; Trigger buttons
      M574 E0 S0 ; sets the E0 endstop to active low for NO switch
      M574 E1 S0 ; same for E1
      M581 E0 T2 S0 ; configure trigger 2 to use E0 endstop on falling edge for NO switch
      M581 E1 T3 S0 ; configure trigger 3 for E1 endstop falling edge for NO switch
      ; Epilogue
      ;*** If you are using axis compensation, put the figures in the following command
      ;M556 S78 X0 Y0 Z0                   ; Axis compensation here
      M501                ; load saved parameters from non-volatile memory
      T0									; select first hot end
      bed.g
      G29 S2; Clear bed height map
      ;G29  ; probe the bed and enable compensation
      G28
      G30 P0 X160 Y5 Z-99999
      G30 P1 X160 Y245 Z-99999 S2
      homeall.g
      M561 			; remove any bed compensation
      G1 H2 Z15 F600         ; lift Z relative to current position
      G1 H1 X-291 Y-341 F6000 ; move quickly to X or Y endstop and stop there (first pass)
      G1 H1 X-291             ; home X axis
      G1 H1 Y-341             ; home Y axis
      G1 X5 Y5 F6000         ; go back a few mm
      G1 H1 X-291 F4000        ; move slowly to X axis endstop once more (second pass)
      G1 H1 Y-341 F4000        ; then move slowly to Y axis endstop
      G90                     ; absolute positioning
      G1 X140 Y125 F6000        ; go to first bed probe point and home Z
      G30                     ; home Z by probing the bed
      homex.g
      G1 H1 X-291 F8000 ; move quickly to X axis endstop and stop there (first pass)
      G1 X5 F6000      ; go back a few mm
      G1 H1 X-291 F6000  ; move slowly to X axis endstop once more (second pass)
      G1 H2 Z-5 F600  ; lower Z again
      homey.g
      G1 H1 Y-341 F12000 ; move quickly to Y axis endstop and stop there (first pass)
      G1 Y5 F18000      ; go back a few mm
      G1 H1 Y-341 F6000  ; move slowly to Y axis endstop once more (second pass)
      homez.g
      G1 H2 Z15 54000  ; lift Z relative to current position
      G1 X140 Y125 F18000 ; go to first probe point
      slicer start code
      G28 ;Home
      G29 S1; load mesh
      G1 Z15.0 F6000 ;Move the platform down 15mm
      ;Prime the extruder
      G92 E0
      G1 F200 E3
      G92 E0
      slicer end code
      M104 S0
      M140 S0
      ;Retract the filament
      G92 E1
      G1 E-1 F300
      G28 X0 Y0
      M84
      pause.g
      M83            ; relative extruder moves
      G1 E-10 F3600  ; retract 10mm of filament
      G1 Z5 F360     ; lift Z by 5mm
      G1 X0 Y0 F6000 ; go to X=0 Y=0
      stop.g
      M104 S0 ; cool extruder
      M140 S0 ; cool bed
      G92 E1
      G1 E-1 F300
      G28 X0 Y0 return to 0
      M84 ; disable motors
      M106 P0 S0 ; stop layer fan
      I am sorry for the long post but I hope somebody can help with this issue. Because restarting the printer does not fix it, the only thing I can do is redo the probe calibration and increase the Z probe offset.
      • fcwiltundefined
        fcwilt
        @alexic said in Z height issue:
        For my BLTouch v3.0 I don't have the M307 or the + zprobe.mod part and it works fine. Have no idea if that would have any negative effect though.
        I don't see where you create the height map using G30 and G29.
        • alexicundefined
          alexic
          Thanks for your input. the Z-probe code is taken from the duet page example, M307 is there to release the H3 pin which is by default by heater 3 and not cause any problems.
          To greate the mesh I manually ran once first HomeAll then Run Mesh Compensation (G29) from the DWC.
          Then I can see the map in the Height Map page, I assume G29 S1 is loading that map that is shown in the visualizer. Or am I wrong?
          • fcwiltundefined
            fcwilt @alexic
            I forgot about the item on the DWC page where you can create the height map - that works fine.
            Do you use baby stepping sometimes during a print? I include M290 R0 S0 ; cancel baby stepping in my macros when probing the bed, just to be safe. It might not be needed but it doesn't hurt.
            I understand what M307 did under v2 firmware but it is not used with v3 firmware.
            Did you read the following in regards for v3 firmware?
            1. Identify the name of the pin that you connected the control input of the BLTouch to. On a Duet WiFi/Ethernet without an attached DueX expansion board, it will be one of exp.heater3 thru exp.heater7. If you have a DueX attached, one of duex.pwm1 thru duex.pwm5. On a Duet Maestro it is zprobe.mod. On Duet 3 it is one of io4.out, io5.out or io7.out. If you use one of these pin names, you will not need to invert the output.
            2. The Z probe input pin will be zprobe.in on a Duet 2, or one of io4.in, io5.in or io7.in on a Duet 3. If using zprobe.in, you need to enable the pullup resistor using the ^ character in front of the pin name.
            3. In your M558 command, specify probe type 9 and the input pin, for example:
            M558 P9 C"^zprobe.in" H5 F100 T2000
            If using pin zprobe.in then must include the ^ character in front of the pin name to enable the pullup resistor.
            1. Create a GPIO/Servo pin index using your chosen control pin:
            In this example we chose to attach GPIO/Servo index 0 to pin exp.heater3 on the expansion connector of a Duet WiFi or Duet Ethernet. On a Duet Maestro you would use C"zprobe.mod" in the M950 command.
            • alexicundefined
              alexic
              Okay I added the ^ in front of zprobe.in it should be more robust in triggering the probe.
              Still for me it's not about that, it is some offset stored somewehere in the software, or my probe might be damaged.
              Because right now I had to recalibrate the probe and increase the Z offset from 2.95 to 3.9 and this seems impossible.
              • fcwiltundefined
                fcwilt @alexic
                As to stored offsets the only ones I know of are:
                • baby stepping in the Duet firmware
                • xyz offsets in slicer applications
                The probe Z offset is related to the mounting of the probe in relation to the nozzle.
                Using this as your guide what is your nozzle-to-pin difference (the red number)?
                alexicundefined 1 Reply Last reply Reply Quote 1
                  Phaedrux Moderator @alexic
                  3d touch probe
                  A clone?
                  alexicundefined 1 Reply Last reply Reply Quote 0
                  • alexicundefined
                    alexic @fcwilt
                    @fcwilt the phisical offset is 2.9mm in reality
                    • alexicundefined
                      alexic @Phaedrux
                      @Phaedrux Yes it is a clone, that's the name, 3D Touch. Everytime I wonder if the probe is not the issue, and I'm not sure, I plan to replace it with a IR-probe to clarify this unknown variable.
                      • fcwiltundefined
                        fcwilt @alexic
                        Before I understood the difference my first two BLTouch were actually clones.
                        They did not work.
                        Then I got two genuine v3.0 units and they worked without issue.
